There are no links to the used hardware, no sketch you're using for these tests and no links to the libraries you might have used. There is also no wiring diagram of how you connected everything together.
How do you measure the resolution?
I am using arduino Uno with ADC MAX31865 (from http://www.playingwithfusion.com), with a Arduino wireless SD Shield and my LCD is a 4D system 32WPTU.
The ADC and SD card use SPI comunication and the LCD use I2C.
The resolution I am reading in LCD. without SD Shield the value of temperature changes 0.03ºC (20.00 to 20.03 or 19.97ºC), when a connect it changes to 0.06ºC (20.00 to 20.06 or 19.94ºC)
The code I am using is from the library.
/* Arduino Uno --> SEN-30201
* CS: pin 2 --> CS
* MOSI: pin 11 --> SDI (must not be changed for hardware SPI)
* MISO: pin 12 --> SDO (must not be changed for hardware SPI)
* SCK: pin 13 --> SCLK (must not be changed for hardware SPI)
* GND --> GND
* 5V --> Vin (supply with same voltage as Arduino I/O, 5V)
// the sensor communicates using SPI, so include the hardware SPI library:
#include <SPI.h>
// include Playing With Fusion MAX31865 libraries
#include <PlayingWithFusion_MAX31865.h> // core library
#include <PlayingWithFusion_MAX31865_STRUCT.h> // struct library
#include <SD.h>
#include <elapsedMillis.h>
#include <Time.h>
//#include <TimeAlarms.h>
#include <genieArduino.h>
//Sensor addresses:
const byte CONFIG_REG_W = 0x80; // Config register write addr
const byte CONFIG_VALUE = 0xC3; // Config register value (Vbias+Auto+FaultClear+50Hz, see pg 12 of datasheet)
const byte ADC_WORD_MSB = 0x00; // Addr of first byte of data (start reading at RTD MSB)
const byte ADC_FAULT_REG = 0x07; // Addr of the fault reg
// CS pin used for the connection with the sensor
// other connections are controlled by the SPI library)
const int CS_PIN = 2;
const int chipSelect = 4;
double Temp_PT1;
unsigned int interval = 1000;
time_t t = now();
int hours = 17;
int minutes = 47;
int seconds = 0;
int days = 22;
int months = 4;
int years = 2014;
elapsedMillis timeElapsed; //declare global if you don't want it reset every time loop runs
PWFusion_MAX31865_RTD rtd_ch0(CS_PIN);
//Serial.begin(9600);
// setup for the the SPI library:
SPI.begin(); // begin SPI
SPI.setDataMode(SPI_MODE3); // MAX31865 is a Mode 3 device
// initalize the chip select pin
pinMode(CS_PIN, OUTPUT);
rtd_ch0.MAX31865_config();
SPI.setClockDivider(SPI_CLOCK_DIV2);
//Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
SD.begin(chipSelect);// {
//Serial.println("Card failed, or not present"); Display
// don't do anything more:
// return;}
setTime(hours, minutes, seconds, days, months, years);
genieBegin (GENIE_SERIAL,9600); //Serial0
genieAttachEventHandler(myGenieEventHandler);
genieWriteContrast(1); // 1 = Display ON, 0 = Display OFF
delay(100);
Did the change really happen, when you connected the Wireless SD shield? Or did it change when you changed the code to access the SD card?
BTW: the sketch is not complete, please add the loop() routine. The SD card is a mode 0 device so you might have to switch between the modes for each access. Many cards may also have problems with the increased bus speed of 8MHz.
genieDoEvents();
temp_sensor();
DataLogging();
void DataLogging()
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
char datalog[ ] = "probe.txt";
File dataFile = SD.open(datalog, FILE_WRITE);
if (timeElapsed > interval)
// if the file is available, write to it:
if (dataFile) {
dataFile.print(hour());dataFile.print(":");dataFile.print(minute());dataFile.print(":");dataFile.print(second());dataFile.print(" ");
dataFile.print(day());dataFile.print("/");dataFile.print(month());dataFile.print("/");dataFile.print(year());dataFile.print(" ");
dataFile.print("S1: ");dataFile.println(Temp_PT1);
dataFile.close();
// if the file isn't open, pop up an error:
else {
//dataFile.println("error opening datalog.txt"); Enviar para display
timeElapsed = 0; // reset the counter to 0 so the counting starts over...
dataFile.close();
void temp_sensor()
static struct var_max31865 RTD_CH0;
double tmp;
RTD_CH0.RTD_type = 1; // un-comment for PT100 RTD
struct var_max31865 *rtd_ptr;
rtd_ptr = &RTD_CH0;
rtd_ch0.MAX31865_full_read(rtd_ptr); // Update MAX31855 readings
if(0 == RTD_CH0.status) // no fault, print info to serial port
if(1 == RTD_CH0.RTD_type) // handle values for PT100
// calculate RTD resistance
tmp = (double)RTD_CH0.rtd_res_raw * 400 / 32768;
// calculate RTD temperature (simple calc, +/- 2 deg C from -100C to 100C)
// more accurate curve can be used outside that range
tmp = ((double)RTD_CH0.rtd_res_raw / 16) - 256;
Temp_PT1 = tmp;
tmp = tmp*100;
int Temp = tmp;
//if (tmp > 0){
genieWriteObject(GENIE_OBJ_LED_DIGITS, 0x00,(Temp));
delay(100);
} // end of no-fault handling
File dataFile = SD.open("probe1.txt", FILE_WRITE);
if (dataFile) {
dataFile.print("RTD Fault, register: ");
dataFile.print(RTD_CH0.status);
dataFile.print(" - ");
if(0x80 & RTD_CH0.status){
dataFile.println("RTD High Threshold Met");} // RTD high threshold fault
else if(0x40 & RTD_CH0.status){
dataFile.println("RTD Low Threshold Met");} // RTD low threshold fault
else if(0x20 & RTD_CH0.status){
dataFile.println("REFin- > 0.85 x Vbias");} // REFin- > 0.85 x Vbias
else if(0x10 & RTD_CH0.status){
dataFile.println("FORCE- open");} // REFin- < 0.85 x Vbias, FORCE- open
else if(0x08 & RTD_CH0.status){
dataFile.println("FORCE- open");} // RTDin- < 0.85 x Vbias, FORCE- open
else if(0x04 & RTD_CH0.status){
dataFile.println("Over/Under voltage fault");} // overvoltage/undervoltage fault
else{
dataFile.println("Unknown fault, check connection");} // print RTD temperature heading
dataFile.close();}
// end of fault handling
dataFile.close();}
void myGenieEventHandler(void) //Keyboard function
genieFrame Event;
genieDequeueEvent(&Event);
The MAX31865 is a mode 0 or mode 3 device and sets it's internal mode automatically when you pull the CS pin low. After that you probably get correct results again.
void DataLogging()
if (dataFile) {
//dataFile.print(hour());dataFile.print(":");dataFile.print(minute());dataFile.print(":");dataFile.print(second());dataFile.print(" ");
//dataFile.print(day());dataFile.print("/");dataFile.print(month());dataFile.print("/");dataFile.print(year());dataFile.print(" ");
dataFile.print(F("S1: "));dataFile.println(F(Temp_PT1));
dataFile.close();
else {
dataFile.close();
Is TempPT1 a string constant? Please use the F() macro only with string constants. It's used to read these strings directly from the flash without making a copy in the RAM, so you save a lot of RAM.
Can you do a measurement series with different temperatures (ice water, boiling water, etc.) also writing out the raw read value (RTD_CH0.rtd_res_raw) and posting the results?
What I think is very interesting:
The resolution of that calculation has always a resolution of 0.06. That means the wrong result was when you got a 0.03 resolution.
The ADC is 16 bits, this means the resolution is 0.03.
When I istalled the uSD card, the values from ADC changed, and I saw if I divided the raw value by 2, the values are corret. But I losses resolution 8)
That's from the datasheet page 1:
15-Bit ADC Resolution
But anyway, with the calculation you have in your sketch, the resolution is 0.06. If you use another sketch, why didn't you post it? Is the calculation in my previous post wrong? If that is correct the resolution is 0.06° because the source value is an integer and you divide by 16 you cannot get a resolution finer than 0.06.
The lowest bit of the two result bytes is the fault bit, that doesn't add to the resolution.
I change this, and installed in arduino. I am trying using PID, without LCD. the output is:
RTD Sensor Trtd = 18.50 deg C
RTD Sensor Trtd = 18.47 deg C
* CS: pin 4 --> CS
* GND --> GND
#include <SPI.h>
#include <PID_v1.h>
#define RelayPin 6
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
int WindowSize = 5000;
unsigned long windowStartTime;
//Sensor addresses:
const byte ADC_WORD_MSB = 0x01; // Addr of first byte of data (start reading at RTD MSB)
const int CS_PIN = 4;
// give the sensor time to set up
delay(100);
windowStartTime = millis();
//initialize the variables we're linked to
Setpoint = 40;
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
//turn the PID on
myPID.SetMode(AUTOMATIC);
temp_sensor();
myPID.Compute();
* turn the output pin on/off based on pid output
if(millis() - windowStartTime>WindowSize)
{ //time to shift the Relay Window
windowStartTime += WindowSize;
if(Output < millis() - windowStartTime) digitalWrite(RelayPin,HIGH);
else digitalWrite(RelayPin,LOW);
void temp_sensor()
double tmp;
rtd_ptr = &RTD_CH0;
// Print information to serial port
Serial.print("RTD Sensor "); // Print RTD0 header
tmp = ((double)RTD_CH0.rtd_res_raw / 32) - 256;
Input = tmp;
Serial.print("Trtd = "); // print RTD temperature heading
Serial.print(tmp);
Serial.println(" deg C"); // print RTD temperature heading
Serial.print("RTD Fault, register: ");
Serial.print(RTD_CH0.status);
Serial.print(" - ");
Serial.println("RTD High Threshold Met"); // RTD high threshold fault
Serial.println("RTD Low Threshold Met"); // RTD low threshold fault
Serial.println("REFin- > 0.85 x Vbias"); // REFin- > 0.85 x Vbias
Serial.println("FORCE- open"); // REFin- < 0.85 x Vbias, FORCE- open
Serial.println("FORCE- open"); // RTDin- < 0.85 x Vbias, FORCE- open
Serial.println("Over/Under voltage fault"); // overvoltage/undervoltage fault
Serial.println("Unknown fault, check connection"); // print RTD temperature heading
} // end of fault handling
Have you tried with the SD card using the same code? If you change the calculation method between the two configuration it cannot return the same results.
