Hi all...
ok, full disclosure, not 100% Arduino based, but guessing most here will know electronics better than me.
Transducer is 5V DC input, output is 0-3.3V
MCP3008 is 2.5 - 5.8V
Want to power the MCP => VCC and vRef wit 3.3V
Power the Transducer via a separate 5V.
All grounds are to be connected,
I'm using Rpi platform, simply because I have allot of them and comfortable with Python.
At the moment I've figured out I can introduce more stability on the MCP by grounding the unused analog inputs.
I am however having measurements that fluctuates like a wave... See below...
See the first column, that was with the transducer powered by 3.3V
| 412 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 0 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 116 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 512 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 597 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 581 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 579 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 582 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 459 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 0 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 38 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 588 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 585 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 584 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 287 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 36 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 430 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 601 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 587 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 578 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 433 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 178 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 586 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 598 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 575 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 254 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 0 | 0 | 0 | 0 | 0 | 988 | 0 | 0 |
| 43 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 481 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 584 | 0 | 0 | 0 | 0 | 989 | 0 | 0 |
| 572 | 0 | 0 | 0 | 0 | 990 | 0 | 0 |
| 0 | 0 | 0 | 0 | 0 | 808 | 0 | 0 |
| 0 | 0 | 0 | 0 | 0 | 576 | 0 | 0 |
| 220 | 0 | 0 | 0 | 0 | 571 | 0 | 0 |
| 591 | 0 | 0 | 0 | 0 | 572 | 0 | 0 |
| 608 | 0 | 0 | 0 | 0 | 571 | 0 | 0 |
| 596 | 0 | 0 | 0 | 0 | 571 | 0 | 0 |
Got the below when I powered it by 5V, channel 6 is a 10k pot powered by the 3.3V line.
Need to retry and install the sensor in test pipe, power by 5V again and see if this 1023 (lying on desk with 0 pressure) translates to a stable reading when I add water to test pipe...
| 1023 | 3 | 2 | 2 | 2 | 740 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 739 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 738 | 3 | 3 |
| 1023 | 2 | 2 | 2 | 2 | 731 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 743 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 745 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 741 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 733 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 744 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 747 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 746 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 700 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 522 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 430 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 426 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 427 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 347 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 94 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 50 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 93 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 290 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 514 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 608 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 617 | 3 | 3 |
| 1023 | 3 | 2 | 2 | 2 | 620 | 3 | 3 |
