Measure pulse with 2 hands like a gym treadmill?
I want to measure a person's pulse in an interactive exhibit.
There are many "fingertip" sensors, such as this
fingertip pulse sensor
but I want to use a metal surface like that seen on gym treadmills.
treadmill pulse sensors
Would it be possible to remove a gym treadmill sensor and hook it up to an Arduino?
Is the technique used in metal gym treadmill sensors different than the finger tip sensors?
This is a link to a replacement part for a treadmill. It only has a single tab on the back, would I need to get two of these?
Could I hook it up to this "Single Lead Heart Rate Monitor" AD8232
from Sparkfun?
AD8232 Monitor
The price on that "replacement part" is absurd. Not sure what the material is but I suspect stainless steel tubing would work OK.
The Sparkfun breakout looks good when I check the design. "Single lead" refers to the multiple different arm and leg connections available on an ECG machine. It always requires two electrodes - actually three including the ground or "right leg" connection. Note that any such equipment you make must not connect in any way to mains power, only run from a 3.7 V LiPo or three or four "AA" batteries.
Paul__B:
Thank you for your reply. I got the sensor and the 3 electrodes. In testing it doesn't seem to work if I hold just the L and R electrodes against my skin. I got it to work occasionally with all three electrodes.
The third "right leg" connection, you said this is ground? Should I connect that to the GND pin on the Arduino?
How do I get it to work like the treadmill at the gym? Is the treadmill using a different sensing technique? There are only two sensors on the treadmill since I only have to hold on with 2 hands right?
