I am studying Arduino ADC. I learned that the maximum sampling frequency of Arduino ADC ( e.g. Due) is 1M sample per second. However, as Arduino ADC has a 12-bit resolution so I can use an external ADC with a 16-bit for higher resolution.
My question is, what can be the maximum rate at which this Arduino can receive the sample signal from the External ADC? How can I find that?
In the case of Arduino's own ADC, it was 1M sample/Sec. But I don't know what can be the sample rate receiving limit for Arduino if It receives data from external ADC. My knowledge is basic level so I am not able to understand the datasheet.
It all depends on the interface. For instance SPI can be clocked fast enough for 1MSPS to be plausible on an
84MHz processor, above that sort of rate takes a data-bus and DMA.
The on-board DUE ADC is not very good(*), you want an external one anyway I suggest.
At this kind of sample rate its common to forget that the amount of RAM may be a limiting factor -
what exactly do you want to do?
(*) The Due AVcc is from a switch-mode regulator, so its very noisy and this ruins the analog
performance of the Due.
Thank you MarkT. I want to measure the frequency response of the analog sensor. Due to the high-resolution requirement ( 16 bit), I am planning to use the external ADC. However, I am not sure what sample rate would I have in case of external ADC ( in terms of Arduino on receiving end ).
If you intend to choose an external high speed 16-bit ADC with SPI interface, there is the TurboSPI library for the DUE. This library leverages the DMA feature for SPI peripheral:
You can get pretty fast commodity precision SAR's, like the ADS8885, 18 bit, 400kSPS.
I suspect you're oversimplifying the landscape of ADC design, there are hundreds of hybrid approaches I suspect,
many trade-secret. And modern processes give huge speedups, 14 bit 3GSPS is about the state of the
art I reckon, and 1GSPS for 16 bit, for instance ADS54J60. You don't want to know the price though
The designs inside these chips will be pulling all sorts of tricks I expect, with pipelining, flash conversion
sigma-delta, laser-trimming, exotic semiconductor materials, etc etc.
Anyway with a high precision ADC running at high sample rates the limiting factor to accuracy
is often clock-jitter. With 16 bit at 1MSPS, you need a jitter below about 30ps rms to avoid
reducing the effective resolution for high frequency input signals.
