Touch control with ILI9486 display in conjunction with DOIT ESP32 DEVKIT V1
Hello. Can someone advise me how to activate the touch on the ILI9486? I am using ESP32 DEVKIT V1 and Adafruit_GFX, MCUFRIEND_kbv and TouchScreen libraries.
I am using Arduino IDE 2.2.1 and Visual Studio Code with Platformio IDE
Sorry for the English, but I'm translating it from Czech using Google.
Test MCU Friend parallel display and resistive touchscreen by drawing touch points
on screen, use something pointed for more accuracy
Need this modified Touchscreen library and one of:
- TFT_eSPI        much faster for ESP32, must select correct display driver
- MCUFRIEND_kbv   more display driver support, auto detects display driver
//#define TFT_eSPIlib  // comment out to use MCUFRIEND_kbv
#ifdef TFT_eSPIlib
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
#else
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#endif
#include <TouchScreen.h>
// adjust pressure sensitivity - note works 'backwards'
#define MINPRESSURE 200
#define MAXPRESSURE 1000
// some colours to play with
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
// Either run TouchScreen_Calibr_native.ino and apply results to the arrays below
// or just use trial and error from drawing on screen
// ESP32 coordinates at default 12 bit resolution have range 0 - 4095
// however the ADC cannot read voltages below 150mv and tops out around 3.15V
// so the actual coordinates will not be at the extremes
// each library and driver may have different coordination and rotation sequence
const int coords[] = {3800, 500, 300, 3800}; // portrait - left, right, top, bottom
const int rotation = 0; //  in rotation order - portrait, landscape, etc
const int XP = 27, XM = 15, YP = 4, YM = 14; // default ESP32 Uno touchscreen pins
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#ifdef TFT_eSPIlib
    Serial.println("TFT_eSPI library");
    tft.begin();
#else
    Serial.println("MCUFRIEND_kbv library");
    idDisplay();
#endif
    // screen orientation and background
    String orientation;
    switch (rotation) {
      case 0:
        orientation = "Portrait";
      case 1:
        orientation = "Landscape";
      case 2:
        orientation = "Portrait Inverted";
      case 3:
        orientation = "Landscape Inverted";
    Serial.println(orientation);
    tft.setRotation(rotation);
    tft.fillScreen(BLACK);
    // display touched point with colored dot
    uint16_t pixel_x, pixel_y;
    boolean pressed = Touch_getXY(&pixel_x, &pixel_y, true);
boolean Touch_getXY(uint16_t *x, uint16_t *y, boolean showTouch) {
    TSPoint p = ts.getPoint();
    pinMode(YP, OUTPUT);      //restore shared pins
    pinMode(XM, OUTPUT);
    digitalWrite(YP, HIGH);   //because TFT control pins
    digitalWrite(XM, HIGH);
    bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
    if (pressed) {
      switch (rotation) {
        case 0: // portrait
          *x = map(p.x, coords[0], coords[1], 0, tft.width());
          *y = map(p.y, coords[2], coords[3], 0, tft.height());
        case 1: // landscape
          *x = map(p.y, coords[1], coords[0], 0, tft.width());
          *y = map(p.x, coords[2], coords[3], 0, tft.height());
        case 2: // portrait inverted
          *x = map(p.x, coords[1], coords[0], 0, tft.width());
          *y = map(p.y, coords[3], coords[2], 0, tft.height());
        case 3: // landscape inverted
          *x = map(p.y, coords[0], coords[1], 0, tft.width());
          *y = map(p.x, coords[3], coords[2], 0, tft.height());
      if (showTouch) tft.fillCircle(*x, *y, 2, YELLOW);
    return pressed;
#ifndef TFT_eSPIlib
void idDisplay() {
    // MCUFRIEND_kbv library only
    uint16_t ID = tft.readID();
    Serial.print("TFT ID = 0x");
    Serial.println(ID, HEX);
    if (ID == 0xD3D3) ID = 0x9486; // write-only shield
    tft.begin(ID);
#endif
Here is the connection of the terminals that work for me with the display.
/* Funkční propojení se setup16 ILI9488 parallel
// ESP32 pins used
#define TFT_CS   33  // Chip select control pin
#define TFT_DC   15  // Data Command control pin - must use a pin in the range 0-31
#define TFT_RST  32  // Reset pin
#define TFT_WR    4  // Write strobe control pin - must use a pin in the range 0-31
#define TFT_RD    2
#define TFT_D0   12  // Must use pins in the range 0-31 for the data bus
#define TFT_D1   13  // so a single register write sets/clears all bits
#define TFT_D2   26
#define TFT_D3   25
#define TFT_D4   17
#define TFT_D5   16
#define TFT_D6   27
#define TFT_D7   14
Hey, did you figure out what the problem was??....im struggling. :frowning:
I solved the problem online with Bing's ChatAI and we solved it. I removed the TFT_eSPI library and replaced it with the TouchScreen_kbv library. Here is the touch pin wiring:
// ILI9488
#define YP 15
#define XM 33
#define YM 12
#define XP 13
Using the MCUfriend_kbv library, I found out what display I have. In Setup() I entered the code
"uint16_t ID = tft.readID()" and then had it written to the serial monitor. According to the seller, I should have ILI9486, but the library reported ILI9488, so I adjusted everything to 9488. Then just writing the basic code for the touch:
"boolean Touch_getXY(int16_t *pixel_x, int16_t *pixel_y)
TSPoint_kbv p = ts.getPoint();
digitalWrite(YP, HIGH); //because of TFT control pins
 if (p.z > MINPRESSURE && p.z < MAXPRESSURE); {
   // * pixel_x = map(p.y, TS_LEFT, TS_RT, 0, tft.width()); // ESP32 ILI9486
   // * pixel_y = map(p.x, TS_BOT, TS_TOP, 0, tft.height()); // ESP32 ILI9486
   * pixel_x = map(p.y, TS_LEFT, TS_RT, tft.width(),0); // ESP32 ILI9488
   * pixel_y = map(p.x, TS_BOT, TS_TOP, tft.height(),0); // ESP32 ILI9488
tft.fillCircle(*pixel_x, *pixel_y, 2, TFT_GREENYELLOW)} // render touch point.
Everything I wrote here was advised by ChatAI. Just ask the right questions. I used touch in a clock project.
