An MCP23017 is set up for:
- bank = 0 (A and B addresses are sequential)
- Mirror = 1 (INTA and INTB internally connected)
- port A = output
- port B = input, pull-up
- normally-open switch connects GPB0 to ground
- GPB1 to GPB7 connected with resistor to ground
- all resistor values >1k
- I2C address = 0x20
- interrupt-on-change enabled
- change versus previous value is enabled (INTCON = 0b00000000, default value)
So when pushing the button, the value on GPIOB goes from 1 to 0, and the interrupt is is set until register INTCAPB is read.
The LED on INTB signals the status of that output: when an interrupt occurs INTB goes low and the LED on that pin lights up.
However, the serial monitor output shows following values, regardless of whether the button is pushed or not:
INTFB = : 11110000 INTCAPB = : 10001000
Why does the serial output not show the status of INTCAPB as I would expect: 00000001 when released, 00000000 when pressed?
And why does INTFB show 11110000? I would have expected 00000001 after an interrupt on GPB0?
The schematic:
#include <Wire.h>
// MCP23017 registers (everything except direction defaults to 0)
#define IODIRA 0x00 // IO direction (0 = output, 1 = input (Default))
#define IODIRB 0x01
#define IOPOLA 0x02 // IO polarity (0 = normal, 1 = inverse)
#define IOPOLB 0x03
#define GPINTENA 0x04 // Interrupt on change (0 = disable, 1 = enable)
#define GPINTENB 0x05
#define DEFVALA 0x06 // Default comparison for interrupt on change (interrupts on opposite)
#define DEFVALB 0x07
#define INTCONA 0x08 // Interrupt control (0 = interrupt on change from previous, 1 = interrupt on change from DEFVAL)
#define INTCONB 0x09
#define IOCON 0x0A // IO Configuration: bank/mirror/seqop/disslw/haen/odr/intpol/notimp
//#define IOCON 0x0B // same as 0x0A
#define GPPUA 0x0C // Pull-up resistor (0 = disabled, 1 = enabled)
#define GPPUB 0x0D
#define INFTFA 0x0E // Interrupt flag (read only) : (0 = no interrupt, 1 = pin caused interrupt)
#define INFTFB 0x0F
#define INTCAPA 0x10 // Interrupt capture (read only) : value of GPIO at time of last interrupt
#define INTCAPB 0x11
#define GPIOA 0x12 // Port value. Write to change, read to obtain value
#define GPIOB 0x13
#define OLLATA 0x14 // Output latch. Write to latch output.
#define OLLATB 0x15
#define port 0x20 // MCP23017 is on I2C port 0x20: base address A0, A1 A2 = 0
#define ISR_INDICATOR 12 // pin 12
#define ONBOARD_LED 13 // pin 13
volatile bool keyPressed;
// set register "reg", and next register, on expander to "data"
// for example, IO direction
void expanderWriteBoth (const byte reg, const byte data )
Wire.beginTransmission (port);
Wire.write (reg);
Wire.write (data); // port A
Wire.write (data); // port B
Wire.endTransmission ();
} // end of expanderWrite
// set register "reg" on expander to "data"
void expanderWriteSingle (const byte reg, const byte data)
Wire.write (reg);
// read a byte from the expander
unsigned int expanderRead (const byte reg)
Wire.write (reg);
Wire.requestFrom (port, 1);
return Wire.read();
} // end of expanderRead
// interrupt service routine, called when pin D2 goes from 1 to 0
void keypress ()
digitalWrite (ISR_INDICATOR, HIGH); // debugging
keyPressed = true; // set flag so main loop knows
} // end of keypress
void setup ()
pinMode (ISR_INDICATOR, OUTPUT); // for testing (ISR indicator)
pinMode (ONBOARD_LED, OUTPUT); // for onboard LED
Wire.begin ();
Serial.begin (115200);
Serial.println ("Starting ...");
// expander GPIO register setting
expanderWriteSingle (IODIRA, 0b00000000);
// expander configuration register
expanderWriteBoth (IOCON, 0b01100000); // mirror interrupts, disable sequential mode
// enable pull-up on switches
expanderWriteBoth (GPPUA, 0xFF); // pull-up resistor for switch - both ports
// invert polarity
expanderWriteBoth (IOPOLA, 0xFF); // invert polarity of signal - both ports
// enable all interrupts
expanderWriteBoth (GPINTENA, 0xFF); // enable interrupts - both ports
// no interrupt yet
keyPressed = false;
// read from interrupt capture ports to clear them
expanderRead (INTCAPA);
expanderRead (INTCAPB);
// pin 19 of MCP23017 is plugged into D2 of the Arduino which is interrupt 0
attachInterrupt(0, keypress, FALLING);
} // end of setup
// time we turned LED on
unsigned long time = 0;
// called from main loop when we know we had an interrupt
void handleKeypress ()
unsigned int keyValue = 0;
delay (100); // de-bounce before we re-enable interrupts
keyPressed = false; // ready for next time through the interrupt service routine
digitalWrite (ISR_INDICATOR, LOW); // debugging
// Read port values, as required. Note that this re-arms the interrupts.
if (expanderRead (INFTFA))
keyValue |= expanderRead (INTCAPA) << 8; // read value at time of interrupt
if (expanderRead (INFTFB))
keyValue |= expanderRead (INTCAPB); // port B is in low-order byte
Serial.println ("Button states");
Serial.println ("0 1");
Serial.println ("0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5");
// display which buttons were down at the time of the interrupt
for (byte button = 0; button < 16; button++)
// this key down?
if (keyValue & (1 << button))
Serial.print ("1 ");
Serial.print ("0 ");
} // end of for each button
Serial.println ();
// if a switch is now pressed, turn LED on (key down event)
if (keyValue)
time = millis (); // remember when
digitalWrite (ONBOARD_LED, HIGH); // on-board LED
} // end if
} // end of handleKeypress
void loop ()
// was there an interrupt?
if (keyPressed)
handleKeypress ();
// turn LED off after 500 ms
if (millis () > (time + 500) && time != 0)
digitalWrite (ONBOARD_LED, LOW);
time = 0;
} // end if time up
} // end of loop
