I have a magnetic encoder that I can read values in the range of 0 to 1024. I need a way to be able to accumulate this value into a new value for example 2 rotations would be 2048 or -2048. I'm using a serial output variable to set this new position but cant seem to get my head around how I might tell it to do so. The attached code is working for the range in which I have mapped 1024 to 360. I want to use this accumulating value to be able to keep track of the position even if i rotate many times.
Most of the important things are in
void loop_sv4()
////////////////////// as5040
#include <PWM.h>
//AS5040 stuff
const int clockPin = 7; //output to clock
const int CSnPin = 6; //output to chip select
const int inputPin = 2; //read AS5040
int inputstream = 0; //one bit read from pin
long packeddata = 0; //two bytes concatenated from inputstream
long angle = 0; //holds processed angle value
long anglemask = 65472; //0x1111111111000000: mask to obtain first 10 digits with position info
long statusmask = 63; //0x000000000111111; mask to obtain last 6 digits containing status info
long statusbits; //holds status/error information
int DECn; //bit holding decreasing magnet field error data
int INCn; //bit holding increasing magnet field error data
int OCF; //bit holding startup-valid bit
int COF; //bit holding cordic DSP processing error data
int LIN; //bit holding magnet field displacement error data
int debug = 0; //SET THIS TO 0 TO DISABLE PRINTING OF ERROR CODES
int shortdelay = 1; // this is the microseconds of delay in the data clock
int rotations = 0; //how many times have I spun around
int overallpostion = 0; //count rotations plus postions into a new value
//PID stuff
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
// Serial for VVVV
String readString;
//PWM fast
int ENA = 9;//fast PWM
int IN1 = 12;
int IN2 = 13;
int32_t frequency = 16000; //frequency (in Hz)
void setup_sv4()
InitTimersSafe();
bool success = SetPinFrequencySafe(ENA, frequency);
pinMode (ENA, OUTPUT);
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
//Serial.println("V4_Arduino_L298N_AS5040");//track what I have loaded
pinMode(clockPin, OUTPUT); // SCK
pinMode(CSnPin, OUTPUT); // CSn -- has to toggle high and low to signal chip to start data transfer
pinMode(inputPin, INPUT); // SDA
setup_sv4();
void loop_sv4() {
if (Serial.available())
char c = Serial.read(); //gets one byte from serial buffer
if (c == 'a')
if (readString.length() >0)
int SerialInput = readString.toInt(); //convert readString into a number
int Xaxis = angle;//magnet position
int DiffLeft = SerialInput - Xaxis;
int DiffRight = Xaxis - SerialInput;
//int BreakL = 1;
//int BreakR = 1;
//if (SerialInput > Xaxis && DiffLeft > BreakL) //> <
if (SerialInput > Xaxis) //>
digitalWrite (IN1, HIGH);
digitalWrite (IN2, LOW);
int Lspd = map(DiffLeft, 0, 360, 404, 490);
pwmWrite (ENA, (Lspd) );
Serial.println(DiffLeft, DEC);
//f (DiffRight > BreakR)
digitalWrite (IN1, LOW);
digitalWrite (IN2, HIGH);
int Rspd = map(DiffRight, 0, 360, 404, 490);
pwmWrite (ENA, (Rspd) );
readString=""; //clears variable for new input
Serial.println(DiffRight, DEC);
Serial.println(angle, DEC);
else if (c == 'b')
int n = readString.toInt(); //convert readString into a number
else if (c == 'c')
/// be sure this value is >= '0' && <= '9'
readString += c; //makes the string readString
loop_sv4();
// CSn needs to cycle from high to low to initiate transfer. Then clock cycles. As it goes high
// again, data will appear on sda
digitalWrite(CSnPin, HIGH); // CSn high
digitalWrite(clockPin, HIGH); // CLK high
delay(shortdelay);// time between readings
digitalWrite(CSnPin, LOW); // CSn low: start of transfer
delayMicroseconds(shortdelay); // delay for chip initialization
digitalWrite(clockPin, LOW); // CLK goes low: start clocking
delayMicroseconds(shortdelay); // hold low
for (int x=0; x <16; x++) // clock signal, 16 transitions, output to clock pin
digitalWrite(clockPin, HIGH); //clock goes high
inputstream =digitalRead(inputPin); // read one bit of data from pin
packeddata = ((packeddata << 1) + inputstream);// left-shift summing variable, add pin value
delayMicroseconds(shortdelay); // end of one clock cycle
angle = packeddata & anglemask; // mask rightmost 6 digits of packeddata to zero, into angle.
angle = (angle >> 6); // shift 16-digit angle right 6 digits to form 10-digit value
angle = angle * 0.3515; // angle * (360/1024) == actual degrees
//Serial.print("angle: "); // and, finally, print it.
//Serial.println(angle, DEC);
if (debug)
statusbits = packeddata & statusmask;
DECn = statusbits & 2; // goes high if magnet moved away from IC
INCn = statusbits & 4; // goes high if magnet moved towards IC
LIN = statusbits & 8; // goes high for linearity alarm
COF = statusbits & 16; // goes high for cordic overflow: data invalid
OCF = statusbits & 32; // this is 1 when the chip startup is finished.
if (DECn && INCn) { Serial.println("magnet moved out of range"); }
if (DECn) { Serial.println("magnet moved away from chip"); }
if (INCn) { Serial.println("magnet moved towards chip"); }
if (LIN) { Serial.println("linearity alarm: magnet misaligned? Data questionable."); }
if (COF) { Serial.println("cordic overflow: magnet misaligned? Data invalid."); }
packeddata = 0; // reset both variables to zero so they don't just accumulate
//angle = 0;
