MCP42010 digital POT
Can you use these as variable resistors, with connections to either terminal A or B and the wiper terminal?
All the examples I see seem to apply Vcc and GND to the terminal pins and a LED to GND on the wiper pin.
I am trying to use it to control the frequency of a 555 timer, with R1 as PA0->PW0
Either way I am struggling to change the resistance. Seems to unpredictably shift between 10k and 5k no matter what value I send to the chip.
Hi, @gregaryb
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
I'll do that tomorrow. Bed time here. But to begin with can you use the devices with two of the pins from a channel and as a variable resistor? Or not?
I just assumed you could even though I have not found any examples of others using them in that way.
Yes. But you must tell us all we asked so we know what you have already and spot any mistakes you have made.
Things like what sort of Arduino you are using, and how it is wired up.
When you start to cooperate with us we can answer your questions. Until you buck your ideas up we can do nothing but guess.
It is all up to you.
In this example you would connect your wiper pin to one end of the pot.
But note you can't use voltages higher than 5v, to the line that says 5v to 15v with that sort of digital pot.
Try a DS3502 that will cope with up to 15V. Make sure you wire it up correctly so ask us first.
Powering the 555 with 5V anyway
You should be able to follow the wiring from this photo as you can zoom in close.
Yellow is MOSI
White is MISO
Green is SCK
Blue is SS or CS
There is a bit of a perspective issue with the wires plugged into the Mega. It looks like they are plugged into pin 48. But they are not. I used pins 50-53 as per this.
100nF decoupling cap across the 555 pins 1 and 8.
10nF cap on 555 pin 5
12nF cap on 555 pin 3 - that is actually in the wrong spot, should be pin 2 or 6 which are connected.
But that wiring error is irrelevant for the moment because I am using my multimeter to measure the resistance across digital POT pins PA0 and PW0, PB0 and pW0, PA1 and PW1, PB1 and PW1.
And I am not succeeding in changing any resistances.
#include "MCP4XXXXPOT.h"
#include "debug.h"
CMCP42010 mcp41xxxDigitPot(53, 255, 255);
#define CHANNEL 0
void setResistance(const uint16_t nResistance)
  Serial.print(F("Setting resistance to "));
  Serial.print(nResistance);
  Serial.println(F(" ohms..."));
  mcp41xxxDigitPot.setOhm(CHANNEL, nResistance);
  Serial.print(F("Calculated frequency "));
  double dFrequency = 0.72 / (nResistance * (6.8 / 1000000000));
  if (dFrequency > 1000.0)
    Serial.print(dFrequency / 1000.0);
    Serial.println(F("kHz"));
    Serial.print(dFrequency);
    Serial.println(F("Hz"));
  while (!Serial);
  mcp41xxxDigitPot.begin(RES_AW, 0);
  //setResistance(MCP_POT_MAX_VALUE);
  Serial.println(F("Setup complete!"));
  if (Serial.available())
    uint16_t nResistanceOhms = Serial.parseInt();
    setResistance(nResistanceOhms);
MCP4XXXXPOT.cpp
#line 2 "MCP4XXXXPOT.cpp"
//  see page 18 datasheet
#define MCP42XXX_IGNORE_CMD        0x00
#define MCP42XXX_WRITE_CMD         0x10
#define MCP42XXX_SHUTDOWN_CMD      0x20
#define MCP42XXX_NONE_CMD          0x30
  //       HARDWARE SPI
CMCP42XXX::CMCP42XXX(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
  m_nNumChannels = 2;
  m_nSSPin = nSSPin;
  m_nResetPin = nResetPin;
  m_nShutDownPin = nShutDownPin;
  m_nMOSIPin = 255;
  m_nSCKPin = 255;
  m_bIsHWSPI = true;
  m_pSPI = m_pSPI;
//       SOFTWARE SPI
CMCP42XXX::CMCP42XXX(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
  m_nNumChannels = 2;
  m_nSSPin = nSSPin;
  m_nMOSIPin = nMOSIPin;
  m_nSCKPin = nSCKPin;
  m_bIsHWSPI = false;
  m_pSPI = NULL;
void CMCP42XXX::begin(const enum_pot_use_type eUseType, const uint8_t nValue)
  m_eUseType = eUseType;
  pinMode(m_nSSPin, OUTPUT);
  digitalWrite(m_nSSPin, HIGH);
  pinMode(m_nResetPin, OUTPUT);
  digitalWrite(m_nResetPin, HIGH);
  pinMode(m_nShutDownPin, OUTPUT);
  digitalWrite(m_nShutDownPin, HIGH);
  setSPIspeed(1000000);
  if (m_bIsHWSPI)
    m_pSPI->end();
    m_pSPI->begin();
    delay(1);
    pinMode(m_nMOSIPin, OUTPUT);
    pinMode(m_nSCKPin,   OUTPUT);
    digitalWrite(m_nMOSIPin, LOW);
    digitalWrite(m_nSCKPin,   LOW);
  reset(nValue);
void CMCP42XXX::reset(const uint8_t nValue)
  digitalWrite(m_nResetPin, LOW);
  setValue(nValue);  //  set all to same nValue.
//  SET VALUE
bool CMCP42XXX::setValue(uint8_t nValue)
  if (m_eUseType == RES_AW)
    nValue = MCP_POT_MAX_VALUE - nValue;
  m_arrayChannels[0] = nValue;
  m_arrayChannels[1] = nValue;
  updateDevice(2, nValue, MCP42XXX_WRITE_CMD);
  return true;
bool CMCP42XXX::setValue(const uint8_t nChannel, uint8_t nValue)
  if (nChannel >= m_nNumChannels)
    return false;
  m_arrayChannels[nChannel] = nValue;
  updateDevice(nChannel, nValue, MCP42XXX_WRITE_CMD);
  return true;
uint8_t CMCP42XXX::getValue(const uint8_t nChannel)
    return 0;
  return m_arrayChannels[nChannel];
//  OHM - wrappers
void CMCP42XXX::setMaxOhm(const uint32_t nMaxOhms)
  m_nMaxOhm = nMaxOhms;
uint32_t CMCP42XXX::getMaxOhm()
  return m_nMaxOhm;
void CMCP42XXX::setOhm(const uint8_t nChannel, uint32_t nOhms)
    nOhms = getMaxOhm() - nOhms;
  setValue(nChannel, round(nOhms * 255.0 / m_nMaxOhm));
uint32_t CMCP42XXX::getOhm(const uint8_t nChannel)
  return round(getValue(nChannel) * (m_nMaxOhm / 255.0));
//  OTHER
uint8_t CMCP42XXX::pmCount()
  return m_nNumChannels;
void CMCP42XXX::powerOn()
void CMCP42XXX::powerOff()
  digitalWrite(m_nShutDownPin, LOW);
bool CMCP42XXX::isPowerOn()
  return digitalRead(m_nShutDownPin) == HIGH;
//  SPI
void CMCP42XXX::setSPIspeed(const uint32_t nSpeed)
  m_nSPISpeed = nSpeed;
  _spi_settings = SPISettings(m_nSPISpeed, MSBFIRST, SPI_MODE0);
uint32_t CMCP42XXX::getSPIspeed()
  return m_nSPISpeed;
void CMCP42XXX::setSWSPIDelay(const uint16_t nDelay)
  m_nSPIDelay = nDelay;
uint16_t CMCP42XXX::getSWSPIdelay()
  return m_nSPIDelay;
bool CMCP42XXX::usesHWSPI()
  return m_bIsHWSPI;
//  PROTECTED
void CMCP42XXX::updateDevice(const uint8_t nChannel, const uint8_t nValue, const uint8_t nCommand)
  uint8_t nTempCommand = nCommand;
  if (nChannel == 0)
    nTempCommand |= 1;   //  01
  if (nChannel == 1)
    nTempCommand |= 2;   //  10
  if (nChannel == 2)
    nTempCommand |= 3;   //  11 => both potentiometers
  //  otherwise ignore
  digitalWrite(m_nSSPin, LOW);
  if (m_bIsHWSPI)
    m_pSPI->beginTransaction(_spi_settings);
    m_pSPI->transfer(nTempCommand);
    m_pSPI->transfer(nValue);
    m_pSPI->endTransaction();
  else      //  Software SPI
    swSPI_transfer(nTempCommand);
    swSPI_transfer(nValue);
//  MSBFIRST
void  CMCP42XXX::swSPI_transfer(const uint8_t nVal)
  //  split m_nSPIDelay in equal dLow and dHigh
  //  dLow should be longer one when m_nSPIDelay = odd.
  uint16_t dHigh = m_nSPIDelay / 2;
  uint16_t dLow  = m_nSPIDelay - dHigh;
  uint8_t nSCKPin = m_nSCKPin;
  uint8_t nMOSIPin = m_nMOSIPin;
  //  MSBFIRST
  for (uint8_t mask = 0x80; mask; mask >>= 1)
    digitalWrite(nMOSIPin,(nVal & mask));
    digitalWrite(nSCKPin, HIGH);
    if (dHigh > 0)
      delayMicroseconds(dHigh);
    digitalWrite(nSCKPin, LOW);
    if (dLow > 0)
      delayMicroseconds(dLow);
//  DERIVED CLASSES MCP41000 SERIES
CMCP41010::CMCP41010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
        :CMCP42XXX(nSSPin, nResetPin, nShutDownPin, pSPI)
  m_nNumChannels = 1;
  m_nMaxOhm  = 10000;
CMCP41010::CMCP41010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
        :CMCP42XXX(nSSPin, nResetPin, nShutDownPin, nMOSIPin, nSCKPin)
  m_nNumChannels = 1;
  m_nMaxOhm  = 10000;
CMCP41050::CMCP41050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
  m_nNumChannels = 1;
  m_nMaxOhm  = 50000;
CMCP41050::CMCP41050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
  m_nNumChannels = 1;
  m_nMaxOhm  = 10000;
CMCP41100::CMCP41100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
  m_nNumChannels = 1;
  m_nMaxOhm  = 100000;
CMCP41100::CMCP41100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
  m_nNumChannels = 1;
  m_nMaxOhm  = 100000;
//  DERIVED CLASSES MCP42000 SERIES
CMCP42010::CMCP42010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
  m_nNumChannels = 2;
  m_nMaxOhm  = 10000;
CMCP42010::CMCP42010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
  m_nNumChannels = 2;
  m_nMaxOhm  = 10000;
CMCP42050::CMCP42050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
  m_nNumChannels = 2;
  m_nMaxOhm  = 50000;
CMCP42050::CMCP42050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
  m_nNumChannels = 2;
  m_nMaxOhm  = 50000;
CMCP42100::CMCP42100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI)
  m_nNumChannels = 2;
  m_nMaxOhm  = 100000;
CMCP42100::CMCP42100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin)
  m_nNumChannels = 2;
  m_nMaxOhm  = 100000;
MCP4XXXXPOT.h
#line 2 "MCP4XXXXPOT.h"
#pragma once
#include "Arduino.h"
#include "SPI.h"
#ifndef MCP_POT_MIDDLE_VALUE
#define MCP_POT_MIDDLE_VALUE          128
#endif
#ifndef MCP_POT_MAX_VALUE
#define MCP_POT_MAX_VALUE             255
#endif
#ifndef __SPI_CLASS__
  //  MBED must be tested before RP2040
  #if defined(ARDUINO_ARCH_MBED)
  #define __SPI_CLASS__   SPIClass
  #elif defined(ARDUINO_ARCH_RP2040)
  #define __SPI_CLASS__   SPIClassRP2040
  #else
  #endif
#endif
typedef enum{POT_AWB, RES_AW, RES_WB} enum_pot_use_type;
class CMCP42XXX
  public:
    //       HARDWARE SPI
    CMCP42XXX(const uint8_t nSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    //       SOFTWARE SPI
    CMCP42XXX(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin);
    void     begin(const enum_pot_use_type eUseType, uint8_t nValue = MCP_POT_MIDDLE_VALUE);
    void     reset(uint8_t nValue = MCP_POT_MIDDLE_VALUE);
    //       set both potmeters to the same value
    bool     setValue(uint8_t nValue);
    //       set single potmeter, pm = 0 or 1
    bool     setValue(uint8_t nChannel, const uint8_t nValue);
    uint8_t  getValue(const uint8_t nChannel = 0);
    //  EXPERIMENTAL
    //  Ohm wrappers
    void     setMaxOhm(const uint32_t nOhms);
    uint32_t getMaxOhm();
    void     setOhm(const uint8_t nChannel, uint32_t nResistanceOhms);
    uint32_t getOhm(const uint8_t nChannel);
    //       speed in Hz
    void     setSPIspeed(uint32_t speed);
    uint32_t getSPIspeed();
    void     setSWSPIDelay(uint16_t del = 0);
    uint16_t getSWSPIdelay();
    //       MISC
    uint8_t  pmCount();
    void     powerOn();
    void     powerOff();
    bool     isPowerOn();
    //       debugging
    bool     usesHWSPI();
  protected:
    enum_pot_use_type m_eUseType;
    uint8_t  m_nMOSIPin;
    uint8_t  m_nSCKPin;
    uint8_t  m_nSSPin;
    uint8_t  m_nResetPin;
    uint8_t  m_nShutDownPin;
    uint8_t  m_arrayChannels[2];
    uint8_t  m_nNumChannels;
    uint32_t m_nMaxOhm;
    void     updateDevice(const uint8_t nChannel, const uint8_t nValue, const uint8_t nCommand);
    void     swSPI_transfer(uint8_t value);
    bool     m_bIsHWSPI;
    uint16_t m_nSPIDelay = 0;
    uint32_t m_nSPISpeed;
    __SPI_CLASS__ *m_pSPI;
    SPISettings     _spi_settings;
//  DERIVED CLASSES CMCP41000 SERIES
class CMCP41010 : public CMCP42XXX
  public:
    CMCP41010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    CMCP41010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPin);
class CMCP41050 : public CMCP42XXX
  public:
    CMCP41050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    CMCP41050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPpin);
class CMCP41100 : public CMCP42XXX
  public:
    CMCP41100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    CMCP41100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPpin);
//  DERIVED CLASSES CMCP42000 SERIES
class CMCP42010 : public CMCP42XXX
  public:
    CMCP42010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    CMCP42010(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPpin);
class CMCP42050 : public CMCP42XXX
  public:
    CMCP42050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    CMCP42050(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPpin);
class CMCP42100 : public CMCP42XXX
  public:
    CMCP42100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const __SPI_CLASS__ *pSPI = (__SPI_CLASS__*)&SPI);
    CMCP42100(const uint8_t nSSPin, const uint8_t nResetPin, const uint8_t nShutDownPin, const uint8_t nMOSIPin, const uint8_t nSCKPpin);
And this is why we ask for a clear annotated circuit (schematic diagram.
Ambiguity doesn’t appear in any electronics dictionary.
It never ceases to amaze me how little people who come here looking for free advice are willing to invest in the process.
A picture, a circuit diagram and a sketch is worth a thousand words and can save a thousand ill informed posts.
How much CURRENT are you trying to draw through the digipot?
The problem is I could give you an idealised circuit diagram.
That may or may not reflect the reality of what I actually have on my bread board.
For example that is my circuit for the 555 part, however I realised I had made a mistake on the bread board, in the photo, by connecting the 12nF timing cap in the wrong place on the 555.
If I had given you this idealised circuit alone then how would you have picked up on the fact that my bread board circuit was wrong for the 555 part.
The problem with circuit diagrams is that there are no bloody decent tools out there to create them with that I know of.
And that some people in here won't belly ache about, e.g. Fritzing!
And that has a full array of components.
I am left to do it peicmeal in 'libre writer' or 'word' with what ever photos and screed shots I can piece together.
And then some people belly ache about that too!
Would have thought that people could consider the live photo of the bread board superior given the way I have done it....not with long jumper wires winding all over the place (except the SPI connections)
Unless one of you can put me in the direction of DECENT circuit diagram software that everyone in here will be happy about....
Then this is as good as it is going to get folks.
So please don't moan about the way I have created it.
I am not concerned with the 555 part of the circuit until I get the digital pot working as measured with my multimeter.
This is the intention anyway....unless someone can spot a mistake I have made on my bread board.
Have you got no pencils or pens?
They are magical devices that allow you to create any schematic symbol you like.
If you want something similar only on a computer you need a vector drawing package like the free inkscape. Each time you create a new symbol add it to a drawing that contains just the symbols. Then when working on a specific diagram then just drag out a symbol from this page into your working schematic.
I use MacDraft P.E for this, but it is a payed for application.
Mike it is the 21st century mate.
I think we have moved past pencil and paper decades ago.
Pencil diagrams do not match the clarity that I can acheive with even tedious Libre writer diagrams.
And I am no young whipper snapper myself - 56yo
No we haven't simple as that.
I still draw circuit diagrams by hand before I make one with a drawing package, as it is so much quicker.
Well yes you are :wink: it is all relative. I am 73, and despite my stroke two years which rendered my right hand almost useless I am still drawing the first draft by hand (or rather hands) one to grip the pen (left hand) and one to guide the pen using my next to useless right hand.
By the way the capacitors used with the NE555 seem to be a bit on the small side.
Well remove the LM555 circuit from the pot and then measure it.
Leaving the 555 connected while you measure the resistance, means you are also measuring the parallel resistance of the 555 as well.
From a 68yo, pencil and paper is still current.
I use it regularly in my engineer job to reverse engineer circuits.
Master reverse engineer Ken Sherrif;
And CuriousMarc
And EEvblog...
All the symbol ibraries are in your head and all you need is a pen(cil) and paper, ruler, all non-volatile.
Tom... :smiley: :+1: :coffee: :australia:
You need something like NI Multisim or Fritzing.
But neither seem to have every possible component you might need!
And no easy and convenient ways to create custom components.
Doing it with images in Libre Write is problematic due to the wrapping around the images, and it being hard to get them to sit nicely side by side etc.
Sorry but I don't think pencil diagrams are ever as clear and concise as color diagrams with images created with libre write or whatever.
And I am not going to spend hours drafting a high quality but trivial (and very temporary) circuit diagram on paper. It is not a productive use of time when I can knock up an image based libre write diagram in 5-10 minutes
Have you done your resistance measurements with out the LM555 circuit connected?
