Hi everybody,
I have an arduino code that enables me to send 3-byte MIDI messages (MIDI channel, MIDI note number, Velocity) from Max/MSP to arduino over the serial port. Just to make sure I seperate the MIDI messages with a carriage return (13). This basically works like expected and fine.
However, when closing the Max [serial] and opening it again, I ALWAYS get a wrong result the first time. Assuming I close and re-open [serial] and then send it a message like [144, 66, 66, 13] I will get a result like [254, 254, 144]. Sending the same message a second time outputs the correct result.
I really don't understand that. Does anybody have a clue why it behaves like that?
I also tested it with Pure data and got the same result.
Below the arduino code with the simple Max patch.
I currently work under Windows XP with Max 5 and Arduino 1.0.1.
Thanks a lot for your time and help!
byte buffer[] = {1, 2, 3}; // Serial Input-Buffer containing our 3-byte MIDI messages
byte SerialData = 0;
byte index;void setup(){
Serial.begin(57600); }void loop(){/* empty */}
void serialEvent(){
SerialData = Serial.read();
buffer[index] = SerialData;
index++;
if(SerialData == 13) // Just to make sure we send a carriage return after each MIDI message
evalSerialData();
}void evalSerialData(){
Serial.write(buffer[0]);
Serial.write(buffer[1]);
Serial.write(buffer[2]);buffer[0] = 0; buffer[1] = 0; buffer[2] = 0;
index = 0;}
----------begin_max5_patcher----------
727.3ocwW0yaaCCDc1AH+GNnYWCQpu6VQ6PyPlR2BBJnkNayBIRCIpJmFz+6
kjRxw1Io9K4jA6y9HEuGeu6HO8z0WMxYpbEV4.eFtGFM5IsmQVeFOi5cLxof
sJMmUYmnSprn.EJmwcCpvUJ6.eMWVg.SjAxkn.pvRNKGjS+ElprtaXpzE.Th
U04JfKfaYq.EVVvEr70qWNWfoxZgcQo8dE05YkiJKFH8dmIEpJ9ePqS5D2d+
KMQhKl+yRcra2djjP83.Ip0j3ZLd9SbgG1HFxZUePb2LHBVgMHNewroViUdl
0odO9IB0w57uWekwpMiOeJ8GK3Ufcy.r7bYSEnjZhUykEXUEaNVAyJkEsDoD
XkY0bgbB7cYC9arbLjp0DMOrVUL+Vs.2QbZ344PJqVKepELkcFy3kJc33EHz
fvRsnUAx5R31a91M8Q2Lh8YmiZEFZJk5kuSdumF3OFreQ78eXxqqu9aRxyXo
3Vx6YK5w9FUlFa0ZRjwDRGNI28BH42YT2sH4mEVmAiXnjDaY.0qsnvRMT2Ai
ZRNclQfM5U3kDSWJKBAQgttCGUPhBra9DhwDGtOlX8QRs9TOtDaWHGtQOAGm
mexCLOZ3IqkkZv.2gaExghp77ZOCkDOvYMmwQncEKujIzG9nK5Ca+P7dcxfd
JjQ64I8kPtsl32lLHuYhyQmw3M7YLJXJLjoJcrSf0DEe5UUSYh4mTYk+vSRY
XN6QsVeLMqbN4Vw1So8I6qWEx+m8NVlK3BTGZ5DAGtpOJs8JKhka7idGK9Bu
.rio2rAjbRnaPNdumjSztjS6BXKT18EMrH2LvNTVktOyzdDzdA4XXCvmgUJ8
qLn3RwFSht8jVvyxPwVWBUvyVJ02K1gC3g2VGOXn4qiJYePi7g.sfCg0NZnQ
ngSBLM1aMDcG18+aP.c3EAzTuNPmrEnSFHP6cHf1+CK+buPK3CAZQWDo1ykb
nRswg17OwTd2t.
-----------end_max5_patcher-----------*/
