MAX485 Module RO pin is not working other then pin 10 or 11 on Arduino mega
Hi to everyone,
What I want to do, in the simplest way is as ,
I have multiple arduinos mega joined with MAX485 module in serial.
I have joined Arduino + MAX485 + other parts needed on a single pcb.
On every arduino there is a led connected to pin 12 .
I am sending via serial port “002R011H” or “002R011L” data using RS485 protocol from my computer.
When the Max485 module connected to Arduino mega 2560 receives data, if it is “002R011H” , the led connected to pin 12 turns on.
If the data received is “002R011L“ the led connected to pin 12 turns off.
This works fine with the following sketch.
#include <SoftwareSerial.h>     // Using software serial library
#define SerialRX        10      // Serial Receive pin  (RO)  (A1 10 55) Is working only on 10 or 11 pins .
                                //  But I want to use it on A1   and don't work
#define SerialTX        A0      // Serial Transmit pin (DI)  (A0 or 11 or 54)
#define SerialTxControl A2      // RS485 Direction control  //(DE & RE) pin to pin A2 or 9 or 56
#define RS485Transmit   HIGH    // to open direction of MAX485 module
#define RS485Receive    LOW     // to close direction of MAX485 module
SoftwareSerial RS485Serial(SerialRX, SerialTX); // RS485 connection parameters
// Starting Declaration of Leds names and pins
const int ledR011  = 12  ;     // the number of the LED pin
// Finish Declaration of Leds pins
 pinMode(SerialTxControl, OUTPUT);           // SSerialTxControl as output
 pinMode(SerialRX,INPUT) ;                   // SerialRX as input
// Starting   PinMode state
  pinMode(ledR011, OUTPUT);                   // ledR011 as output
digitalWrite(SerialTxControl, RS485Receive);  // RS485 SerialTxControl is in receive mode
RS485Serial.begin(9600);                      // RS485Serial start in 9600 baudrate
Serial.begin(9600);                           // Serial start in 9600 baudrate
String x = "";                                // String x is the incoming data and is reseted to begin
if (RS485Serial.available())                  // Controlling if RS485Serial is available
    x = RS485Serial.readString();             //incoming data is equal to string x
    RS485Serial.flush();                      //waiting to receive all incoming data
    RS485Serial.setTimeout(25);               // waiting a while before going to next step
if ( x == "002R011H" )                        // If incoming data is equal to 002R011H
          digitalWrite(ledR011 , HIGH);       // ledR011 is on
if ( x == "002R011L" )                        // If incoming data is equal to 002R011H
          digitalWrite(ledR011 , LOW);       // ledR011 is off
However, if I try to use the SerialRX (RO) connection with a pin other than pins 10 or 11, is not working.
Normally I can use pins 10 or 11, but using pin A1 is more suitable for my pcb design.
Am I missing something for use the pin A1, or should I use pins 10 or 11 to use the MAX485 module ?
Thanks in advance.
Using SoftwareSerial on an Arduino Mega2560 is quite stupid. That board has 4 (in words: four) hardware serial interfaces, so there is no need to use a rather crippled software emulation.
You can use any digital IO that supports pin change interrupts (if you us a more or less current IDE version) for the SoftwareSerial read pin. On the Mega2560 the A1 pin doesn't support pin change interrupts so it cannot be used.
