SerialUSB.begin is a dummy function : it does nothing and you don't even need it. The SerialUSB class is a special Serial instance which use the hardware USB peripheral : the speed will always be as fast as the device can go, I think.
Maybe I'm wrong, but when I change the dWDTERate to 1843200, my computer recognize the arduino but can't find the drivers (it thinks that's a new device which try connection)
On other boards, CDC transfers data at the full USB speed, but the USB only transports packets as rapidly as one side can create them and the other side can consume them. Arduino Zero probably works the same way.
Normally (other boards) the baud rate setting can be read in your sketch, even though it's not actually used by CDC, so you can use it to configure the real hardware serial baud rate. That allows you to make a USB-serial converter, where the hardware serial gets set to whatever the PC-side software wants.
Nope, I have just tried this sketch to measure a transfert time with different baudrates set in CDC.cpp
SerialUSB.begin(9600); //115200 921600 1843200 etc..
while (!SerialUSB) {};
unsigned long timer = micros();
for (int i = 0; i < 1000; i++) {
SerialUSB.println(i);
SerialUSB.println(micros() - timer);
delay(10000);
This is my results
9600 :
1.974036 s
1.963778 s
1.938866 s
115200 :
1.984935 s
1.971971 s
1.928075 s
921600 :
1.973776 s
1.994513 s
1.995619 s
I have always a time about 2 sec with any baudrate set in CDC.cpp...
Something is very wrong with your computer. This should never take 2 seconds to complete!
I just ran it here on Zero. I viewed with the Arduino Serial Monitor. I'm running 64 bit Linux on a desktop machine with i7-3930K CPU. It prints 56712, which is 0.056 seconds.
For comparison, I ran it on 6 different boards. Here are the results:
Zero 56712
Due 15776
Teensy LC 12378
Teensy 3.2 5640
Leonardo 162044
Teensy 2.0 35088
Aside from the fact that all of these are much faster than 2 seconds, they also really show how the CPU speed and efficiency dramatically affect performance. CDC uses the native USB speed, not a fixed (slow) baud rate, but the actual speed depends on the code because CDC uses end-to-end flow control.
I have exactly 423635 with the Programmer Port on the Arduino Zero and Serial.begin(115200).
But when I use the Native Port (which is configured with 115200), I have really the results on my last post using Arduino Serial Monitor or Termite with 2 differents computer.
Your screenshot says "Arduino M0 Pro" in the title of the serial monitor window. Maybe you're using software from Arduino.org, rather than Arduino.cc? Perhaps that could be the problem?
Okay, the problem may be there. Indeed, I have one M0 Pro from arduino.org which exactly the same hardware board than the Zero from .cc (There is just 2 pins inverted).
I have this board, because in the futur I'll transfer an other code in a M0 Board (Light version of the M0 Pro) which is the only arduino board operating in -40 to +85°C temperature range.
So I think there is something wrong with .org library for the configuration of the CDC. I'll check this
I just tried Arduino.org's 1.7.10 software. It can't upload at all to the native port on Arduino Zero. It does upload to the programming port, but nothing 1.7.10 builds seems to run on Zero, not even LED blink.
Perhaps these 2 boards aren't as similar as they might seem?
I do not have a M0 Pro board. I only have Arduino Zero.
The Zero board does work with Arduino.cc 1.6.9, but it does not work at all with Arduino.org 1.7.10. Even the programming port using Atmel's EDBG chip, which does upload with 1.7.10, doesn't result in the programs compiled by 1.7.10 actually running properly on Zero (at least with the board I have here).
Did you try running your program on your M0 Pro using Arduino.cc 1.6.9? Does it make a speed difference?
@Paul
The bootloader of the M0/M0 Pro is 16KB, VS 8KB for the Zero. So you manage to upload the program, but as soon as the Zero bootloader jumps to application, it jumps at adress 0x4000 + 4 instead of 0x8000+4, that's why the program doesn't execute : this memory space contains no code.
I made it work the Arduino M0 Pro on IDE 1.6.9. just burning the bootloader using this simple procedure from a post of BenStlr on this forum :
So, it took me 15 seconds to "turn" it into Zero(means to use this website IDE)
-Download the Zero board to the IDE (in the boards menu)
-Chose it from the boards menu
-Chose Atmel EDBG programmer
-Burn the boot loader, and it just worked
Now my M0 Pro seems work properly. I don't change the digital pin #2 to #4.
And I have better result with the SerialUSB (2 sec to 0.2 sec) but it requires new driver installation.
I'll search the difference between the two files.
I have best performances, but it's not enough for my project, I need to transfert 12kbytes/sec by the Native Port
loicb38:
Your test transmits approx 5000 bytes in 0.2 seconds, with Arduino.cc's faster CDC code. That's 25 kbytes/sec, or about double your 12 kbytes/sec requirement.
Due & Teensy LC & 3.2 are much faster in my tests, and my test with Zero on Linux was also faster, but even Zero with Windows seems good enough if you only need 12k/sec.
