I have connected my CLK to pin 13, my CS to pin 10, DIN to 11
// Program to exercise the MD_Parola library
// Demonstrates most of the functions of the Parola library.
// All animations can be run and tested under user control.
// Speed for the display is controlled by a pot on SPEED_IN analog input.
// Digital switches used for control of Justification, Effect progression,
// Pause between animations, LED intensity, Display flip, and invert mode.
// UI switches are normally HIGH.
// UISwitch library can be found at https://github.com/MajicDesigns/MD_UISwitch
// NOTE: MD_MAX72xx library must be installed and configured for the LED
// matrix type being used. Refer documentation included in the MD_MAX72xx
// library or see this link:
// https://majicdesigns.github.io/MD_MAX72XX/page_hardware.html
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include <MD_UISwitch.h>
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define MAX_DEVICES 4
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
// HARDWARE SPI
MD_Parola P = MD_Parola(CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
// Turn on debug statements to the serial output
#define DEBUG_ENABLE 1
#if DEBUG_ENABLE
#define DEBUG(s, x) { Serial.print(F(s)); Serial.print(x); }
#define DEBUGS(x) Serial.print(F(x))
#define DEBUGX(x) Serial.println(x, HEX)
#else
#define DEBUG(s, x)
#define DEBUGS(x)
#define DEBUGX(x)
#endif
// User interface pin and switch definitions
const uint8_t SPEED_IN = A5; // control the speed with an external pot
const uint8_t PAUSE_SET = 4; // toggle pause time
const uint8_t FLIP_SET = 5; // toggle flip status
const uint8_t JUSTIFY_SET = 6; // change the justification
const uint8_t INTENSITY_SET = 7; // change the intensity of the display
const uint8_t EFFECT_SET = 8; // change the effect
const uint8_t INVERSE_SET = 9; // set/reset the display to inverse
uint8_t uiPins[] = { PAUSE_SET, FLIP_SET, JUSTIFY_SET, INTENSITY_SET, EFFECT_SET, INVERSE_SET };
const uint16_t PAUSE_TIME = 1000; // in milliseconds
const uint8_t SPEED_DEADBAND = 5; // in analog units
// Global variables
uint8_t curString = 0;
const char *msg[] =
"Parola for",
"Arduino",
"LED Matrix",
"Display"
#define NEXT_STRING ((curString + 1) % ARRAY_SIZE(msg))
MD_UISwitch_Digital uiSwitches(uiPins, ARRAY_SIZE(uiPins));
void doUI(void)
// set the speed if it has changed - Analog read
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 0, 100);
if ((speed >= ((int16_t)P.getSpeed() + SPEED_DEADBAND)) ||
(speed <= ((int16_t)P.getSpeed() - SPEED_DEADBAND)))
P.setSpeed(speed);
DEBUG("\nChanged speed to ", P.getSpeed());
// now process the switch digital inputs
if (uiSwitches.read() == MD_UISwitch::KEY_PRESS) // a switch was pressed!
switch (uiSwitches.getKey())
case JUSTIFY_SET: // TEXT ALIGNMENT - nothing on initialise
static uint8_t curMode = 1;
textPosition_t align = P.getTextAlignment();
textPosition_t textAlign[] =
PA_CENTER,
PA_LEFT,
PA_RIGHT
DEBUG("\nChanging alignment to ", curMode);
P.setTextAlignment(textAlign[curMode]);
P.displayReset();
curMode = (curMode + 1) % ARRAY_SIZE(textAlign);
case EFFECT_SET: // EFFECT CHANGE
static uint8_t curFX = 1;
textEffect_t effect[] =
PA_PRINT, PA_SCROLL_UP, PA_SCROLL_DOWN, PA_SCROLL_LEFT, PA_SCROLL_RIGHT,
#if ENA_MISC
PA_SLICE, PA_FADE, PA_MESH, PA_BLINDS, PA_DISSOLVE, PA_RANDOM,
#endif
#if ENA_WIPE
PA_WIPE, PA_WIPE_CURSOR,
#endif
#if ENA_OPNCLS
PA_OPENING, PA_OPENING_CURSOR, PA_CLOSING, PA_CLOSING_CURSOR,
#endif
#if ENA_SCR_DIA
PA_SCROLL_UP_LEFT, PA_SCROLL_UP_RIGHT, PA_SCROLL_DOWN_LEFT, PA_SCROLL_DOWN_RIGHT,
#endif
#if ENA_SCAN
PA_SCAN_HORIZ, PA_SCAN_HORIZX, PA_SCAN_VERT, PA_SCAN_VERTX,
#endif
#if ENA_GROW
PA_GROW_UP, PA_GROW_DOWN,
#endif
DEBUG("\nChanging effect to ", curFX);
P.setTextEffect(effect[curFX], effect[curFX]);
P.displayClear();
P.displayReset();
curFX = (curFX + 1) % ARRAY_SIZE(effect);
case PAUSE_SET: // PAUSE DELAY
DEBUGS("\nChanging pause");
if ((P.getPause() <= P.getSpeed()))
P.setPause(PAUSE_TIME);
P.setPause(0);
case INTENSITY_SET: // INTENSITY
static uint8_t intensity = MAX_INTENSITY/2;
if (intensity == 0)
P.displayShutdown(true);
DEBUG("\nDisplay shutdown ", intensity);
P.setIntensity(intensity);
P.displayShutdown(false);
DEBUG("\nChanged intensity to ", intensity);
intensity = (intensity + 1) % (MAX_INTENSITY + 1);
case INVERSE_SET: // INVERSE
P.setInvert(!P.getInvert());
case FLIP_SET: // FLIP
P.setZoneEffect(0, !P.getZoneEffect(0, PA_FLIP_LR), PA_FLIP_LR);
P.setZoneEffect(0, !P.getZoneEffect(0, PA_FLIP_UD), PA_FLIP_UD);
void setup(void)
#if DEBUG_ENABLE
Serial.begin(57600);
DEBUGS("[Parola Test]");
#endif
// user interface switches
uiSwitches.begin();
// Parola object
P.begin();
P.displayText(msg[curString], PA_CENTER, P.getSpeed(), PAUSE_TIME, PA_PRINT, PA_PRINT);
curString = NEXT_STRING;
void loop(void)
doUI();
if (P.displayAnimate())
P.setTextBuffer(msg[curString]);
P.displayReset();
what exactly do you mean by "But the aren't working good"?
I mean that sometimes the first segment fully light up, but the other time they light up all. There isn't also any text
MD_MAX72xx.h (39.5 KB)
