I have connect the MCP23017 to Arduino and it's working fine. but I want to use atmega328p on breadboard. this is the link which I referred for atmega328p on breadboard. "https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoToBreadboard". I connected MCP23017 and atmega328p on breadboard but it is not working. this is rough circuit diagram. and this same connection i have done on breadboard but not working.
This is my code.
#include <Adafruit_MCP23X17.h>
#include <Pushbutton.h>
const uint8_t led[9] = { 2, 3, 4, 5, 6, 7, 8, 9, 10 };
const uint8_t ledPowerandIntervalMode = 11;
const uint8_t btn[9] = { 0, 1, 2, 3, 4, 5, 6, 7, 8 };
const uint8_t btnHorizontalPattern = 9;
const uint8_t btnVerticalPattern = 10;
const uint8_t btnRandomPattern = 11;
const uint8_t btnStopPattern = 12;
const uint8_t btnIntervalSelection = 13;
const uint8_t buzzer = 12;
Adafruit_MCP23X17 mcp;
Pushbutton *btnObj[9],
btnHorizontalPatternObj(btnHorizontalPattern),
btnVerticalPatternObj(btnVerticalPattern),
btnRandomPatternObj(btnRandomPattern),
btnStopPatternObj(btnStopPattern),
btnIntervalSelectionObj(btnIntervalSelection);
const uint16_t horizontalPatternSequence[] = {
0b0000000000000001,
0b0000000000000010,
0b0000000000000100,
0b0000000000001000,
0b0000000000010000,
0b0000000000100000,
0b0000000001000000,
0b0000000010000000,
0b0000000100000000,
const uint16_t verticalPatternSequence[] = {
0b0000000000000001,
0b0000000000001000,
0b0000000001000000,
0b0000000000000010,
0b0000000000010000,
0b0000000010000000,
0b0000000000000100,
0b0000000000100000,
0b0000000100000000,
byte pattern = 0;
static byte previousOnLed, btnOff;
uint8_t actualIndex = 0;
byte btnIntervalSelectionCounter = 0;
unsigned long previousMillis;
long interval_;
bool btnHorizontalPatternFlag = false,
btnVerticalPatternFlag = false,
btnRandomPatternFlag = false,
btnStopPatternFlag = false,
btnIntervalSelectionFlag = true,
skipInterval = true;
bool btnFlag[9] = { false, false, false, false, false, false, false, false, false };
if (!mcp.begin_I2C(0x20)) {
Serial.println("Error");
while (1)
digitalWrite(ledPowerandIntervalMode, HIGH);
randomSeed(analogRead(A0));
for (int i = 0; i <= 8; i++) {
btnObj[i] = new Pushbutton(btn[i]);
pinMode(led[i], OUTPUT);
mcp.pinMode(btn[i], INPUT);
pinMode(ledPowerandIntervalMode, OUTPUT);
pinMode(buzzer, OUTPUT);
mcp.pinMode(btnHorizontalPattern, INPUT);
mcp.pinMode(btnVerticalPattern, INPUT);
mcp.pinMode(btnRandomPattern, INPUT);
mcp.pinMode(btnStopPattern, INPUT);
mcp.pinMode(btnIntervalSelection, INPUT);
if (btnIntervalSelectionObj.getSingleDebouncedPress(mcp) && btnIntervalSelectionFlag == true) {
tone(buzzer, 2500, 150);
btnIntervalSelectionCounter++;
btnHorizontalPatternFlag = btnVerticalPatternFlag = btnRandomPatternFlag = btnStopPatternFlag = true;
if (btnIntervalSelectionCounter == 6) {
btnIntervalSelectionCounter = 1;
intervalSelection(btnIntervalSelectionCounter);
Serial.println(interval_);
patternSelection();
switch (pattern) {
case 'H':
HandVPattern(currentMillis, horizontalPatternSequence);
if (btnObj[btnOff]->getSingleDebouncedPress(mcp) && btnFlag[btnOff] == true) {
digitalWrite(led[btnOff], LOW);
case 'V':
HandVPattern(currentMillis, verticalPatternSequence);
case 'R':
randomPattern(currentMillis);
case 'S':
stopPattern();
void intervalSelection(byte btnIntervalSelectionCounter) {
switch (btnIntervalSelectionCounter) {
case 1:
interval_ = 60000;
case 2:
interval_ = 30000;
case 3:
interval_ = 15000;
case 4:
interval_ = 10000;
case 5:
interval_ = 5000;
void patternSelection() {
if (btnHorizontalPatternObj.getSingleDebouncedPress(mcp) && btnHorizontalPatternFlag == true) {
pattern = 'H';
btnVerticalPatternFlag = btnRandomPatternFlag = btnIntervalSelectionFlag = false;
if (btnVerticalPatternObj.getSingleDebouncedPress(mcp) && btnVerticalPatternFlag == true) {
pattern = 'V';
btnHorizontalPatternFlag = btnRandomPatternFlag = btnIntervalSelectionFlag = false;
if (btnRandomPatternObj.getSingleDebouncedPress(mcp) && btnRandomPatternFlag == true) {
pattern = 'R';
btnHorizontalPatternFlag = btnVerticalPatternFlag = btnIntervalSelectionFlag = false;
if (btnStopPatternObj.getSingleDebouncedPress(mcp) && btnStopPatternFlag == true) {
pattern = 'S';
btnHorizontalPatternFlag = btnVerticalPatternFlag = btnRandomPatternFlag = btnIntervalSelectionFlag = true;
void HandVPattern(unsigned long currentMillis, const uint16_t patternSequence[]) {
if (currentMillis - previousMillis >= interval_ || skipInterval == true) {
skipInterval = false;
for (uint8_t i = 0; i < 9; i++) {
if (patternSequence[actualIndex] & (1 << i)) {
btnOff = i;
btnFlag[i] = true;
digitalWrite(led[i], HIGH);
btnFlag[i] = false;
digitalWrite(led[i], LOW);
actualIndex++;
if (actualIndex >= 9) {
actualIndex = 0;
void randomPattern(unsigned long currentMillis) {
int randomNum = randomNumGenerator();
btnOff = randomNum;
btnFlag[randomNum] = true;
btnFlag[previousOnLed] = false;
digitalWrite(led[previousOnLed], LOW);
digitalWrite(led[randomNum], HIGH);
previousOnLed = randomNum;
void stopPattern() {
btnFlag[i] = false;
actualIndex = 0;
int randomNumGenerator() {
static int randomNum = random(0, 9);
int randomNum_ = random(0, 9 - 1);
if (randomNum_ >= randomNum) {
randomNum_++;
randomNum = randomNum_;
return randomNum;
Circuit diagram
