Hej,
I am pretty new to the Arduino and am planing my first own project.
I want to make a BIG led cube in size and not in numbers of rows and columns and z-things. (4x4x4 but with more LEDs per element. In fact I want to make a ring of LEDs so that I have 64 rings with several LEDs each in the end.) It should be as brigth as possible for less money as possible. ![]()
I was thinking about using the MAX7219 but I am unhappy with the fact that it uses multiplexing and since it is for a 8x8 matrix it takes 7/8 of the ligt away. Right? I figured I could give the LEDs more current since they are not constantly on but at the most I could make them twice as bright as they normaly are in which case I would still loose 3/4 of the light ... and I dont want to solder hundreds of LEDs only because of multiplexing. ![]()
So ist there a way to circumvent the multiplexing part? Something like the MAX7219 but instead of 2x8 pins with 64 pins.
I would be happy if someone can give me a hint, clue, suggestion, ...
Cheers
Erik
