hello, I am using the mcufreind library on my esp32-WROOM devboard. The mcufreind graphics example works on my 8 bit parallel ili9486 uno shield, however i am clueless as to how i get touch working?
my wiring so far:
#define TFT_CS 33
#define TFT_DC 15
#define TFT_RST 32
#define TFT_WR 4
#define TFT_RD 2
#define TFT_D0 12
#define TFT_D1 13
#define TFT_D2 26
#define TFT_D3 25
#define TFT_D4 17
#define TFT_D5 16
#define TFT_D6 27
#define TFT_D7 14
so, anyone know how i can get touch capability without purchasing any extra parts?
i was advised by bodmer in this topic to contact @david_prentice about it
@loveofsparks, Hi,
Right-click on @david_prentice to see his profile, then notice Last Post Oct 18 Seen Oct 26.
This is uncommon, as David used to answer posts frequently. I am a bit anxious.
I assume you have a display with resistive touch without touch controller. MCUFriend_kbv can handle this on UNO, afaik. I think two pins are used for analog measure, and two pins to drive the other side. This should be possible on the ESP32 board with UNO headers as well, but may need jumper wires to analog capable pins, and modifications to the touch part of the library. Take a look at that touch part to see if you are able to modify it.
And please always post links to your devices, so we do not need to guess.
Jean-Marc
hello. yes, i followed this, however it does not work. When wifi is enabled on the esp32 board, some of the analog pins stop working as input pins and only work as output pins as they are used internally by the chip. therefore you have to wire the remaining analog pins that work as inputs to the analog pins that dont work as inputs. when i did this it just stopped working, the screen wouldnt display, its very complicated.
