Hi guys! I'm working on an Arduino m0 pro. I would like to know what is the maximum frequency for an interrupts. I would like to develop a system that, thanks to the interrupt overflow routine, outputs different values at each interrupt. Till now I followed this topic:
http://forum.arduino.cc/index.php?topic=425385.0;nowap
I want to do the same thing but with frequency of 25kHz, I tried to do it but in output I obtain just a constant signal. Is it possible to reach the frequency of 25kHz with an Arduino M0 pro?
In order to obtain an output every 39.06 microseconds (25kHz) what formula should I use?
This is my code:
int i = 0;
int sintable[256] PROGMEM={512,524,537,549,562,574,587,599,611,624,636,648,660,672,684,696,707,719,30,741,753,764,774,785,796,806,816,826,836,846,855,864,873,882,890,899,907,915,922,930,937,944,950,957,963,968,974,979,984,989,993,997,1001,1004,1008,1011,1013,1015,1017,1019,1021,1022,1022,1023,1023,1023,1022,1022,1021,1019,1017,1015,1013,1011,1008,1004,1001,997,993,989,984,979,974,968,963,957,950,944,937,930,922,915,907,899,890,882,873,864,855,846,836,826,816,806,796,785,774,764,753,741,730,719,707,696,684,672,660,648,636,624,611,599,587,574,562,549,537,524,512,499,486,474,461,449,436,424,412,399,387,375,363,351,339,327,316,304,293,282,270,259,249,238,227,217,207,197,187,177,168,159,150,141,133,124,116,108,101,93,86,79,73,66,60,55,49,44,39,34,30,26,22,19,15,12,10,8,6,4,2,1,1,0,0,0,1,1,2,4,6,8,10,12,15,19,22,26,30,34,39,44,49,55,60,66,73,79,86,93,101,108,116,124,133,141,150,159,168,177,187,197,207,217,227,238,249,259,270,282,293,304,316,327,339,351,363,375,387,399,412,424,436,449,461,474,486,499};
analogWriteResolution(10);
Serial.begin(9600); // Set up the generic clock (GCLK4) used to clock timers
REG_GCLK_GENDIV = GCLK_GENDIV_DIV(1) | // Divide the 48MHz clock source by divisor 1: 48MHz/1=48MHz
GCLK_GENDIV_ID(4); // Select Generic Clock (GCLK) 4
while (GCLK->STATUS.bit.SYNCBUSY); // Wait for synchronization
REG_GCLK_GENCTRL = GCLK_GENCTRL_IDC | // Set the duty cycle to 50/50 HIGH/LOW
GCLK_GENCTRL_GENEN | // Enable GCLK4
GCLK_GENCTRL_SRC_DFLL48M | // Set the 48MHz clock source
GCLK_GENCTRL_ID(4); // Select GCLK4
// Feed GCLK4 to TC4 and TC5
REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN | // Enable GCLK4 to TC4 and TC5
GCLK_CLKCTRL_GEN_GCLK4 | // Select GCLK4
GCLK_CLKCTRL_ID_TC4_TC5; // Feed the GCLK4 to TC4 and TC5
REG_TC4_COUNT16_CC0 = 0xEA; // Set the TC4 CC0 register as the TOP value in match frequency mode
while (TC4->COUNT16.STATUS.bit.SYNCBUSY); // Wait for synchronization
NVIC_SetPriority(TC4_IRQn, 0); // Set the Nested Vector Interrupt Controller (NVIC) priority for TC4 to 0 (highest)
NVIC_EnableIRQ(TC4_IRQn); // Connect TC4 to Nested Vector Interrupt Controller (NVIC)
REG_TC4_INTFLAG |= TC_INTFLAG_OVF; // Clear the interrupt flags
REG_TC4_INTENSET = TC_INTENSET_OVF; // Enable TC4 interrupts
REG_TC4_CTRLA |= TC_CTRLA_PRESCALER_DIV8 | // Set prescaler to 1024, 48MHz/1024 = 46.875kHz
TC_CTRLA_WAVEGEN_MFRQ | // Put the timer TC4 into match frequency (MFRQ) mode
TC_CTRLA_ENABLE; // Enable TC4
void loop() {}
void TC4_Handler() // Interrupt Service
Routine (ISR) for timer TC4
// Check for overflow (OVF) interrupt
if (TC4->COUNT16.INTFLAG.bit.OVF && TC4->COUNT16.INTENSET.bit.OVF){
Serial.print(sintable[i]);
Serial.print("\t");
Serial.print(i);
Serial.print("\n");
analogWrite(A0,sintable[i]);
i++;
if(i==256)
i=0;
REG_TC4_INTFLAG = TC_INTFLAG_OVF; // Clear the OVF interrupt flag
