Make parameter Serial number - "Not specified" (Leonardo)
Hello! I'm using IDE 2.1.0 with Leonardo's board and using the USB HID keyboard and mouse emulation library. I know where i can set the "Serial Number" parameter of my USB HID Device - in PluggableUSB.cpp :
for example - the code below will set the parameter "Serial number" of the device - 01296
virtual uint8_t getShortName(char *name) { name[0] = '0'; name[1] = '1'; name[2] = '2'; name[3] = '9'; name[4] = '6';   return 5; }
Well, but how can I make this parameter "Serial number" are "Not specified"? For example - I analyze real USB HID devices - this parameter it says "Not specified", i.e. the parameter is not set. Example1 Example2
I have tried ending the above line like this -
virtual uint8_t getShortName(char *name) { name[0] = '0'; name[1] = '1'; name[2] = '2'; name[3] = '9'; name[4] = '6';   return 0; }
but it had no effect. - it says "String Descriptor 3 (unable to read).
Has anyone successfully resolved this issue?
Thank you!
