Maxx7219 8x32 dot matrix Clock Code help
I am very new to Arduino, coding and this forum. I am making a clock that cycles through the time, Day of the week, month, date and year. I want to add a DHT11 Temperature and Humidity sensor so that after it cycles through everything and it's done displaying the year, I want it to display the Temperature in degrees Fahrenheit for 2.5 seconds then switch to Humidity and display it in %RH for 2.5 seconds before switching back to the clock. i tried to add in what little i knew and could figure out from examples online, but nothing is displaying on the screen for temperature or humidity. would someone be able to take a look at my code and help me get started in the right direction? I have been trying different things for a few hours, and I can't seem to figure it out easily. I'm using a maxx7219 8x32 dot matrix . I'm also using the ds1307 RTC module. The clock also has 2 buttons to cycle through the diffrent clock modes and for setting up. Thank you for your assistance.
#include <DHT.h>
#include <DHT_U.h>
#include "LedControl.h"
#include <FontLEDClock.h>
#include <Wire.h>
#include "RTClib.h"
#include <Button.h>
#define DHTPIN 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
unsigned long ct = 0;
unsigned long pt = 0;
// Setup LED Matrix
LedControl lc = LedControl(11, 13, 10, 4); //sets the 3 pins as 4, 5 & 6 and then sets 4 displays (max is 8 displays)
//global variables
byte intensity = 0;                      // Default intensity/brightness (0-15)
byte clock_mode = 0;                     // Default clock mode. Default = 0 (basic_mode)
bool random_mode = 0;                    // Define random mode - changes the display type every few hours. Default = 0 (off)
byte old_mode = clock_mode;              // Stores the previous clock mode, so if we go to date or whatever, we know what mode to go back to after.
bool ampm = 1;                           // Define 12 or 24 hour time. 0 = 24 hour. 1 = 12 hour
byte change_mode_time = 0;               // Holds hour when clock mode will next change if in random mode.
unsigned long delaytime = 3000;          // We always wait a bit between updates of the display 500 ms
int rtc[7];                              // Holds real time clock output
char days[7][4] = {
  "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"
}; //day array - used in slide, basic_mode and jumble modes (The DS1307 outputs 1-7 values for day of week)
char daysfull[7][9] = {
  "Sunday", "Monday", "Tuesday", "Wed", "Thursday", "Friday", "Saturday"
char suffix[4][3] = {
  "st", "nd", "rd", "th"
};  //date suffix array, used in slide, basic_mode and jumble modes. e,g, 1st 2nd ...
//define constants
#define NUM_DISPLAY_MODES 3              // Number display modes (conting zero as the first mode)
#define NUM_SETTINGS_MODES 4             // Number settings modes = 6 (conting zero as the first mode)
#define SLIDE_DELAY 20                   // The time in milliseconds for the slide effect per character in slide mode. Make this higher for a slower effect
#define cls          clear_display       // Clear display
RTC_DS1307 ds1307;                              // Create RTC object
Button buttonA = Button(2, BUTTON_PULLUP);      // Setup button A (using button library)
Button buttonB = Button(3, BUTTON_PULLUP);      // Setup button B (using button library)
  digitalWrite(2, HIGH);                 // turn on pullup resistor for button on pin 2
  digitalWrite(3, HIGH);                 // turn on pullup resistor for button on pin 3
  digitalWrite(4, HIGH);                 // turn on pullup resistor for button on pin 4
  Serial.begin(9600); //start serial
  //initialize the 4 matrix panels
  int devices = lc.getDeviceCount();
  for (int address = 0; address < devices; address++) {
    lc.shutdown(address, false);
    lc.setIntensity(address, intensity);
    lc.clearDisplay(address);
  //Setup DS1307 RTC
#ifdef AVR
  Wire.begin();
#else
  Wire1.begin(); // Shield I2C pins connect to alt I2C bus on Arduino
#endif
  ds1307.begin(); //start RTC Clock
  if (! ds1307.isrunning()) {
    Serial.println("RTC is NOT running!");
    ds1307.adjust(DateTime(__DATE__, __TIME__));  // sets the RTC to the date & time this sketch was compiled
  //Show software version & hello message
  printver();
  //enable red led
  digitalWrite(13, HIGH);
  // Initialize DHT sensor
  dht.begin();
  //run the clock with whatever mode is set by clock_mode - the default is set at top of code.
  switch (clock_mode){
  case 0:
    basic_mode();
  case 1:
    small_mode();
  case 2:
    slide();
  case 3:
    word_clock();
  case 4:
    setup_menu();
     case 5:
    display_temperature();
  case 6:
    display_humidity();
//plot a point on the display
void plot (byte x, byte y, byte val) {
  //select which matrix depending on the x coord
  byte address;
  if (x >= 0 && x <= 7)   {
    address = 3;
  if (x >= 8 && x <= 15)  {
    address = 2;
    x = x - 8;
  if (x >= 16 && x <= 23) {
    address = 1;
    x = x - 16;
  if (x >= 24 && x <= 31) {
    address = 0;
    x = x - 24;
  if (val == 1) {
    lc.setLed(address, y, x, true);
    lc.setLed(address, y, x, false);
//clear screen
void clear_display() {
  for (byte address = 0; address < 4; address++) {
//fade screen down
void fade_down() {
  //fade from global intensity to 1
  for (byte i = intensity; i > 0; i--) {
      lc.setIntensity(address, i);
    delay(2000); //change this to change fade down speed 30ms
  clear_display(); //clear display completely (off)
  //reset intentsity to global val
//power up led test & display software version number
void printver() {
  byte i = 0;
  char hello_message[9] = " Hello! ";
  //test all leds.
  for (byte x = 0; x <= 31; x++) {
    for (byte y = 0; y <= 7; y++) {
      plot(x, y, 1);
  delay(600);
  fade_down();
  while (hello_message[i]) {
    puttinychar((i * 4), 1, hello_message[i]);
    delay(35);
    i++;
  delay(700);
  fade_down();
// Additional functions to display temperature and humidity
void display_temperature() {
  float tempF = dht.readTemperature(true); // Read temperature in Fahrenheit
  char buffer[6];
  dtostrf(tempF, 4, 1, buffer); // Convert float to string with 1 decimal place
  cls();
  puttinychar(0, 1, 'T');
  puttinychar(4, 1, ':');
  puttinychar(8, 1, buffer[0]);
  puttinychar(12, 1, buffer[1]);
  puttinychar(16, 1, buffer[2]);
  puttinychar(20, 1, buffer[3]);
  puttinychar(24, 1, buffer[4]);
  delay(2500);
  fade_down();
  clock_mode = 6; // Switch to humidity display mode
void display_humidity() {
  float humidity = dht.readHumidity(); // Read humidity
  char buffer[6];
  dtostrf(humidity, 4, 1, buffer); // Convert float to string with 1 decimal place
  cls();
  puttinychar(0, 1, 'H');
  delay(2500);
  fade_down();
  clock_mode = 0; // Switch back to clock display mode
// puttinychar
// Copy a 3x5 character glyph from the myfont data structure to display memory, with its upper left at the given coordinate
// This is unoptimized and simply uses plot() to draw each dot.
void puttinychar(byte x, byte y, char c)
  byte dots;
  if (c >= 'A' && c <= 'Z' || (c >= 'a' && c <= 'z') ) {
    c &= 0x1F;   // A-Z maps to 1-26
  else if (c >= '0' && c <= '9') {
    c = (c - '0') + 32;
  else if (c == ' ') {
    c = 0; // space
  else if (c == '.') {
    c = 27; // full stop
  else if (c == ':') {
    c = 28; // colon
  else if (c == '\'') {
    c = 29; // single quote mark
  else if (c == '!') {
    c = 30; // single quote mark
  else if (c == '?') {
    c = 31; // single quote mark
  for (byte col = 0; col < 3; col++) {
    dots = pgm_read_byte_near(&mytinyfont[c][col]);
    for (char row = 0; row < 5; row++) {
      if (dots & (16 >> row))
        plot(x + col, y + row, 1);
        plot(x + col, y + row, 0);
void putnormalchar(byte x, byte y, char c)
  byte dots;
  //  if (c >= 'A' && c <= 'Z' || (c >= 'a' && c <= 'z') ) {
  //    c &= 0x1F;   // A-Z maps to 1-26
  if (c >= 'A' && c <= 'Z' ) {
  else if (c >= 'a' && c <= 'z') {
    c = (c - 'a') + 41;   // A-Z maps to 41-67
    c = (c - '0') + 31;
    c = 0; // space
    c = 28; // single quote mark
    c = 29; // clock_mode selector arrow
  else if (c == '>') {
    c = 30; // clock_mode selector arrow
  else if (c >= -80 && c <= -67) {
    c *= -1;
  for (char col = 0; col < 5; col++) {
    dots = pgm_read_byte_near(&myfont[c][col]);
    for (char row = 0; row < 7; row++) {
      //check coords are on screen before trying to plot
      //if ((x >= 0) && (x <= 31) && (y >= 0) && (y <= 7)){
      if (dots & (64 >> row)) {   // only 7 rows.
//small_mode
//show the time in small 3x5 characters with seconds display
void small_mode() {
  char textchar[8]; // the 16 characters on the display
  byte mins = 100; //mins
  byte secs = rtc[0]; //seconds
  byte old_secs = secs; //holds old seconds value - from last time seconds were updated o display - used to check if seconds have changed
  cls();
  //run clock main loop as long as run_mode returns true
  while (run_mode()) {
    get_time();
    //check for button press
    if (buttonA.uniquePress()) {
      switch_mode();
      return;
    if (buttonB.uniquePress()) {
      display_date();
      return;
    //if secs changed then update them on the display
    secs = rtc[0];
    if (secs != old_secs) {
      //secs
      char buffer[3];
      itoa(secs, buffer, 10);
      //fix - as otherwise if num has leading zero, e.g. "03" secs, itoa coverts this to chars with space "3 ".
      if (secs < 10) {
        buffer[1] = buffer[0];
        buffer[0] = '0';
      puttinychar( 20, 1, ':'); //seconds colon
      puttinychar( 24, 1, buffer[0]); //seconds
      puttinychar( 28, 1, buffer[1]); //seconds
      old_secs = secs;
    //if minute changes change time
    if (mins != rtc[1]) {
      //reset these for comparison next time
      mins = rtc[1];
      byte hours = rtc[2];
      if (hours > 12) {
        hours = hours - ampm * 12;
      if (hours < 1) {
        hours = hours + ampm * 12;
      //byte dow  = rtc[3]; // the DS1307 outputs 0 - 6 where 0 = Sunday0 - 6 where 0 = Sunday.
      //byte date = rtc[4];
      //set characters
      char buffer[3];
      itoa(hours, buffer, 10);
      //fix - as otherwise if num has leading zero, e.g. "03" hours, itoa coverts this to chars with space "3 ".
      if (hours < 10) {
        //if we are in 12 hour mode blank the leading zero.
        if (ampm) {
          buffer[0] = ' ';
        else {
          buffer[0] = '0';
      //set hours chars
      textchar[0] = buffer[0];
      textchar[1] = buffer[1];
      textchar[2] = ':';
      itoa (mins, buffer, 10);
      if (mins < 10) {
        buffer[0] = '0';
      //set mins characters
      textchar[3] = buffer[0];
      textchar[4] = buffer[1];
      //do seconds
      textchar[5] = ':';
      buffer[3];
      secs = rtc[0];
      if (secs < 10) {
        buffer[0] = '0';
      //set seconds
      textchar[6] = buffer[0];
      textchar[7] = buffer[1];
      byte x = 0;
      byte y = 0;
      //print each char
      for (byte x = 0; x < 6 ; x++) {
        puttinychar( x * 4, 1, textchar[x]);
    delay(50);
    ct = millis();
    if(ct-pt>75000)
      pt = ct;
    display_date();
    return;
  fade_down();
// basic_mode()
// show the time in 5x7 characters
void basic_mode()
  cls();
  char buffer[3];   //for int to char conversion to turn rtc values into chars we can print on screen
  byte offset = 0;  //used to offset the x postition of the digits and centre the display when we are in 12 hour mode and the clock shows only 3 digits. e.g. 3:21
  byte x, y;        //used to draw a clear box over the left hand "1" of the display when we roll from 12:59 -> 1:00am in 12 hour mode.
  //do 12/24 hour conversion if ampm set to 1
  if (hours > 12) {
  if (hours < 1) {
  //do offset conversion
  if (ampm && hours < 10) {
    //offset = 2;
  //set the next minute we show the date at
  //set_next_date();
  // initially set mins to value 100 - so it wll never equal rtc[1] on the first loop of the clock, meaning we draw the clock display when we enter the function
  byte secs = 100;
  byte mins = 100;
  int count = 0;
    //get the time from the clock chip
    get_time();
      switch_mode();
      return;
      display_date();
      return;
    //check whether it's time to automatically display the date
    //check_show_date();
    //draw the flashing : as on if the secs have changed.
    if (secs != rtc[0]) {
      //update secs with new value
      secs = rtc[0];
      //draw :
      plot (15, 2, 1); //top point
      plot (15, 5, 1); //bottom point
      count = 400;
    //if count has run out, turn off the :
    if (count == 0) {
    else {
      count--;
    //re draw the display if button pressed or if mins != rtc[1] i.e. if the time has changed from what we had stored in mins, (also trigggered on first entering function when mins is 100)
      //update mins and hours with the new values
      mins = rtc[1];
      hours = rtc[2];
      //adjust hours of ampm set to 12 hour mode
      if (hours > 12) {
      if (hours < 1) {
      //if hours < 10 the num e.g. "3" hours, itoa coverts this to chars with space "3 " which we dont want
      if (hours < 10) {
        buffer[0] = '0';
      //print hours
      //if we in 12 hour mode and hours < 10, then don't print the leading zero, and set the offset so we centre the display with 3 digits.
        //offset = 2;
        //if the time is 1:00am clear the entire display as the offset changes at this time and we need to blank out the old 12:59
        if ((hours == 1 && mins == 0) ) {
          cls();
      else {
        //else no offset and print hours tens digit
        offset = 0;
        //if the time is 10:00am clear the entire display as the offset changes at this time and we need to blank out the old 9:59
        if (hours == 10 && mins == 0) {
          cls();
        //putnormalchar(1,  0, buffer[0]);
        putnormalchar(2,  0, buffer[0]);
      //print hours ones digit
      putnormalchar(8 - offset, 0, buffer[1]);
      //print mins
      //add leading zero if mins < 10
      if (mins < 10) {
        buffer[0] = '0';
      //print mins tens and ones digits
      putnormalchar(18 - offset, 0, buffer[0]);
      putnormalchar(24 - offset, 0, buffer[1]);
    ct = millis();
    if(ct-pt>75000)
      pt = ct;
    display_date();
    return;
  fade_down();
//like basic_mode but with slide effect
void slide() {
  byte digits_old[4] = {99, 99, 99, 99}; //old values  we store time in. Set to somthing that will never match the time initially so all digits get drawn wnen the mode starts
  byte digits_new[4]; //new digits time will slide to reveal
  byte digits_x_pos[4] = {25, 19, 7, 1}; //x pos for which to draw each digit at
  char old_char[2]; //used when we use itoa to transpose the current digit (type byte) into a char to pass to the animation function
  char new_char[2]; //used when we use itoa to transpose the new digit (type byte) into a char to pass to the animation function
  //old_chars - stores the 5 day and date suffix chars on the display. e.g. "mon" and "st". We feed these into the slide animation as the current char when these chars are updated.
  //We sent them as A initially, which are used when the clocl enters the mode and no last chars are stored.
  //char old_chars[6] = "AAAAA";
  //plot the clock colon on the display
  cls();
  putnormalchar( 13, 0, ':');
  byte old_secs = rtc[0]; //store seconds in old_secs. We compare secs and old secs. WHen they are different we redraw the display
    get_time();
      switch_mode();
      return;
      display_date();
      return;
    //if secs have changed then update the display
    if (rtc[0] != old_secs) {
      old_secs = rtc[0];
      if (hours > 12) {
      if (hours < 1) {
      //split all date and time into individual digits - stick in digits_new array
      //rtc[0] = secs                        //array pos and digit stored
      //digits_new[0] = (rtc[0]%10);           //0 - secs ones
      //digits_new[1] = ((rtc[0]/10)%10);      //1 - secs tens
      //rtc[1] = mins
      digits_new[0] = (rtc[1] % 10);         //2 - mins ones
      digits_new[1] = ((rtc[1] / 10) % 10);  //3 - mins tens
      //rtc[2] = hours
      digits_new[2] = (hours % 10);         //4 - hour ones
      digits_new[3] = ((hours / 10) % 10);  //5 - hour tens
      //rtc[4] = date
      //digits_new[6] = (rtc[4]%10);           //6 - date ones
      //digits_new[7] = ((rtc[4]/10)%10);      //7 - date tens
      //draw initial screen of all chars. After this we just draw the changes.
      //compare digits 0 to 3 (mins and hours)
      for (byte i = 0; i <= 3; i++) {
        //see if digit has changed...
        if (digits_old[i] != digits_new[i]) {
          //run 9 step animation sequence for each in turn
          for (byte seq = 0; seq <= 8 ; seq++) {
            //convert digit to string
            itoa(digits_old[i], old_char, 10);
            itoa(digits_new[i], new_char, 10);
            //if set to 12 hour mode and we're on digit 2 (hours tens mode) then check to see if this is a zero. If it is, blank it instead so we get 2.00pm not 02.00pm
            if (ampm && i == 3) {
              if (digits_new[3] == 0) {
                new_char[0] = ' ';
              if (digits_old[3] == 0) {
                old_char[0] = ' ';
            //draw the animation frame for each digit
            slideanim(digits_x_pos[i], 0, seq, old_char[0], new_char[0]);
            delay(SLIDE_DELAY);
      //compare date digit 6 (ones) and (7) tens - if either of these change we need to update the date line. We compare date tens as say from Jan 31 -> Feb 01 then ones digit doesn't change
      if ((digits_old[6] != digits_new[6]) || (digits_old[7] != digits_new[7])) {
        //change the day shown. Loop below goes through each of the 3 chars in turn e.g. "MON"
        for (byte day_char = 0; day_char <=2 ; day_char++){
          //run the anim sequence for each char
          for (byte seq = 0; seq <=8 ; seq++){
            //the day (0 - 6) Read this number into the days char array. the seconds number in the array 0-2 gets the 3 chars of the day name, e.g. m o n
            slideanim(6*day_char,8,seq,old_chars[day_char],days[rtc[3]][day_char]); //6 x day_char gives us the x pos for the char
            delay(SLIDE_DELAY);
          //save the old day chars into the old_chars array at array pos 0-2. We use this next time we change the day and feed it to the animation as the current char. The updated char is fed in as the new char.
          old_chars[day_char] = days[rtc[3]][day_char];
        //change the date tens digit (if needed) and ones digit. (the date ones digit wil alwaus change, but putting this in the 'if' loop makes it a bit neater code wise.)
        for (byte i = 7; i >= 6; i--){
              itoa(digits_old[i],old_char,10);
              itoa(digits_new[i],new_char,10);
              slideanim(digits_x_pos[i],8,seq,old_char[0],new_char[0]);
              delay(SLIDE_DELAY);
        //print the day suffix "nd" "rd" "th" etc. First work out date 2 letter suffix - eg st, nd, rd, th
        byte s = 3; //the pos to read our suffix array from.
        byte date = rtc[4];
        if(date == 1 || date == 21 || date == 31) {
          s = 0;
        else if (date == 2 || date == 22) {
          s = 1;
        else if (date == 3 || date == 23) {
          s = 2;
        for (byte suffix_char = 0; suffix_char <=1 ; suffix_char++){
            slideanim((suffix_char*6)+36,8,seq,old_chars[suffix_char+3],suffix[s][suffix_char]); // we pass in the old_char array char as the current char and the suffix array as the new char
            delay(SLIDE_DELAY);
          //save the suffic char in the old chars array at array pos 3 and 5.  We use these chars next time we change the suffix and feed it to the animation as the current char. The updated char is fed in as the new char.
          old_chars[suffix_char+3] = suffix[s][suffix_char];
      }//end do date line
      //save digita array tol old for comparison next loop
        digits_old[i] =  digits_new[i];
    }//secs/oldsecs
    ct = millis();
    if(ct-pt>75000)
      pt = ct;
    display_date();
    return;
  }//while loop
  fade_down();
//called by slide
//this draws the animation of one char sliding on and the other sliding off. There are 8 steps in the animation, we call the function to draw one of the steps from 0-7
//inputs are are char x and y, animation frame sequence (0-7) and the current and new chars being drawn.
void slideanim(byte x, byte y, byte sequence, char current_c, char new_c) {
  //  To slide one char off and another on we need 9 steps or frames in sequence...
  //  seq# 0123456 <-rows of the display
  //  seq0 0123456  START - all rows of the display 0-6 show the current characters rows 0-6
  //  seq1  012345  current char moves down one row on the display. We only see it's rows 0-5. There are at display positions 1-6 There is a blank row inserted at the top
  //  seq2 6 01234  current char moves down 2 rows. we now only see rows 0-4 at display rows 2-6 on the display. Row 1 of the display is blank. Row 0 shows row 6 of the new char
  //  seq3 56 0123
  //  seq4 456 012  half old / half new char
  //  seq5 3456 01
  //  seq6 23456 0
  //  seq7 123456
  //  seq8 0123456  END - all rows show the new char
  //from above we can see...
  //currentchar runs 0-6 then 0-5 then 0-4 all the way to 0. starting Y position increases by 1 row each time.
  //new char runs 6 then 5-6 then 4-6 then 3-6. starting Y position increases by 1 row each time.
  //if sequence number is below 7, we need to draw the current char
  if (sequence < 7) {
    byte dots;
    // if (current_c >= 'A' &&  || (current_c >= 'a' && current_c <= 'z') ) {
    //   current_c &= 0x1F;   // A-Z maps to 1-26
    if (current_c >= 'A' && current_c <= 'Z' ) {
    else if (current_c >= 'a' && current_c <= 'z') {
      current_c = (current_c - 'a') + 41;   // A-Z maps to 41-67
    else if (current_c >= '0' && current_c <= '9') {
      current_c = (current_c - '0') + 31;
    else if (current_c == ' ') {
      current_c = 0; // space
    else if (current_c == '.') {
      current_c = 27; // full stop
    else if (current_c == '\'') {
      current_c = 28; // single quote mark
    else if (current_c == ':') {
      current_c = 29; //colon
    else if (current_c == '>') {
      current_c = 30; // clock_mode selector arrow
    byte curr_char_row_max = 7 - sequence; //the maximum number of rows to draw is 6 - sequence number
    byte start_y = sequence; //y position to start at - is same as sequence number. We inc this each loop
    //plot each row up to row maximum (calculated from sequence number)
    for (byte curr_char_row = 0; curr_char_row <= curr_char_row_max; curr_char_row++) {
      for (byte col = 0; col < 5; col++) {
        dots = pgm_read_byte_near(&myfont[current_c][col]);
        if (dots & (64 >> curr_char_row))
          plot(x + col, y + start_y, 1); //plot led on
          plot(x + col, y + start_y, 0); //else plot led off
      start_y++;//add one to y so we draw next row one down
  //draw a blank line between the characters if sequence is between 1 and 7. If we don't do this we get the remnants of the current chars last position left on the display
  if (sequence >= 1 && sequence <= 8) {
      plot(x + col, y + (sequence - 1), 0); //the y position to draw the line is equivalent to the sequence number - 1
  //if sequence is above 2, we also need to start drawing the new char
  if (sequence >= 2) {
    //work out char
    byte dots;
    //if (new_c >= 'A' && new_c <= 'Z' || (new_c >= 'a' && new_c <= 'z') ) {
    //  new_c &= 0x1F;   // A-Z maps to 1-26
    if (new_c >= 'A' && new_c <= 'Z' ) {
    else if (new_c >= 'a' && new_c <= 'z') {
      new_c = (new_c - 'a') + 41;   // A-Z maps to 41-67
    else if (new_c >= '0' && new_c <= '9') {
      new_c = (new_c - '0') + 31;
    else if (new_c == ' ') {
      new_c = 0; // space
    else if (new_c == '.') {
      new_c = 27; // full stop
    else if (new_c == '\'') {
      new_c = 28; // single quote mark
    else if (new_c == ':') {
      new_c = 29; // clock_mode selector arrow
    else if (new_c == '>') {
      new_c = 30; // clock_mode selector arrow
    byte newcharrowmin = 6 - (sequence - 2); //minimumm row num to draw for new char - this generates an output of 6 to 0 when fed sequence numbers 2-8. This is the minimum row to draw for the new char
    byte start_y = 0; //y position to start at - is same as sequence number. we inc it each row
    //plot each row up from row minimum (calculated by sequence number) up to 6
    for (byte newcharrow = newcharrowmin; newcharrow <= 6; newcharrow++) {
        dots = pgm_read_byte_near(&myfont[new_c][col]);
        if (dots & (64 >> newcharrow))
//print a clock using words rather than numbers
void word_clock() {
  cls();
  char numbers[19][10]   = {
    "one", "two", "three", "four", "five", "six", "seven", "eight", "nine", "ten",
    "eleven", "twelve", "thirteen", "fourteen", "fifteen", "sixteen", "seventeen", "eighteen", "nineteen"
  char numberstens[5][7] = {
    "ten", "twenty", "thirty", "forty", "fifty"
  //potentially 3 lines to display
  char str_a[8];
  char str_b[8];
  char str_c[8];
  //byte hours_y, mins_y; //hours and mins and positions for hours and mins lines
  if (hours > 12) {
  if (hours < 1) {
  get_time(); //get the time from the clock chip
  byte old_mins = 100; //store mins in old_mins. We compare mins and old mins & when they are different we redraw the display. Set this to 100 initially so display is drawn when mode starts.
  byte mins;
      switch_mode();
      return;
      display_date();
    mins = rtc[1];  //get mins
    //if mins is different from old_mins - redraw display
    if (mins != old_mins) {
      //update old_mins with current mins value
      old_mins = mins;
      mins = rtc[1];
      hours = rtc[2];
      //make hours into 12 hour format
      if (hours > 12) {
        hours = hours - 12;
      if (hours == 0) {
        hours = 12;
      //split mins value up into two separate digits
      int minsdigit = rtc[1] % 10;
      byte minsdigitten = (rtc[1] / 10) % 10;
      //if mins <= 10 , then top line has to read "minsdigti past" and bottom line reads hours
      if (mins < 10) {
        strcpy (str_a, numbers[minsdigit - 1]);
        strcpy (str_b, "PAST");
        strcpy (str_c, numbers[hours - 1]);
      //if mins = 10, cant use minsdigit as above, so soecial case to print 10 past /n hour.
      if (mins == 10) {
        strcpy (str_a, numbers[9]);
        strcpy (str_b, " PAST");
      //if time is not on the hour - i.e. both mins digits are not zero,
      //then make first line read "hours" and 2 & 3rd lines read "minstens"  "mins" e.g. "three /n twenty /n one"
      else if (minsdigitten != 0 && minsdigit != 0  ) {
        strcpy (str_a, numbers[hours - 1]);
        //if mins is in the teens, use teens from the numbers array for the 2nd line, e.g. "fifteen"
        //if (mins >= 11 && mins <= 19) {
        if (mins <= 19) {
          strcpy (str_b, numbers[mins - 1]);
        else {
          strcpy (str_b, numberstens[minsdigitten - 1]);
          strcpy (str_c, numbers[minsdigit - 1]);
      // if mins digit is zero, don't print it. read read "hours" "minstens" e.g. "three /n twenty"
      else if (minsdigitten != 0 && minsdigit == 0  ) {
        strcpy (str_c, "");
      //if both mins are zero, i.e. it is on the hour, the top line reads "hours" and bottom line reads "o'clock"
      else if (minsdigitten == 0 && minsdigit == 0  ) {
        strcpy (str_b, "O'CLOCK");
        strcpy (str_c, "");
    }//end worknig out time
    //run in a loop
    //print line a "twelve"
    byte len = 0;
    while (str_a[len]) {
      len++;
    }; //get length of message
    byte offset_top = (31 - ((len - 1) * 4)) / 2; //
    //plot hours line
    byte i = 0;
    while (str_a[i]) {
      puttinychar((i * 4) + offset_top, 1, str_a[i]);
      i++;
    //hold display but check for button presses
    int counter = 1000;
    while (counter > 0){
        switch_mode();
        return;
        display_date();
    delay(1);
    counter--;
    fade_down();
    //print line b
    len = 0;
    while (str_b[len]) {
      len++;
    i = 0;
    while (str_b[i]) {
      puttinychar((i * 4) + offset_top, 1, str_b[i]);
      i++;
    counter = 1000;
        switch_mode();
        return;
        display_date();
      delay(1);
      counter--;
    fade_down();
    //print line c if there.
    len = 0;
    while (str_c[len]) {
      len++;
    i = 0;
    while (str_c[i]) {
      puttinychar((i * 4) + offset_top, 1, str_c[i]);
      i++;
    counter = 1000;
        switch_mode();
        return;
        display_date();
      delay(1);
      counter--;
    fade_down();
    //hold display blank but check for button presses before starting again.
    counter = 1000;
        switch_mode();
        return;
        display_date();
      delay(1);
      counter--;
  fade_down();
//display_date - print the day of week, date and month with a flashing cursor effect
void display_date()
  cls();
  //read the date from the DS1307
  byte dow = rtc[3]; // day of week 0 = Sunday
  byte date = rtc[4];
  byte month = rtc[5] - 1;
  int year = rtc[6];
  //array of month names to print on the display. Some are shortened as we only have 8 characters across to play with
  char monthnames[12][9] = {
    "January", "February", "March", "April", "May", "June", "July", "August", "Sept", "October", "November", "December"
  //print the day name
  //get length of text in pixels, that way we can centre it on the display by divindin the remaining pixels b2 and using that as an offset
  byte len = 0;
  while(daysfull[dow][len]) {
    len++;
  byte offset = (31 - ((len-1)*4)) / 2; //our offset to centre up the text
  //print the name
  int i = 0;
  while(daysfull[dow][i])
    puttinychar((i*4) + offset , 1, daysfull[dow][i]);
    i++;
  delay(3200);
  fade_down();
  cls();
 //print the month name
  len = 0;
  while(monthnames[month][len]) {
    len++;
  i = 0;
  while(monthnames[month][i])
    puttinychar((i*4) +offset, 1, monthnames[month][i]);
    i++;
  delay(3200);
  fade_down();
  // print date numerals
  char buffer[3];
  itoa(date,buffer,10);
  offset = 10; //offset to centre text if 3 chars - e.g. 3rd
  // first work out date 2 letter suffix - eg st, nd, rd, th etc
  // char suffix[4][3]={"st", "nd", "rd", "th"  }; is defined at top of code
  byte s = 3;
    s = 0;
    s = 1;
    s = 2;
  //print the 1st date number
  puttinychar(-4+offset, 1, buffer[0]);
  //if date is under 10 - then we only have 1 digit so set positions of sufix etc one character nearer
  byte suffixposx = 4;
  //if date over 9 then print second number and set xpos of suffix to be 1 char further away
  if (date > 9){
    suffixposx = 8;
    puttinychar(0+offset, 1, buffer[1]);
    offset = 8; //offset to centre text if 4 chars
  //print the 2 suffix characters
  puttinychar(suffixposx+offset, 1, suffix[s][0]);
  puttinychar(suffixposx+4+offset, 1, suffix[s][1]);
  delay(3200);
  fade_down();
  char bufferx[4];
  itoa(year, bufferx, 10);
  puttinychar(-2+offset, 1, bufferx[0]);
  puttinychar(2+offset, 1, bufferx[1]);
  puttinychar(6+offset, 1, bufferx[2]);
  puttinychar(10+offset, 1, bufferx[3]);
  delay(3200);
  fade_down();
//dislpay menu to change the clock mode
void switch_mode() {
  //remember mode we are in. We use this value if we go into settings mode, so we can change back from settings mode (6) to whatever mode we were in.
  char* modes[] = {
    "Basic", "Small", "Slide", "Words", "Setup"
  byte next_clock_mode;
  byte firstrun = 1;
  //loop waiting for button (timeout after 35 loops to return to mode X)
  for (int count = 0; count < 50 ; count++) {
    //if user hits button, change the clock_mode
    if (buttonA.uniquePress() || firstrun == 1) {
      count = 0;
      cls();
      if (firstrun == 0) {
        clock_mode++;
      if (clock_mode > NUM_DISPLAY_MODES + 1 ) {
        clock_mode = 0;
      //print arrown and current clock_mode name on line one and print next clock_mode name on line two
      char str_top[9];
      //strcpy (str_top, "-");
      strcpy (str_top, modes[clock_mode]);
      next_clock_mode = clock_mode + 1;
      if (next_clock_mode >  NUM_DISPLAY_MODES + 1 ) {
        next_clock_mode = 0;
      byte i = 0;
      while (str_top[i]) {
        putnormalchar(i * 6, 0, str_top[i]);
        i++;
      firstrun = 0;
    delay(50);
byte run_mode() {
  //if random mode is on... check the hour when we change mode.
  if (random_mode) {
    //if hour value in change mode time = hours. then reurn false = i.e. exit mode.
    if (change_mode_time == rtc[2]) {
      //set the next random clock mode and time to change it
      set_next_random();
      //exit the current mode.
      return 0;
  //else return 1 - keep running in this mode
  return 1;
//set the next hour the clock will change mode when random mode is on
void set_next_random() {
  //set the next hour the clock mode will change - current time plus 1 - 4 hours
  get_time();
  change_mode_time = rtc[2] + random (1, 5);
  //if change_mode_time now happens to be over 23, then set it to between 1 and 3am
  if (change_mode_time > 23) {
    change_mode_time = random (1, 4);
  //set the new clock mode
  clock_mode = random(0, NUM_DISPLAY_MODES + 1);  //pick new random clock mode
//dislpay menu to change the clock settings
void setup_menu() {
  char* set_modes[] = {
     "Rndom", "24 Hr","Set", "Brght", "Exit"};
  if (ampm == 0) {
    set_modes[1] = ("12 Hr");
  byte setting_mode = 0;
  byte next_setting_mode;
  byte firstrun = 1;
  for(int count=0; count < 50 ; count++) {
    if(buttonA.uniquePress() || firstrun == 1){
      count = 0;
      cls();
        setting_mode++;
      if (setting_mode > NUM_SETTINGS_MODES) {
        setting_mode = 0;
      char str_top[9];
      strcpy (str_top, set_modes[setting_mode]);
      next_setting_mode = setting_mode + 1;
      if (next_setting_mode > NUM_SETTINGS_MODES) {
        next_setting_mode = 0;
      byte i = 0;
      while(str_top[i]) {
        putnormalchar(i*6, 0, str_top[i]);
        i++;
      firstrun = 0;
    delay(50);
  //pick the mode
  switch(setting_mode){
    case 0:
      set_random();
    case 1:
       set_ampm();
    case 2:
      set_time();
    case 3:
       set_intensity();
    case 4:
      //exit menu
  //change the clock from mode 6 (settings) back to the one it was in before
  clock_mode=old_mode;
//toggle random mode - pick a different clock mode every few hours
void set_random(){
  cls();
  char text_a[9] = "Off";
  char text_b[9] = "On";
  byte i = 0;
  //if random mode is on, turn it off
  if (random_mode){
    //turn random mode off
    random_mode = 0;
    //print a message on the display
    while(text_a[i]) {
      putnormalchar((i*6), 0, text_a[i]);
      i++;
    //turn randome mode on.
    random_mode = 1;
    //set hour mode will change
    set_next_random();
    while(text_b[i]) {
      putnormalchar((i*6), 0, text_b[i]);
      i++;
  delay(1500); //leave the message up for a second or so
//set 12 or 24 hour clock
void set_ampm() {
  // AM/PM or 24 hour clock mode - flip the bit (makes 0 into 1, or 1 into 0 for ampm mode)
  ampm = (ampm ^ 1);
  cls();
//change screen intensityintensity
void set_intensity() {
  cls();
  byte i = 0;
  char text[7] = "Bright";
  while(text[i]) {
    puttinychar((i*4)+4, 0, text[i]);
    i++;
  //wait for button input
  while (!buttonA.uniquePress()) {
    levelbar (0,6,(intensity*2)+2,2);    //display the intensity level as a bar
    while (buttonB.isPressed()) {
      if(intensity == 15) {
        intensity = 0;
        cls ();
      else {
        intensity++;
      //print the new value
      i = 0;
      while(text[i]) {
        i++;
      //change the brightness setting on the displays
      delay(150);
// display a horizontal bar on the screen at offset xposr by ypos with height and width of xbar, ybar
void levelbar (byte xpos, byte ypos, byte xbar, byte ybar) {
  for (byte x = 0; x < xbar; x++) {
    for (byte y = 0; y <= ybar; y++) {
      plot(x+xpos, y+ypos, 1);
//set time and date routine
void set_time() {
  cls();
  //fill settings with current clock values read from clock
  get_time();
  byte set_min   = rtc[1];
  byte set_hr    = rtc[2];
  byte set_date  = rtc[4];
  byte set_mnth  = rtc[5];
  int  set_yr    = rtc[6];
  //Set function - we pass in: which 'set' message to show at top, current value, reset value, and rollover limit.
  set_date = set_value(2, set_date, 1, 31);
  set_mnth = set_value(3, set_mnth, 1, 12);
  set_yr   = set_value(4, set_yr, 2013, 2099);
  set_hr   = set_value(1, set_hr, 0, 23);
  set_min  = set_value(0, set_min, 0, 59);
  ds1307.adjust(DateTime(set_yr, set_mnth, set_date, set_hr, set_min));
  cls();
//used to set min, hr, date, month, year values. pass
//message = which 'set' message to print,
//current value = current value of property we are setting
//reset_value = what to reset value to if to rolls over. E.g. mins roll from 60 to 0, months from 12 to 1
//rollover limit = when value rolls over
int set_value(byte message, int current_value, int reset_value, int rollover_limit){
  cls();
  char messages[6][17]   = {
    "Set Mins", "Set Hour", "Set Day", "Set Mnth", "Set Year"};
  //Print "set xyz" top line
  byte i = 0;
  while(messages[message][i])
    puttinychar(i*4 , 1, messages[message][i]);
    i++;
  delay(2000);
  cls();
  //print digits bottom line
  char buffer[5] = "    ";
  itoa(current_value,buffer,10);
  puttinychar(0 , 1, buffer[0]);
  puttinychar(4 , 1, buffer[1]);
  puttinychar(8 , 1, buffer[2]);
  puttinychar(12, 1, buffer[3]);
  delay(300);
    while (buttonB.isPressed()){
      if(current_value < rollover_limit) {
        current_value++;
      else {
        current_value = reset_value;
      itoa(current_value, buffer ,10);
      delay(150);
  return current_value;
void get_time()
  //get time
  DateTime now = ds1307.now();
  //save time to array
  rtc[6] = now.year();
  rtc[5] = now.month();
  rtc[4] = now.day();
  rtc[3] = now.dayOfTheWeek(); //returns 0-6 where 0 = Sunday
  rtc[2] = now.hour();
  rtc[1] = now.minute();
  rtc[0] = now.second();
  //flash arduino led on pin 13 every second
  //if ( (rtc[0] % 2) == 0) {
  //  digitalWrite(13, HIGH);
  //else {
  //  digitalWrite(13, LOW);
  //print the time to the serial port - useful for debuging RTC issues
  Serial.print(rtc[2]);
  Serial.print(":");
  Serial.print(rtc[1]);
  Serial.print(":");
  Serial.println(rtc[0]);
It looks like your "display_date()" function displays the DOW, month, date and year and then calls the fade_down() function after each one of those.
You would just have to extend that function to then display the temperature and fade_down() and then the humidity and fade_down() before it returns.
BTW, that code seems terribly convoluted and overly complicated, but I'm sure it is part of the learning process! +1 for posting your code using code-tags.
