Hello. Today I was wrote a code about control three servos, each servo motor is connected to pins 2, 3 and 4
I need something more advanced maybe put the exact degrees to move an specific servo.
For example: "Welcome to servo motor control system"
First step: Select your servo to be controlled:
1 2 3
Second step: enter numbers degrees you want to move it:
_ (here I put degrees)
My question is: how can I write a Yes or No dialogue? (Using if as conditional sentence)
Some useful functions for you may need
byte ServoNum;
boolean gotServoNum = false;
Serial.println("Enter a Servo number : ");
if (Serial.available() > 0 && gotServoNum == false)
ServoNum = Serial.read();
gotServoNum = true;
Serial.print("You chose Servo number ");
Serial.write(ServoNum);
jim-p
January 8, 2024, 6:41pm
4
Do you mean like this?
if (answer == "YES")
//do this
//do that
What is the baud rate of the Serial monitor set to ?
It was 115200. Now change it at 9600 and show this repeatdely. This need a wait command
I will try it now. Declare answer as a input
edwinjbg:
edwinjbg:
If you have the Serial monitor set to 9600 then you are not running the code that I posted
Sorry, I can’t read your screenshots on my phone.
@edwinjbg , please do not cross-post. Other thread removed.
Hi, @edwinjbg
Slow down mate.
Although you are asking 5 different questions here with 5 different threads, it might be better if you concentrate one request at a time, get it solved then go onto the next.
This might help to, please read, you need to post your code in code tags;
Thanks.. Tom...
system
Closed
July 6, 2024, 9:56pm
20
