clear;
% Connect to Arduino
a = arduino;
% User input for Flowrate info
num_pumps = input('Please enter the number of pumps you are using (ex. 4): ', 's');
number_pumps = str2double(num_pumps);
pump_list = cell(1, number_pumps);
flowrate_archives = zeros(172800,6);
for j = 1:number_pumps
pump_input = input('Please enter the pumps in alphabetical order one at a time: ', 's');
pump_list{j} = pump_input;
pump_rate = input('Please enter the flow rate for this pump: ','s');
pump_rate_num = str2double(pump_rate);
pump_rate_list(j) = pump_rate_num;
end
%User input for temperature info
temperature_archives = zeros(172800,5);
num_temp = input('Please enter the number of temperature sensors you are using: ','s');
number_temp = str2double(num_temp);
temp_list = cell(1,number_temp);
for j = 1:number_temp
temp_input = input('Please enter one of temperature sensors you are using: ','s');
temp_list{j} = temp_input;
temp_rate = input('Please enter the temperature you would like to keep that sensor at in C: ','s');
temp_rate_num = str2double(temp_rate);
temp_rate_list(j) = temp_rate_num;
end
%User input for pressure info
pressure_archives = zeros(172800,5);
num_pressure = input('Please enter the number of pressure sensors you are using (ex. 4): ', 's');
number_pressure = str2double(num_pressure);
pressure_list = cell(1, number_pressure);
for j = 1:number_pressure
pressure_input = input('Please enter the pressure sensors you are using in alphabetical order one at a time: ', 's');
pressure_list{j} = pressure_input;
pressure_rate = input('Please enter the pressure for this sensor in psi: ','s');
pressure_rate_num = str2double(pressure_rate);
pressure_rate_list(j) = pressure_rate_num;
end
% Positions and colors for the text elements
Legend_Positions = [0.87, 0.83, 0.79, 0.75, 0.71, 0.67];
colors = {'black','red','#EDB120','#77AC30','#4DBEEE','m'};
pump_ids = {'A','B','C','D','E','F'};
pump_letters = 'ABCDEF';
temp_numbers = '12345';
pressure_letters = 'ABCEE';
% Create figures for flowrate data
figure1 = figure('Name', 'Flowrate Data');
subplot(2, 1, 1);
PumpA = animatedline('Color', 'black');
PumpB = animatedline('Color', 'red');
PumpC = animatedline('Color', '#EDB120');
PumpD = animatedline('Color', '#77AC30');
PumpE = animatedline('Color', '#4DBEEE');
PumpF = animatedline('Color', 'm');
title('All Flowrate Data Points');
xlabel('# of Samples');
ylabel('Flowrate (mL/min)');
ylim([0, 11]);
% Timer for Flowrate
TimerText = uicontrol('Style', 'text', 'FontSize', 10, 'Units', 'normalized', ...
'Position', [0.72 0.93 0.15 0.05], 'String', '0:00:00');
% Legend for flowrate data
Legend_Text = cell(1, length(pump_ids));
Pos_Update = 1;
for idx = 1:length(pump_ids)
if ismember(pump_ids(idx), pump_list)
Legend_Text{idx} = uicontrol('Style', 'text', 'FontSize', 7, 'Units', 'normalized', 'Position', [0.15 Legend_Positions(Pos_Update) 0.15 0.04], 'ForegroundColor', colors{idx});
Pos_Update = Pos_Update + 1;
Legend_Text{idx} = uicontrol('Style', 'text', 'FontSize', 7, 'Units', 'normalized', 'Position', [0.15 9999 0.15 0.04]);
end
end
% Assign text handles to individual variables if needed
Pump_A_Legend = Legend_Text{1};
Pump_B_Legend = Legend_Text{2};
Pump_C_Legend = Legend_Text{3};
Pump_D_Legend = Legend_Text{4};
Pump_E_Legend = Legend_Text{5};
Pump_F_Legend = Legend_Text{6};
% Flowrate Average Plot
subplot(2,1,2);
PumpA_Avg = animatedline('Color', 'black');
PumpB_Avg = animatedline('Color', 'red');
PumpC_Avg = animatedline('Color', '#EDB120');
PumpD_Avg = animatedline('Color', '#77AC30');
PumpE_Avg = animatedline('Color', '#4DBEEE');
PumpF_Avg = animatedline('Color', 'm');
title('Average (5sec) Flowrate');
ylim([0, 11]);
% Create figures for pressure data
figure2 = figure('Name', 'Pressure Data');
subplot(2, 1, 1);
pressure_1 = animatedline('Color','black');
pressure_2 = animatedline('Color','red');
pressure_3 = animatedline('Color','#EDB120');
pressure_4 = animatedline('color','#77AC30');
pressure_5 = animatedline('color','#4DBEEE');
title('Overall Pressure');
ylabel('Pressure (psi)');
ylim([0, 200]);
%Lenegd for pressure data
Pressure_Legend_Text = cell(1, length(pressure_letters));
Pos_Update = 1;
for idx = 1:length(pressure_letters)
if ismember(pressure_letters(idx), pressure_list)
Pressure_Legend_Text{idx} = uicontrol('Style', 'text', 'FontSize', 7, 'Units', 'normalized', 'Position', [0.15 Legend_Positions(Pos_Update) 0.15 0.04], 'ForegroundColor', colors{idx});
Pressure_Legend_Text{idx} = uicontrol('Style', 'text', 'FontSize', 7, 'Units', 'normalized', 'Position', [0.15 9999 0.15 0.04]);
end
end
Pressure_A_Legend = Pressure_Legend_Text{1};
Pressure_B_Legend = Pressure_Legend_Text{2};
Pressure_C_Legend = Pressure_Legend_Text{3};
Pressure_D_Legend = Pressure_Legend_Text{4};
Pressure_E_Legend = Pressure_Legend_Text{5};
%Timer on pressure graph
pressureTimer = uicontrol('Style', 'text', 'FontSize', 10, 'Units', 'normalized','Position', [0.72 0.93 0.15 0.05], 'String', '0:00:00');
subplot(2,1,2);
pressure_1_avg = animatedline('color','black');
pressure_2_avg = animatedline('color','red');
pressure_3_avg = animatedline('color','#EDB120');
pressure_4_avg = animatedline('color','#77AC30');
pressure_5_avg = animatedline('color','#4DBEEE');
title('Average (5sec) Pressure');
ylim([0, 200]);
%Create figures for temperature data
figure3 = figure('Name', 'Temperature Data');
subplot(2, 1, 2);
temp_1_avg = animatedline('Color','Black');
temp_2_avg = animatedline('color','red');
temp_3_avg = animatedline('color','#EDB120');
temp_4_avg = animatedline('color','#77AC30');
temp_5_avg = animatedline('color','#4DBEEE');
title('Average (5sec) Temperature');
xlabel('# of Samples'); ylabel('Degrees Celcius');
ylim([0, 100]);
% Legend for the temperature graphs
Temp_Legend_Text = cell(1, length(temp_numbers));
Pos_Update = 1;
for idx = 1:length(temp_numbers)
if ismember(temp_numbers(idx), temp_list)
Temp_Legend_Text{idx} = uicontrol('Style', 'text', 'FontSize', 7, 'Units', 'normalized', 'Position', [0.15 Legend_Positions(Pos_Update) 0.15 0.04], 'ForegroundColor', colors{idx});
Temp_Legend_Text{idx} = uicontrol('Style', 'text', 'FontSize', 7, 'Units', 'normalized', 'Position', [0.15 9999 0.15 0.04]);
end
end
Temp_A_Legend = Temp_Legend_Text{1};
Temp_B_Legend = Temp_Legend_Text{2};
Temp_C_Legend = Temp_Legend_Text{3};
Temp_D_Legend = Temp_Legend_Text{4};
Temp_E_Legend = Temp_Legend_Text{5};
%timer on temperature graph
tempTimer = uicontrol('Style', 'text', 'FontSize', 10, 'Units', 'normalized','Position', [0.72 0.93 0.15 0.05], 'String', '0:00:00');
subplot(2, 1, 1);
temp_1 = animatedline('Color','Black');
temp_2 = animatedline('color','red');
temp_3 = animatedline('color','#EDB120');
temp_4 = animatedline('color','#77AC30');
temp_5 = animatedline('color','#4DBEEE');
title('Temperature Overall');
ylim([0, 100]);
% Figure 4 to display error messages
figure4 = figure('Name','Flowrate Error');
flowrate_warning_text = uicontrol('Style', 'text', 'FontSize', 15, 'Units', 'normalized','Position', [0.2 0.2 0.6 0.6], 'String', ' ');
pressure_warning_text = uicontrol('Style', 'text', 'FontSize', 15, 'Units', 'normalized','Position', [0.2 0.4 0.6 0.6], 'String', ' ');
temp_warning_text = uicontrol('Style', 'text', 'FontSize', 15, 'Units', 'normalized','Position', [0.2 0.6 0.6 0.6], 'String', ' ');
% Main loop to update the plots
out_of_range = zeros(1, length(pump_list));
i = 1;
% Initialize start time at the last moment before the loop starts
startTime = tic;
while true
% Read voltages from Arduino
flow_voltages = zeros(1,6);
for j = 1:6
flow_voltages(j) = readVoltage(a,['A',num2str(j-1)]);
end
%Read temp voltages from Arduino
temp_voltages = zeros(1,5);
for j = 1:5
temp_voltages(j) = readVoltage(a,['A',num2str(j+5)]);
end
%Read pressure voltages from Arduino
pressure_voltages = zeros(1,5);
for j = 1:5
pressure_voltages(j) = readVoltage(a,['A',num2str(j+10)]);
end
% Convert voltages to flowrates
flowrates = (flow_voltages - 0.8077) / 0.2876;
flowrate_archives(i,:) = flowrates;
%Convert voltages to temperatures
temperatures = (temp_voltages-1.25)/0.005;
temperature_archives(i,:) = temperatures;
%Convert voltages to pressure
pressures = (pressure_voltages-0.8613)/0.0176;
pressure_archives(i,:) = pressures;
%Flowrate +- 10% check
flowrate_warning_message = ' ';
for j= 1:length(pump_list)
lower_bound = pump_rate_list(j) * 0.9;
upper_bound = pump_rate_list(j) * 1.1;
if flowrates(j)<lower_bound || flowrates(j)>upper_bound
out_of_range = out_of_range + 1;
%fprintf("PUMP %s OUT OF +-10% RANGE FOR THE PAST %s SAMPLES",flowrates(j),out_of_range)
flowrate_warning_message = sprintf('PUMP %s IS OUT OF +- 10%% RANGE FOR THE PAST %d SAMPLES\n',pump_list{j}, out_of_range(j));
out_of_range(j) = 0;
end
end
if isempty(flowrate_warning_message)
set(flowrate_warning_text, 'string', ' ');
set(flowrate_warning_text, 'string', flowrate_warning_message);
end
%Pressure +/-10% check
pressure_warning_message = ' ';
for j= 1:length(pressure_list)
lower_bound = pressure_rate_list(j) * 0.9;
upper_bound = pressure_rate_list(j) * 1.1;
if pressures(j)<lower_bound || pressures(j)>upper_bound
pressure_warning_message = sprintf('PRESSURE SENSOR %s IS OUT OF +- 10%% RANGE FOR THE PAST %d SAMPLES\n',pressure_list{j}, out_of_range(j));
end
end
if isempty(pressure_warning_message)
set(pressure_warning_text, 'string', ' ');
set(pressure_warning_text, 'string', pressure_warning_message);
end
%Temperature +/-10% check
temp_warning_message = ' ';
for j= 1:length(temp_list)
lower_bound = temp_rate_list(j) * 0.9;
upper_bound = temp_rate_list(j) * 1.1;
if temperatures(j)<lower_bound || temperatures(j)>upper_bound
temp_warning_message = sprintf('TEMPERATURE SENSOR %s IS OUT OF +- 10%% RANGE FOR THE PAST %d SAMPLES\n',temp_list{j}, out_of_range(j));
end
end
if isempty(temp_warning_message)
set(temp_warning_text, 'string', ' ');
set(temp_warning_text, 'string', temp_warning_message);
end
% Update animated lines for Flowrates
Exp_Flow_Lines = [PumpA,PumpB,PumpC,PumpD,PumpE,PumpF];
Average_Flow_lines = [PumpA_Avg,PumpB_Avg,PumpC_Avg,PumpD_Avg,PumpE_Avg,PumpF_Avg];
%overall flowrate
for j = 1:length(pump_letters)
if ismember(pump_letters(j), pump_list)
pump_index = find(strcmp(pump_list, pump_letters(j)));
if ~isempty(pump_index)
addpoints(Exp_Flow_Lines(j), i, flowrates(j));
addpoints(Exp_Flow_Lines(j), i, 0);
end
addpoints(Exp_Flow_Lines(j),i,0)
end
end
%Average flowrate
if i >= 5
rolling_flowrate_averages = zeros(1, length(pump_letters));
rolling_flowrate_averages(j) = mean(flowrate_archives(max(1, i-4):i,j));
end
addpoints(Average_Flow_lines(j), i, rolling_flowrate_averages(j));
addpoints(Average_Flow_lines(j), i, 0);
end
end
end
%Update Animated Lines for Temperature
Exp_temp_lines = [temp_1,temp_2,temp_3,temp_4,temp_5];
Avg_temp_lines = [temp_1_avg,temp_2_avg,temp_3_avg,temp_4_avg,temp_5_avg];
%Overall temperature
for j = 1:length(temp_numbers)
if ismember(temp_numbers(j), temp_list)
temp_index = find(strcmp(temp_list, temp_numbers(j)));
if ~isempty(temp_index)
addpoints(Exp_temp_lines(j), i, temperatures(j));
addpoints(Exp_temp_lines(j), i, 0);
end
addpoints(Exp_temp_lines(j),i,0)
end
end
%Average temperature
if i >= 5
rolling_temperature_averages = zeros(1, length(temp_numbers));
rolling_temperature_averages(j) = mean(temperature_archives(max(1, i-4):i,j));
end
addpoints(Avg_temp_lines(j), i, rolling_temperature_averages(j));
addpoints(Avg_temp_lines(j), i, 0);
end
end
end
Exp_pressure_lines = [pressure_1,pressure_2,pressure_3,pressure_4,pressure_5];
Avg_pressure_lines = [pressure_1_avg,pressure_2_avg,pressure_3_avg,pressure_4_avg,pressure_5_avg];
%overall pressure
for j = 1:length(pressure_letters)
if ismember(pressure_letters(j), pressure_list)
pressure_index = find(strcmp(pressure_list, pressure_letters(j)));
if ~isempty(pressure_index)
addpoints(Exp_pressure_lines(j), i, pressures(j));
addpoints(Exp_pressure_lines(j), i, 0);
end
addpoints(Exp_pressure_lines(j),i,0);
end
end
%Average pressure
if i >= 5
rolling_pressure_averages = zeros(1, length(pressure_letters));
rolling_pressure_averages(j) = mean(pressure_archives(max(1, i-4):i,j));
end
addpoints(Avg_pressure_lines(j), i, rolling_pressure_averages(j));
addpoints(Avg_pressure_lines(j), i, 0);
end
end
end
% Draw updates
drawnow;
%Pause for 1 second between updates
pause(1);
% X axis for flow rate
if i > 180
set(Average_Flow_lines(j).Parent, 'XLim', [i-180, i]);
end
set(Average_Flow_lines(j).Parent, 'XLim', [0, max(1, i)]);
end
end
% X axis for pressure
if i > 180
set(Avg_pressure_lines(j).Parent, 'XLim', [i-180, i]);
end
set(Avg_pressure_lines(j).Parent, 'XLim', [0, max(1, i)]);
end
end
%x axis for temp
if i > 180
set(Avg_temp_lines(j).Parent, 'XLim', [i-180, i]);
end
set(Avg_temp_lines(j).Parent, 'XLim', [0, max(1, i)]);
end
end
%Current Values for flowrate
set(Pump_A_Legend,'String', sprintf('Pump A (Black): %.4g', flowrate_archives(i,1)));
set(Pump_B_Legend,'String', sprintf('Pump B (Red): %.4g',flowrate_archives(i,2)));
set(Pump_C_Legend,'String', sprintf('Pump C (Yellow): %.4g',flowrate_archives(i,3)));
set(Pump_D_Legend,'String', sprintf('Pump D (Green): %.4g',flowrate_archives(i,4)));
set(Pump_E_Legend,'String', sprintf('Pump E (Blue): %.4g',flowrate_archives(i,5)));
set(Pump_F_Legend,'String', sprintf('Pump F (Pink): %.4g',flowrate_archives(i,6)));
%current values for presure
set(Pressure_A_Legend,'String', sprintf('Pump A (Black): %.4g', pressure_archives(i,1)));
set(Pressure_B_Legend,'String', sprintf('Pump B (Red): %.4g',pressure_archives(i,2)));
set(Pressure_C_Legend,'String', sprintf('Pump C (Yellow): %.4g',pressure_archives(i,3)));
set(Pressure_D_Legend,'String', sprintf('Pump D (Green): %.4g',pressure_archives(i,4)));
set(Pressure_E_Legend,'String', sprintf('Pump E (Blue): %.4g',pressure_archives(i,5)));
%current values for temperature
set(Temp_A_Legend,'String', sprintf('Pump A (Black): %.4g', temperature_archives(i,1)));
set(Temp_B_Legend,'String', sprintf('Pump B (Red): %.4g',temperature_archives(i,2)));
set(Temp_C_Legend,'String', sprintf('Pump C (Yellow): %.4g',temperature_archives(i,3)));
set(Temp_D_Legend,'String', sprintf('Pump D (Green): %.4g',temperature_archives(i,4)));
set(Temp_E_Legend,'String', sprintf('Pump E (Blue): %.4g',temperature_archives(i,5)));
elapsedTime = toc(startTime);
% Convert elapsed time to hours, minutes, and seconds
hours = floor(elapsedTime / 3600);
minutes = floor(mod(elapsedTime, 3600) / 60);
seconds = floor(mod(elapsedTime, 60));
% Format the time as a string
time2String = sprintf('%d:%02d:%02d', hours, minutes, seconds);
% Update text display
set(TimerText, 'String', time2String);
set(pressureTimer, 'String', time2String);
set(tempTimer, 'String', time2String);
drawnow; % Force update of the display
% Pause for the update interval
i = i+1;
end
