I believe your goal in this test is to check if sensor is solid and consistent. If you have other plans to build on, I am glad to pivot to your base work from that. But below is test I setup to start “small and expand” in my testing.
PS: I dug around and found .1u ceramic capacitor (104) and put it on bread board between pins 9 and 10. So each MCP has noted capacitor setup.
My foundation code that has solid test. where each of the 16 outputs with the sensor are solid and consistent.
#include <SPI.h>
// MCP23S17 SPI settings
const uint8_t CS_PIN = 2; // Chip select pin for Group 1 (CS0)
const uint8_t MCP_ADDR = 0x20; // Address 0 (A0=A1=A2=GND)
// MCP23S17 registers (for bank=0 mode)
#define IODIRA 0x00 // I/O direction for Port A (1=input, 0=output)
#define IODIRB 0x01 // I/O direction for Port B
#define GPPUA 0x0C // Pull-up enable for Port A
#define GPPUB 0x0D // Pull-up enable for Port B
#define GPIOA 0x12 // Input state for Port A
#define GPIOB 0x13 // Input state for Port B
// Track previous states for change detection
uint8_t lastStateA = 0xFF; // Assume all HIGH (no magnet) initially
uint8_t lastStateB = 0xFF;
SPI.begin();
pinMode(CS_PIN, OUTPUT);
digitalWrite(CS_PIN, HIGH); // Deselect chip
// Initialize MCP23S17
writeRegister(IODIRA, 0xFF); // All GPA0-GPA7 as inputs
writeRegister(IODIRB, 0xFF); // All GPB0-GPB7 as inputs
writeRegister(GPPUA, 0xFF); // Enable pull-ups on GPA0-GPA7
writeRegister(GPPUB, 0xFF); // Enable pull-ups on GPB0-GPB7
// Read both ports
uint8_t stateA = readRegister(GPIOA); // GPA0-GPA7
uint8_t stateB = readRegister(GPIOB); // GPB0-GPB7
// Check for changes on Port A
for (int i = 0; i < 8; i++) {
bool currentBit = (stateA >> i) & 0x01; // Current state of GPA[i]
bool lastBit = (lastStateA >> i) & 0x01; // Previous state of GPA[i]
if (currentBit != lastBit) {
Serial.print("MCP000-GPA");
Serial.print(i);
Serial.print("-");
Serial.print(currentBit ? "1" : "0");
Serial.println(currentBit ? " - No Magnet" : " - Magnet Detected");
// Check for changes on Port B
bool currentBit = (stateB >> i) & 0x01; // Current state of GPB[i]
bool lastBit = (lastStateB >> i) & 0x01; // Previous state of GPB[i]
Serial.print("MCP000-GPB");
Serial.print(i);
Serial.print("-");
// Update previous states
lastStateA = stateA;
lastStateB = stateB;
delay(100); // Poll every 100ms for debouncing
// Write to MCP23S17 register
void writeRegister(uint8_t reg, uint8_t value) {
digitalWrite(CS_PIN, LOW);
SPI.transfer(MCP_ADDR << 1); // Write command (address + write bit)
SPI.transfer(reg); // Register address
SPI.transfer(value); // Data
// Read from MCP23S17 register
uint8_t readRegister(uint8_t reg) {
SPI.transfer((MCP_ADDR << 1) | 0x01); // Read command (address + read bit)
uint8_t value = SPI.transfer(0x00); // Read data
return value;
Test Output Serial. Very consistent.
MCP000-GPA7-0 - Magnet Detected
MCP000-GPA7-1 - No Magnet
<snip other 14 tests>
MCP000-GPB0-0 - Magnet Detected
MCP000-GPB0-1 - No Magnet
Upon that is my next phase of the test where I add the second “bank” of MCPs
# Wiring Diagram for t02
Arduino UNO R4 WiFi
| D2 ---- CS0 ---- Group 1 (8x MCP23S17-E, Addr 0-7) --+-- A3144 Sensors (128)
| D3 ---- CS1 ---- Group 2 (8x MCP23S17-E, Addr 0-7) --+-- A3144 Sensors (128)
| D4 ---- CS2 ---- Group 3 (8x MCP23S17-E, Addr 0-7) --+-- A3144 Sensors (128)
| D5 ---- CS3 ---- Group 4 (8x MCP23S17-E, Addr 0-7) --+-- A3144 Sensors (128)
| D6 ---- CS4 ---- Group 5 (8x MCP23S17-E, Addr 0-7) --+-- A3144 Sensors (64 used)
| D11 ---- MOSI ----+------------------------------------+
| D12 ---- MISO ----+------------------------------------+
| D13 ---- SCK ----+------------------------------------+
| +5V ---- VDD, /RESET (via 10kΩ) ----------------------+
| GND ---- VSS -----------------------------------------+
Group N (8x MCP23S17-E):
| MCP23S17-E (Addr 0) | Pin 15 (A0)=GND, Pin 16 (A1)=GND, Pin 17 (A2)=GND
| MCP23S17-E (Addr 1) | Pin 15 (A0)=+5V, Pin 16 (A1)=GND, Pin 17 (A2)=GND
| MCP23S17-E (Addr 7) | Pin 15 (A0)=+5V, Pin 16 (A1)=+5V, Pin 17 (A2)=+5V
| Pin 9 (VDD) ---- +5V
| Pin 10 (VSS) --- GND
| Pin 18 (/RESET) -+-- 10kΩ -- +5V
| Pin 11 (/CS) ---- Arduino DN (CSN, e.g., D2 for Group 1)
| Pin 12 (SCK) ---- Arduino D13
| Pin 13 (SI) ----- Arduino D11 (MOSI)
| Pin 14 (SO) ----- Arduino D12 (MISO)
| GPA0-GPA7, GPB0-GPB7 ---- A3144 Sensors (open-collector, internal pull-ups)
*Note: 0.1uF capacitor noted as required. Likely to keep voltage consistent as this is prone to noise for readings that are consistent. Need to RTFM a bit on this.
I wired up in diagram what would be bank CS1, MCP000. Pins on MCP 14-12 on same breadboard line as CS0, MCP000. MCP pin 18 over to same breadboard line to use common 10kohm resistor . In theory pin D2 is group CS0 with one MCP000, pin D3 is group CS1 with MCP000
#include <SPI.h>
const uint8_t CS_PINS[2] = {2, 3}; // CS pins: CP0 (D2), CP1 (D3)
const uint8_t MCP_ADDR = 0x20; // Address 0 (A0=A1=A2=GND) for both MCPs
const char* GROUP_NAMES[2] = {"CP0", "CP1"}; // Group identifiers
// Track previous states for change detection (one per MCP)
uint8_t lastStateA[2] = {0xFF, 0xFF}; // Assume all HIGH (no magnet) initially
uint8_t lastStateB[2] = {0xFF, 0xFF};
SPI.begin();
// Initialize CS pins
for (int i = 0; i < 2; i++) {
pinMode(CS_PINS[i], OUTPUT);
digitalWrite(CS_PINS[i], HIGH); // Deselect chip
// Initialize both MCP23S17 chips
writeRegister(i, IODIRA, 0xFF); // All GPA0-GPA7 as inputs
writeRegister(i, IODIRB, 0xFF); // All GPB0-GPB7 as inputs
writeRegister(i, GPPUA, 0xFF); // Enable pull-ups on GPA0-GPA7
writeRegister(i, GPPUB, 0xFF); // Enable pull-ups on GPB0-GPB7
// Read both MCPs
for (int chip = 0; chip < 2; chip++) {
uint8_t stateA = readRegister(chip, GPIOA); // GPA0-GPA7
uint8_t stateB = readRegister(chip, GPIOB); // GPB0-GPB7
bool lastBit = (lastStateA[chip] >> i) & 0x01; // Previous state
Serial.print(GROUP_NAMES[chip]);
Serial.print("-MCP000-GPA");
Serial.print(i);
bool lastBit = (lastStateB[chip] >> i) & 0x01; // Previous state
Serial.print("-MCP000-GPB");
Serial.print(i);
lastStateA[chip] = stateA;
lastStateB[chip] = stateB;
// Write to MCP23S17 register for specified chip
void writeRegister(uint8_t chip, uint8_t reg, uint8_t value) {
digitalWrite(CS_PINS[chip], LOW);
digitalWrite(CS_PINS[chip], HIGH);
// Read from MCP23S17 register for specified chip
uint8_t readRegister(uint8_t chip, uint8_t reg) {
return value;
Serial.print(i);
return value;
Everything is solid until I plug in CS1, MCP000 pin 11 (CSS) .. I don’t even have to plug it into anything. just wire in and wiggle it and I get outputs like
MCP000-GPB6 - Magnet Detected
MCP000-GPB7 - Magnet Detected
MCP000-GPA7 - Magnet Detected
MCP000-GPA0 - No Magnet
MCP000-GPA1 - No Magnet
MCP000-GPA2 - No Magnet
MCP000-GPA3 - No Magnet
MCP000-GPA4 - No Magnet
MCP000-GPA5 - No Magnet
if I pull wire out. I do still get consistent reads from CS0, MCP000.
So my question is:
You mentioned push based hall effect sensor. Can you give me RTFM location for this?
On paper the design of shared SO,SI,SCK with each channel having pin for each “group”, seems logical. scan would cycle through each MCP by address 0-7 from each CS “group” channel, and during that time slice. But peiece I am not sure on is if this is a “pull” how does it shut off/exclude the signals sent. I guess CS is pin to say “your my focus” (all others state low and go to sleep on outputs), then within that MCP group, cycle via ID through MCP0-7 and each sub 1-16 scans. So in theory.. this works… Hopeing this is just a wire / noise control adjustment I need to make vs scrap design.
Thanks as always for wisdom.
