Anemometer sensor 5v
Hi. Today, instead of build anemometer sensor from beginning is easier to just buy a ready to go sensor and exist many tutorials with ready codes.
I want to run to minimal battery cells what I can, because of space. I have a lot of 18650 and AAA batteries.
And I want to use a small NANO board.
I found that more on the market sensors have input voltage 10-30v. But I found some videos where I can buy 5V input sensor and connect LCD/OLED and Arduino to 5v, that will be like 2x18650 enough?
Also, not sure is the 5-30v input sensors rare on Ali (hard to find), or it is mistake in manual, maybe they mean output 5v, not input :-/ But
in this video you can see in hands 5-30v label on device.
In one video says that the default sensor 10-30v tested on Arduino 5v and it works.. that means maybe all of them can?
https://a.aliexpress.com/_EI0YKqW
https://a.aliexpress.com/_EwpJELs
Any particular Nano board? There are many types.
Your image shows a Nano V3 (Atmega328) which is not a good choice for this circuit because it is 5V and does not have a low minimum consumption.
No, it means that they were lucky. You might not be.
2S would give you 7.4V nominal voltage, good for arduino VIN.
Also, why would you power the sensor from arduino 5V, since you can power it directly from battery at higher voltage?
Does your sensor have analog or pulse output?
For low power, look for an anemometer sensor that uses a reed switch. The only power loss is the resistance of the connecting wires!
I have used this type before. They are very low power, and can use any voltage, since they contain only a reed switch.
https://www.ebay.co.uk/itm/205439001901
Unfortunately they are much more costly now than when I last purchased one, almost 8 times higher price, and I don't think the quality justifies that price.
If I were to buy a new anemometer now, I might choose one like this:
https://www.ebay.co.uk/itm/275308956788
It's not clear from the seller's description, but I think this type generates a voltage proportional to the wind speed, and so draws no power from the battery.
This Nano, I have several of those.
It is not my final sketch. It is SS from video... I can power ot from battery, yes.
Didn't bough sensor yet. I think it will be "Pulse".
Yes on Ali white are cheaper and I like color, but in descriptions I found it says it working only to our weather station and not guaranty that will work on others...
Then I am for the black color, with silver label in the middle. Many videos exist.
Don't forget that you need to convert turns per minute into wind speed. Do you have the calculation to do that for your particular anemometer?
In this video show code for 70m/s.
And there are more others pages.
So, is this will work ?
https://a.aliexpress.com/_EQsgwkw
Why shouldn't it?
If 5-30V sensor doesn't work with 7.4V, they get lot of returns..
No manufacturer will claim that their sensor works with a weather station that you are designing, building and coding yourself. That would be crazy.
They want to avoid customers trying to use their sensors with weather stations produced by other sellers, with which they might not be compatible. You are designing your own weather station. You can design it to work with any sensor you want, provided you can understand how the sensor actually works.
Don't be shallow. The exterior colour of a sensor tells you nothing about how it works internally. That is what is important.
Sure it will work. But it will not work at very low wind speed. Since it is a motor/generator, It cannot turn at very low speeds. A unit using a reed switch will indicate very close to zero wind speed. Beware of hail storms. One of the arms broke off of my plastic rotor. Repaired with a steel pin and supper glue.
The instructions should also include methods to calibrate to device.
Mmmm... sounds delicious!
By the way @danyCro , how is your IR-illuminator case going? After 300+ posts and hours of time people here helping you, you could update the topic perhaps?
What is analog and what is pulse?
In the video showing sensor NPNR and said that is "analog", but on their page in title is "pulse", I confused.
About which wind speed we're talking?
In the video show minimum 0.09m/s, that is very slow wind.
No problem for that. I'm printing in 3D all what I need.
Analog outputs a voltage according to wing speed which you read by ADC (analog input).
NPN gives a tiny digital pulse that you read with digital input counting the time between pulses to get the speed.
The wind speed is creating a DC voltage. What is the lowest voltage your program can measure?
Are you using plastic that is NOT affected by UV from the sun?
Than'ks for your brief update on that topic.
Be aware we are not AI bots here. Many of us gave several hours of full intention to try to help you, just for good will....
Don't know, still we don't know would be measure pulses or what. Didn't download code yet.
Mine two anemos which I'm looking have
Accuracy 0.3m/s, and second have 0.m/s.
On video, I noticed that one have Wind speed: 1.75m/s=20 pulses per second
Pulses per rotation: 20. That characteristics don't see on Ali anemo devices. It seems that is different for each device.
No, I use ABS, but if and when the sun destroy it, print another one.
