Hello,
I am gingerly taking my first steps into the world of Arduino and programming in general.
I am using an Arduino UNO R3 board with an Adafruit Datalogger shield to try and set up some simple data recording of temperatures.
I have used the MAX 6675 thermocouple interface to read the temperature from a K-Type thermocouple using the examples in the respective library with success. I have also managed to get the datalogger to work in isolation using the example sketch in the Arduino IDE.
I have tried to incorporate the two separate sketches so that I can record data from the thermocouple to the SD card. I have attended to some PIN conflicts and can get the program to run on the UNO but I just get a "zero" temperature print out from the MAX 6675 chip. I suspect the problem is to do with SPI conflicts. I have had a play around with the chip select high a low to try and remedy and double checked the electrical wiring but I am not all out of ideas. Any assistance appreciated.
Code is posted below - it is my first attempt at pulling my own sketch together so it is probably not very pretty to the experienced user. Any tips appreciated.
Kind Regards
Ian
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
#include <MAX6675.h>
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL 1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 5000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 1 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 4
#define greenLEDpin 3
// The analog pins that connect to the sensors
#define photocellPin 0 // analog 0
#define tempPin 1 // analog 1
#define BANDGAPREF 14 // special indicator that we want to measure the bandgap
#define aref_voltage 3.3 // we tie 3.3V to ARef and measure it with a multimeter!
#define bandgap_voltage 1.1 // this is not super guaranteed but its not -too- off
// The MAX 6675 PIN definitions
int LED1 = 5; // Status LED Pin
int CS = 9; // CS pin on MAX6675
int SO = 12; // SO pin of MAX6675
int MAX_SCK = 13; // SCK pin of MAX6675
int units = 1; // Units to readout temp (0 = raw, 1 = ˚C, 2 = ˚F)
float temperature = 0.0; // Temperature output variable
RTC_DS1307 RTC; // define the Real Time Clock object
const int sdChipSelect = 10; // for the data logging shield, we use digital pin 10 for the SD cs line
File logfile; // the logging file
MAX6675 temp(CS,SO,MAX_SCK,units); // Initialize the MAX6675 Library for our chip
void error(char *str)
Serial.print("error: ");
Serial.println(str);
digitalWrite(redLEDpin, HIGH); // red LED indicates error
while(1);
void setup(void)
// use debugging LEDs
pinMode(redLEDpin, OUTPUT);
pinMode(greenLEDpin, OUTPUT);
pinMode(LED1, OUTPUT);
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(sdChipSelect, OUTPUT);
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// see if the card is present and can be initialized:
if (!SD.begin(sdChipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,stamp,datetime,light,temp,vcc,t-couple");
#if ECHO_TO_SERIAL
Serial.println("millis,stamp,datetime,light,temp,vcc,t-couple");
// If you want to set the aref to something other than 5v
analogReference(EXTERNAL);
void loop(void)
DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
now = RTC.now(); // fetch the time
// log time
logfile.print(now.unixtime()); // seconds since 1/1/1970
logfile.print('"');
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
logfile.print('"');
#if ECHO_TO_SERIAL
Serial.print(now.unixtime()); // seconds since 1/1/1970
Serial.print(", ");
Serial.print('"');
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
Serial.print('"');
// Read Analogue pins
analogRead(photocellPin);
delay(10);
int photocellReading = analogRead(photocellPin);
analogRead(tempPin);
delay(10);
int tempReading = analogRead(tempPin);
// converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
float voltage = tempReading * aref_voltage / 1024;
float temperatureC = (voltage - 0.5) * 100 ;
float temperatureF = (temperatureC * 9 / 5) + 32;
// Read the temp from the MAX6675
digitalWrite(sdChipSelect, LOW);
temperature = temp.read_temp();
digitalWrite(LED1, HIGH);
digitalWrite(LED1, LOW);
if(temperature < 0) {
// If there is an error with the TC, temperature will be < 0
Serial.print("Thermocouple Error on CS");
Serial.println( temperature );
logfile.print(photocellReading);
logfile.print(temperatureF);
logfile.print(temperature);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(photocellReading);
Serial.print(", ");
Serial.print(temperatureF);
Serial.print(", ");
Serial.print(temperature);
// Log the estimated 'VCC' voltage by measuring the internal 1.1v ref
analogRead(BANDGAPREF);
delay(10);
int refReading = analogRead(BANDGAPREF);
float supplyvoltage = (bandgap_voltage * 1024) / refReading;
logfile.print(supplyvoltage);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(supplyvoltage);
#endif // ECHO_TO_SERIAL
logfile.println();
#if ECHO_TO_SERIAL
digitalWrite(greenLEDpin, LOW);
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
digitalWrite(redLEDpin, LOW);
