Hello,
I want to use a master enum to be used with other enums. The compiler won't accept that.
Is there anyway to do that ?
This is the code I want to design:
// master button index
typedef enum : uint8_t {} FUNCTION_BUTTON_INDEX_T;
// electrical monitor and control
typedef enum : uint8_t {NO_BUTTON, CURRENT_READING, VOLTAGE_READING,
POWER_READING} ELECTRICAL_BUTTON_INDEX_T;
// motor control modes
typedef enum : uint8_t {NO_BUTTON, SERVO_MOTOR_CONTROL, DC_MOTOR_CONTROL,
STEPPER_MOTOR_CONTROL} MOTOR_BUTTON_INDEX_T;
As I want to use the master button index in one master struct for function buttons:
// function_button
struct function_button{
uint16_t x;
uint16_t y;
uint16_t w;
uint16_t h;
uint16_t button_color;
uint16_t text_color;
char text[20];
FUNCTION_BUTTON_INDEX_T button_number;
In case I want to do this:
function_button button1;
button1.button_number = SERVO_MOTOR_CONTROL;
Then of course that's an error.
I thought of using a void *FUNCTION_BUTTON_INDEX_T ; but that will require me to typecast every line after that.
Any suggestions ?
J-M-L
March 3, 2023, 8:51am
2
An enum is a type so you would end up with a kind of dual type in what you want to do if I got that right and There is no inheritance with enums
Please explain in English what this line of code does
The best I could do is to typecast it, this one has no error. But I'm searching for a solution not to use typecast as much as I can.
function_button b1;
b1.button_number = (FUNCTION_BUTTON_INDEX_T)CURRENT_READING;
I also think that I may not use enums, and instead go with defines and then use uint8_t.
OK, I think I solved the problem, I shouldn't use a master enum, and just use a variable inside the struct; like this:
This:
// function_button
uint16_t x;
uint16_t y;
uint16_t w;
uint16_t h;
char text[20];
Should be this:
// function_button
uint16_t x;
uint16_t y;
uint16_t w;
uint16_t h;
char text[20];
uint8_t button_number;
Then I can assign it like this:
function_button b_current = {40, 60, 150, 30, TFT_BLUE, TFT_WHITE, "CURRENT READING", CURRENT_READING};
function_button b_voltage = {40, 90, 150, 30, TFT_BLUE, TFT_WHITE, "VOLTAGE READING", VOLTAGE_READING};
And it compiled without errors.
I thought I cold use the name of the enum as a master type to hold the data for other enums.
J-M-L
March 3, 2023, 9:19am
9
You might want to consider inheritance and pure virtual functions
for example
Run IoT and embedded projects in your browser: ESP32, Arduino, Pi Pico, and more. No installation required!
class Button {
protected:
uint16_t x;
uint16_t y;
uint16_t w;
uint16_t h;
const char* text;
public:
Button(const char * lbl) : x(0), y(0), w(10), h(12), button_color(0), text_color(0xFFFF), text(lbl) {}
virtual void action() = 0; // Pure virtual
class ElectricalButton : public Button {
public:
ElectricalButton(const char * lbl) : Button(lbl) {}
void action() {
Serial.print("ElectricalButton action : ");
Serial.println(text);
class MotorButton : public Button {
public:
MotorButton(const char * lbl) : Button(lbl) {}
void action() {
Serial.print("MotorButton action : ");
MotorButton leftMotorButton("left engine");
MotorButton rightMotorButton("right engine");
ElectricalButton elecButton("power");
Button* myButtons[] = {&leftMotorButton, &rightMotorButton, &elecButton};
Serial.begin(115200); Serial.println();
for (auto && b : myButtons) b->action();
void loop() {}
Serial Monitor (@ 115200 bauds) will show
MotorButton action : left engine
MotorButton action : right engine
ElectricalButton action : power
➜ every Button has an action function and its behavior depends on the subclass but yet everything was stored in an array of pointers which types are from the base class.
OK, thank you so much for this wonderful piece of code. This is completely different that my simple coding.
I stopped at the pure virtual functions before months and didn't come back to carry on that topic, but this should really put a good application advantage in my project
system
Closed
August 30, 2023, 11:49am
11
