Hi!
I got a project where I´m using a rotary encoder to turn my stepper motor, also as a switch with IN and OUT positions to go back and forth. I also got som LEDs for speed and marking of IN an OUT points.
I got the project running on a arduino UNO but now I want to make it wireless with NRF24L01.
My question is, how can I "split" the code to Transmitter and Reciver and how do you do it the easy way, assuming there is one?
OR: Should I use an other module for this purpose?
AND: Can I use the Arduino Micro for the Reciver?
Thanks for your help!
This is what I got:
#include <Stepper.h>
#include <FastLED.h>
// silent step stick driver connection
#define dir_pin 8
#define step_pin 9
#define MS1 10
#define MS2 11
#define SLEEP 12
//Adafruit RGB LED connection
#define led_pin 5
// IN & OUT switches connection
#define SWITCH_PIN_IN A0
#define SWITCH_PIN_OUT A1
// LED for switches connection
#define BUT_LED_PIN 3
#define BUT_LED2_PIN 5
// Rotary encoder module connections
const int PinCLK=2;
const int PinSW=4;
const int PinDT=6;
#define NUM_LEDS 8 //NUM of LEDs on stick
CRGB leds[NUM_LEDS]; //FastLED library unit
volatile boolean TurnDetected; // to detect rotation of Rotary Encoder
volatile boolean rotationdirection; // CW or CCW rotation
volatile boolean rswitch=0; // Variable to store rotary encoder switch state
volatile boolean led_speed_change; // to detect change of speed
volatile int StepsToTake=2; // Controls the speed of the Stepper per Rotary click
int direction; // Variable to set Rotation (CW-CCW) of stepper
int StepperPosition=0; // To store Stepper Motor Position
int IN_Position=0; // To store IN point Position
int OUT_Position=0; // To store OUT point Position
int Time;
void rotarydetect () {
delay(10);
if (rswitch == 1) {
if (digitalRead(PinCLK)) {
if (digitalRead(PinDT)) {
if (StepsToTake > 2) {
StepsToTake=StepsToTake-1; }}
if (!digitalRead(PinDT)) {
if (StepsToTake < 9) {
StepsToTake=StepsToTake+1; }}
led_speed_change = true;
else {
rotationdirection= digitalRead(PinDT);
TurnDetected = true;
void setup () {
pinMode(BUT_LED_PIN, OUTPUT);
pinMode(BUT_LED2_PIN, OUTPUT);
digitalWrite(BUT_LED_PIN,LOW);
digitalWrite(BUT_LED2_PIN,LOW);
pinMode(SWITCH_PIN_IN, INPUT);
pinMode(SWITCH_PIN_OUT, INPUT);
digitalWrite(SWITCH_PIN_IN,HIGH);
digitalWrite(SWITCH_PIN_OUT,HIGH);
FastLED.addLeds<NEOPIXEL,led_pin>(leds, NUM_LEDS); // setup FastLED library
FastLED.clear();
for(int x = 0; x != (StepsToTake - 1); x++) {
if (x < 2) leds[x] = CRGB::Red;
if (x > 1 & x < 5) leds[x] = CRGB::Orange;
if (x > 4) leds[x] = CRGB::Green; }
FastLED.setBrightness(50);
FastLED.show();
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(dir_pin, OUTPUT);
pinMode(step_pin, OUTPUT);
pinMode(SLEEP, OUTPUT);
digitalWrite(SLEEP, HIGH); // wake up silent step stick driver
delay(5);
digitalWrite(MS1, LOW);
digitalWrite(MS2, LOW);
pinMode(PinCLK,INPUT);
pinMode(PinDT,INPUT);
pinMode(PinSW,INPUT);
digitalWrite(PinSW,INPUT_PULLUP);
attachInterrupt (0,rotarydetect,FALLING);
void loop () {
if (digitalRead(SWITCH_PIN_IN) == LOW) // Do if IN switch is pressed
Time = millis();
delay(500);//debounce
// check if the switch is pressed for longer than 1 second.
if(digitalRead(SWITCH_PIN_IN) == LOW && Time - millis() >5000)
digitalWrite(BUT_LED_PIN,HIGH);
delay(10000);
IN_Position=StepperPosition;
if (StepperPosition == IN_Position) {
if (StepperPosition > IN_Position) {
while (StepperPosition > IN_Position) {
digitalWrite(dir_pin, HIGH);
for (int x = 1; x < StepsToTake; x++) {
digitalWrite(step_pin, HIGH);
delay(1);
digitalWrite(step_pin, LOW);
delay(1);
StepperPosition=StepperPosition-StepsToTake;
delay(100-(StepsToTake*11));
else {
while (StepperPosition < IN_Position) {
digitalWrite(dir_pin, LOW);
delay(1);
delay(1);
StepperPosition=StepperPosition+StepsToTake;
if (digitalRead(SWITCH_PIN_OUT) == LOW) // Do if IN switch is pressed
Time = millis();
if(digitalRead(SWITCH_PIN_OUT) == LOW && Time - millis() >5000)
digitalWrite(BUT_LED2_PIN,HIGH);
delay(10000);
OUT_Position=StepperPosition;
if (StepperPosition == OUT_Position) {
if (StepperPosition > OUT_Position) {
while (StepperPosition > OUT_Position) {
delay(1);
delay(1);
else {
while (StepperPosition < OUT_Position) {
delay(1);
delay(1);
if (!(digitalRead(PinSW))) {
delay(250);
if (rswitch == 0) {
rswitch = 1; }
else {
rswitch = 0; }
if (led_speed_change) {
led_speed_change = false;
FastLED.clear();
FastLED.show();
if (TurnDetected) {
TurnDetected = false;
if (rotationdirection) {
delay(1);
delay(1);
if (!rotationdirection) {
delay(1);
delay(1);
