Hi everybody, I want to measure and log the change of the differential pressure over time in short timeintervalls. Now the words "fast" or "short" do not specify numbers so here are the numbers I want to achieve.
Measuring differential pressures that can go above and below a reference-point that has ambient-pressure in the range of
- 0 to -1000 Pa which means a pressure below reference. Minus 1000 Pa and
- 0 to + 1000 Pa which means a pressure above reference. Plus 1000 Pa
Short timeintervals means a measuring once every millisecond = 1000 measurings per second. 1000 samples per second. Resolution of the ADC 10 bit or 12 bit
I have done some initial measurings with a differential sensor from sensirion type SDP6xx. This sensor has two disadvantges: the sensor has a I2C-interface and uses a dynamic measuring principle. Dynamic means the air is really flowing through the sensor. If a hose with a small diameter (2mm) is used the pressure-drop caused by the air flowing is significant even with a hose-length of only 20 cm.
I'm willing to use an external ADC with SPI-interface if this ADC is really fast. And I'm willing to use a microcontroller with a lot of RAM like a Teensy 4.0 to be able to store a lot of samples.
The final purpose of this project is to measure the changes of the pressure in sewer pipes when 10 liters of water fall down a vertical downpipe. In sewer pipes when 10 liters of water fall down a vertical downpipe This falling down causes pressure fluctuations that can be so great that a siphon is sucked empty by the low pressure inside the pipe. I want to record the pressure inside the sewer-pipe over time with a high time-resolution 1000 samples per second.
This Sensirion SDP6xx-Sensors are too slow. So I'm searching for a measuring technology not too expensive. In the range of around 100 Euros that is fast enough.
One idea I have is to use an optical sensor with a single line of pixels and these pixel look at a inclined tube manometer which is filled with black water. I have no idea if this will be fast as 1000 samples per second and if whether due to the inertia of the water the water column will follow the changing pressure fast enough. But it will be interesting what perfomance this measuring system will have.
So does anybody know of such a photo-linesensor? The other basic approach would be a differential pressure-sensor for the range of 0 to +-1000 Pa with analog output connected to a fast ADC.
Or a differential-pressure sensor with SPI-interface. I'm open to totally different approaches and if you know of a sensor with a range only 0 to + 200 Pa or 500 Pa. I Will consider this option too.
Maybe even measuring the water-level in a "probing-siphon" with an optical distance-sensor that has a high sampling rate might be a way. As this is what is happening the sewer-pipes: sucking a siphon empty through the pressure-fall.
best regards Stefan
