I have a rtc with four 7 segment display driven by max7219 using the LedControl lib
is there any way to blink the any of the two digits ( either hours or minutes ) with out loosing the display data continuously?
this is need when i want to adjust the time, to know what i am adjusting (hours or minutes)
Bellow is my code, i want to add few buttons so that i can change the date and time (not at written),
#include <TimerOne.h>
#include <Time.h>
#include <DS3232RTC.h>
#include <LedControl.h>
#include <Button.h>
#define DEBUG_LED 13
* Now we create a new LedControl.
* We use pins 12,11 and 10 on the Arduino for the SPI interface
* Pin 12 is connected to the DATA IN-pin of the first MAX7221
* Pin 11 is connected to the CLK-pin of the first MAX7221
* Pin 10 is connected to the LOAD(/CS)-pin of the first MAX7221
* There will only be a single MAX7221 attached to the arduino
LedControl lc=LedControl(12,11,10,1);
tmElements_t datetime;
void setup(){
pinMode(DEBUG_LED, OUTPUT); digitalWrite(DEBUG_LED, HIGH);
delay(100);
lc.shutdown(0,false);
lc.setIntensity(0,5);
lc.clearDisplay(0);
// datetime.Hour = 12;
// datetime.Minute = 01;
// datetime.Second = 10;
// datetime.Day = 24;
// datetime.Month = 04;
// datetime.Year = 2016 - 1970;
// RTC.write(datetime);
RTC.squareWave(SQWAVE_1_HZ); //1 Hz square wave
unsigned long previousMillis = 0;
const long rtcDisplayInterval = 1000;
void loop(){
if(currentMillis - previousMillis >= rtcDisplayInterval || previousMillis == 0){
display_time();
digitalWrite(DEBUG_LED, !digitalRead(DEBUG_LED));
void display_time(){
RTC.read(datetime);
print2Digit(datetime.Hour, 0, 1);
print2Digit(datetime.Minute, 2, 3);
void print2Digit(int v, int a, int b) {
lc.setDigit(0, b, (v%10), false);
lc.setDigit(0, a, ((v/10)%10), false);
void print4Digit(int v) {
lc.setDigit(0,3, (v%10), false);
lc.setDigit(0,2, ((v/10)%10), false);
lc.setDigit(0,1, ((v/100)%10), false);
lc.setDigit(0,0, ((v/1000)%10), false);
