Measuring Speed of Light with Arduinos and no moving parts
Thanks, I will go that route, especially since I now tested 10bit ADC versus 12bit:
39c39
<  ADC->ADC_MR |=0x80; // free running
>  ADC->ADC_MR |=0x84; // free running, lowres (10bit)
With 10bit one analog read cycle takes the exact same 21 clock cycles as it does with 12bit.
Do you have a pointer to sample code on how to read a digital pin with 42MHz?
In experiment Due would turn laser one, and then, in very few clock cycles (of 84MHz) first digital pin will go from LOW to HIGH, and then, 4-11 clock cycles later the other digital ping will go from LOW to HIGH.
So lets start with just monitoring a single laser sensor pin:
That sensor OUT pin is either LOW or HIGH, do you mean I should connect it to MISO pin of SPI?
You said MOSI pin, where should that get connected to (sensor module only has VCC, GND and OUT)?
Hermann.
HermannSW:
39c39
![](https://stamm-wilbrandt.de/en/forum/laser.sensor.module.png)
Hermann.
Spi is a serial protocol, it usually uses 4 pins:
CLK: clock pulse, this gives the frequency of the serial data. Whenever the pulse goes from high to low, or low to high (it's configurable), it will send and receive a bit on its lines
CS: a pin that's set to high when a device has to listen to the SPI
MOSI: Master Out, Slave In. This pin is your due sending data to the SPI device
MISO: Master In, Slave Out. This pin is your due receiving data from an spi device.
Now ofcourse we don't have an spi device in this case, so we ignore the CLK pin & the CS pin, and will kind of abuse this port for some other end. What does this mean: We now have 2 pins: MISO & MOSI which we have very high speed control over. The MISO pin will be polled by the microcontroller at 42Mhz, and that data will be written to the memory by the DMA. And for the MOSI pin you can set data at the same speed, so you can toggle your laser very precisely, and that data also comes from your memory, from where the DMA reads.
So in this case you'd want to connect your laser to the MOSI pin (with whatever you need in between so that the pin isn't overloaded).
And the output pin of your sensor indeed goes to the MISO pin of the spi, as this is the pin that will get read a lot.
How to do this on the DUE: you'll have to start googling, there are libraries that use DMA SPI on the due, so you should be able to find info & examples. But personally i've been using another microcontroller and know the DMA from that one, but have no experience with the DUE yet.
Hello there
The SPI solution proposed by racemaniac with SPI AHB DMA is clearly the fastest method , although Peripheral to Memory AHB DMA is a bit tricky to implement. It seems that by chance a library exists (with 1 master and 2 slaves in your case ?).
I noticed 2 details in your trials with ADC.
1/ You tried the 10 bits resolution, but the correct implementation is this one (datasheet 43.7.2):
ADC-ADC_MR = ADC_MR_FREERUN_ON | ADC_MR_LOWRES_BITS_10;
With ADC_MR_FREERUN_ON | ADC_MR_LOWRES_BITS_10 = 0x80 | 0x10 = 0x90
I don't know if it changes something but should be tried.
2/And if I understand your manip, you observed a 21 clock cycles offset after the rising edge, which seems logic because the 12 bits resolution takes 20 clock cycles, plus one to register by the PDC, and this rising edge comes (512 + 6) Half Words after PDC starting, right ?
Suppose this was done when your sensor was at location of sensor 1, now when you place your sensor at the location of sensor 2 and do the manip again, you will observe a rising edge coming after (512 + 6 + X) Half Words.
So when you subtract the 2 results, the offset is discarded, including the 21 clock cycles , rest the X Half Words. And thanks to calibration, you know the timing correspondence.
Thanks for correcting me on 1/, I did retest with 0x90 vs 0x80 and there was no difference in timing. I did measure from "adc_init()" until after the 1st block was converted "while(obufn==bufn);", 35822 clock cycles in both cases.
Let me clarify on 2/, I did not test with laser light yet, as said before I just have a connection from D7 to A0 for the sketch I used. I did work on this yesterday afternoon in a cafe where I had to wait for 2 hours :wink:
I realized that the German sentence "Wer mißt misst Mist" ("Who measures measures crap") partially applies to my reported measurements. D21 did consist of 21 "cnt++" statements, that is right. But that did not translate to 21 clock cycles, but 126 beacuse "cnt++" gets optimized compiler to this:
6 clock cycles
ldr     r7, [r3]
adds    r7, r7, #1
str     r7, [r3]
I verified that by using 100 "t=SysTick->VAL" statements as D21, they had same effect and took 125 clock cycles:
1.25 clock cycles
ldr     r3, [r2, #8]
I remembered that somebody said "nop" would take exactly 1 clock cycle, but even that is not true! A big sequence of 888 nops takes 1000 clock cycle:
9/8=1.125 clock cycles
nop
Because 5/4 seemed easier than 9/8 I did measurements based on 100 "t=SysTick->VAL"s in a D21, see bottom for diff to previous posted sketch (as said you can verify with only having a Due and a D7-A0 connector cable yourself) and the new sketch attached as well.
Summary from the new measurements (with clock timing control and generated assembler control [copy out IDE compile command that compiles sketch, remove the trailing "-o ..." and add "-S"], both is important) that a single "D21" being the time needed to get one full ADC conversion is 125/126 clock cycles. That is loooong for measuring speed of light at home.
Let me add some more measurments I did. While a ADC cycle takes 125 clock cycles, in a sketch with absolutely reproducible setup as with D7-A0 connector I was able to get a picture of the rising edge at 1.25 clock cycle or 15ns timing resolution!
I did that by adding a single 1.25 clock cycle statement D1 before setting D7 to HIGH until I found the rising edge. So I had to run many sketches, and I did run each several times to see that the reported values are reproducible and stable. This was a sample line reported:
4 2 2 2 1007 4095 4095 4095 4095 4095
So setting D7 to HIGH with a single port statement "p->PIO_SODR = b7;", the rising edge takes 15ns even if looking at the big step from 1007 to 3916 only.
I have created a small laser transmitter and sensor testbed to measure the effect of real laser instead of setting a pin to HIGH on the Due:
Last let me say that I have not investigated DMA SPI with 42MHz yet, the 2 clock cycle resolution of measurements for a single bit sound promising.
What I found is a very simple method to record all 32 bits of port b every 3 clock cycles, but only 6 times in total. While 6 timestamps that can be taken does not sound much, the timeframe of (6-1)311.9ns=178.5ns should be more than enough for measuring speed of light at home, because light travels 54m(!) in that time.
This is the simple script, no DMA, just storing port value into local(!) variables, and "-O3" compilation:
// C.23 = D7
Pio *p = digitalPinToPort(7);
  uint32_t b,a1,a2,a3,a4,a5,a6,a7;
  uint32_t t0,t1,b7 = digitalPinToBitMask(7);
  Serial.begin(57600);
  while(!Serial){}
  pinMode(7, INPUT);
  t0=SysTick->VAL;  // 1
  a1 = p->PIO_PDSR; // 7
  a2 = p->PIO_PDSR; // 10
  a3 = p->PIO_PDSR; // 13
  a4 = p->PIO_PDSR; // 16
  a5 = p->PIO_PDSR; // 19
  a6 = p->PIO_PDSR; // 22
  a7 = p->PIO_PDSR; // 26
  t1=SysTick->VAL;
  Serial.println( ((t0<t1)?84000+t0:t0)-t1 );
  Serial.print(a1,HEX); Serial.print(",");
  Serial.print(a2,HEX); Serial.print(",");
  Serial.print(a3,HEX); Serial.print(",");
  Serial.print(a4,HEX); Serial.print(",");
  Serial.print(a5,HEX); Serial.print(",");
  Serial.print(a6,HEX); Serial.print(",");
  Serial.print(a7,HEX);
void loop() {}
Just for demoing this program I connected D7 (now digital INPUT pin) with GND first, did run sketch, then connected it do 3.3V pin and ran sketch again. The bit flip can be seen in Serial Monitor output, 7F7... vs 7FF...:
22
7F7FFFFE,7F7FFFFE,7F7FFFFE,7F7FFFFE,7F7FFFFE,7F7FFFFE,0
22
7FFFFFFE,7FFFFFFE,7FFFFFFE,7FFFFFFE,7FFFFFFE,7FFFFFFE,0
So if one can arrange an experiment to happen inside the range of 15 clock cycles one gets all 32 digital bit settings for port b at 3 clock cycle resolution! I hope measurements with laser in testbed described above will allow to do exactly that, with 1 or 2 laser sensors.
Hermann.
$ diff sketch_jun11b.ino.posted sketch_jun11b/sketch_jun11b.ino
7a8
> uint32_t t;
10c11,17
< #define D21  D(D(D(D(cnt++)))) D(D(cnt++)) cnt++;
> #define D1 t=SysTick->VAL;
> #define D2 D(D1)
> #define D4 D(D2)
> #define D8 D(D4)
> #define D16 D(D8)
> #define D32 D(D16)
> #define D21 D(D32 D16 D2)
32a40
>  uint32_t t0,t1;
55c63,64
<  D21 D21 D21 D21
>  t0=SysTick->VAL;
>  D21 D21 D21 D21
56a66
>  t1=SysTick->VAL;
66a77
sketch_jun11b.ino (1.9 KB)
Hello Hermann
Congratulations ! You find the courage to work on the speed of light even when at the café :))))
I did some trials to duplicate your experiment with the NOP (see code below). Once wait states adjusted for read and write operations, and interrupts disabled (in option) alles gut !
uint32_t t;
/* Avoid all interruptions which take a lot of time by
  "pushing" registers during prologue and "poping" registers during epilogue
  on the stack.
  Avoid any call to a function for the same reasons if you don't want overhead
 WDT->WDT_MR = WDT_MR_WDDIS;            // Watchdog disable
 EFC0->EEFC_FMR &=~ EEFC_FMR_FWS_Msk;
 EFC0->EEFC_FMR |= EEFC_FMR_FWS(3);     // After initialization, you have 4+1 wait states
                                        // here 3+1 wait states for read and write operations
                                        // the minimum without hanging
                                        // will give 889 clock cycles for 888 Nop !!
                                        // The main reason why you get 1000 clock cycles for 888 Nop
__asm__ __volatile__(
  ".macro NOPX                  \n\t"
  ".rept 1000                   \n\t"   // adjust the number here
  "NOP                          \n\t"
  ".endr                        \n\t"   // End of Repeat
  ".endm                        \n\t"   // End of macro
 //noInterrupts();
 t=SysTick->VAL;
__asm__ __volatile__("NOPX"); // The preprocessor replaces the macro by 1000 NOP, this is not a call
 t-=SysTick->VAL;
 //interrupts();
 if (t<0) (t = t + SystemCoreClock/pow(10,3));
 Serial.begin(250000);
 Serial.print(" 1000 NOP take exactly "); Serial.print(t-1);Serial.println(" Clock Cycles");
 /*If you comment out the NoInterrupts and interrupts line, you get 1001 cycles for 1000 Nop
 if you comment these lines, you get 1003 cycles for 1000 NOP
delay(5000);
Your last solution seems interesting, but the timing tricky to tune. The beauty of DMA controller is that it works while the CPU can do other things (see the benchmark in :
AT07685: CPU Usage Demonstration using DMAC Application NOTE, page 29 , Table 8.1)
The CPU is idle 96% of the time during which the DMAC is active !!
You could, for example, enable DMAC to register sensor 1, then wait (the CPU) exactly 100 clock cycles, then disable DMAC, then analyze the stored half words.
Every technical solution is a trade_off as used to say the great Confucius.
Thanks for that sketch, I was able to see 1003 sometimes, but when I commented out the noInterrupts()/interrupts() it increased to 1007 and did not go down to 1000. But reducing "4+1" to "3+1" wait states is really dangerous. Most time your sketch did output nothing but did hang, pressing Reset button did not get it to work. So I "buy" the noInterrupts(), but not the wait state reduction.
I played with the laser testbed shown above. I was able to capture the falling edge (I turned laser on and immediately off) after 34μs plus some clock cycles several times. That really surprised me because I did not expect such a precise reproducability because of the "delayMicroseconds(34)" statements.
Now I worked on capturing the rising edge, that happens 62(87) clock cycles @192(84) MHz CPU clock after laser pin gets set high and low in next statement [btw, I had to add a L9110S motor controller to the game, it allows the 3.3V Due to drive 5V laser transmitter I have. I already ordered new module less 3.3V laser transmitters]. With sketch attached and shown at bottom of this posting I was able to reliably capture the rising edge. And I did so with 192MHz overclocking, and I can capture 8 port B values with 3 clock cycles delta times. So the time from one of the 8 port values per line to the next is only (1000/192)3 = 15..6ns, just a little bit more than a "normal" (84MHz) Arduino Due clock cycle. Light only travels 4.73m in that time -- that is good for my 29=18m measuring distance in kitchen+living room. "FD..." has pin 2 (B.27) low, "FF..." has that pin high:
FDFFFFFF FDFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 87 30
FDFFFFFF FDFFFFFF FDFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 87 30
The whole measurement is repeated in loop(), with 192MHz for measurements and 84MHz for serial output. The different number of NOPs needed to adjust to the rising edge of laser sensor is prove that the clocking really changes. Lines 7 and 13 show that sometimes the rising edge is detected one measurement later. But overall a very precise and reproducible measurement.
One fact I find interesting is that although the laser is turned on and immediatly off few clock cycles later, the laser pulse gets emitted for 34μs as the falling edge mentioned above shows. Seems to be the laser transmitter itself, or the L9110S.
While I did the first experiments in a darkened, but still lit room, I worked today in complete darkness (only laptop screen and keybord lit, both not in direction of laser sensor). This seems to be the reason for the reproducability of the experiment although laser pulse lasts only 34μs (light travels 10.3km in that time).
Here is the current sketch with 15.6ns timing resolution port captures:
// B.25 = D2
Pio *p = digitalPinToPort(2);
// C.23 = D7
Pio *q = digitalPinToPort(7);
uint32_t b7 = digitalPinToBitMask(7);
  pinMode(2, INPUT);    // laser sensor
  pinMode(6, OUTPUT);   // "motor" direction  (L9110S)
  pinMode(7, OUTPUT);   // laser transmitter  (L9110S)
  digitalWrite(6, LOW); // "motor" fixed direction
  digitalWrite(7, LOW); // laser off
  delay(200);
  while (!Serial){}
  Serial.println(".");
  Serial.println("---------");
 // Watchdog disable
  uint32_t a1,a2,a3,a4,a5,a6,a7,a8;
  uint32_t t0,t1,t2;
  Clock_System(31);  // set 192MHz CPU clock
  noInterrupts();
  q->PIO_SODR = b7;  // turn laser on ...
  q->PIO_CODR = b7;  // ... and directly off again
  t0=SysTick->VAL;
  // add some short delay to catch rising edge of laser sensor
  asm volatile(".rept 68\n\tNOP\n\t.endr");  // for 192MHz
//asm volatile(".rept 50\n\tNOP\n\t.endr");  // for 84MHz
  t1=SysTick->VAL;
  // capture port B every 3 clock cycles
  a1 = p->PIO_PDSR;
  a2 = p->PIO_PDSR;
  a3 = p->PIO_PDSR;
  a4 = p->PIO_PDSR;
  a5 = p->PIO_PDSR;
  a6 = p->PIO_PDSR;
  a7 = p->PIO_PDSR;
  a8 = p->PIO_PDSR;
  t2=SysTick->VAL;
  interrupts();
  Clock_System(13);  // set 84MHz CPU clock
  Serial.print(a1,HEX); Serial.print(" ");
  Serial.print(a2,HEX); Serial.print(" ");
  Serial.print(a3,HEX); Serial.print(" ");
  Serial.print(a4,HEX); Serial.print(" ");
  Serial.print(a5,HEX); Serial.print(" ");
  Serial.print(a6,HEX); Serial.print(" ");
  Serial.print(a7,HEX); Serial.print(" ");
  Serial.print(a8,HEX); Serial.print(" ");
  Serial.print( ticks_diff(t0,t1) ); Serial.print(" ");
  Serial.print( ticks_diff(t1,t2) ); Serial.print(" ");
  Serial.println() ;
// only for durations <1ms
uint32_t ticks_diff(uint32_t t0, uint32_t t1) {
  return ((t0 < t1) ? 84000 + t0 : t0) - t1;
// set system clock to  (1 + clock_mul)*6 MHz
void Clock_System(uint8_t clock_mul) {
#define SYS_BOARD_PLLAR     (CKGR_PLLAR_ONE \
                            | CKGR_PLLAR_MULA(clock_mul) \
                            | CKGR_PLLAR_PLLACOUNT(0x3fUL) \
                            | CKGR_PLLAR_DIVA(0x1UL))
#define SYS_BOARD_MCKR      ( PMC_MCKR_PRES_CLK_2|PMC_MCKR_CSS_PLLA_CLK)
/* Initialize PLLA to X MHz */
PMC->CKGR_PLLAR = SYS_BOARD_PLLAR;
while (!(PMC->PMC_SR & PMC_SR_LOCKA));
 /* Setting up prescaler */
PMC->PMC_MCKR = SYS_BOARD_MCKR;
while (!(PMC->PMC_SR & PMC_SR_MCKRDY));
 /* Update SystemCoreClock */
SystemCoreClockUpdate();
/* For your experiment you don't need to re-synchronize UART
 so don't serial print when your uc is running at 236 M Hz */
Hermann.
sketch_jun14b.ino (2.72 KB)
Not completely done, did make some progress and walked some dead ends (Intel).
I built a new compact Measure Speed of Light setup from the parts of the original Ikea Ivar experiment at top of this thread:
I placed a mirror just in front and made the sensor from last experiment mentioned above lit. What really surprised me is that although new setup/new laser sensor​s/new laser transmitter/another Due the unchanged sketch hits rising edge!
This was first time capturing of both laser sensors rising edge with similar distance mirror​s (F9…➫FD… FD…➫FF…). There are 4-5 FDs, but should be 0 or 1:
Next I realized that overclocking Arduino Due above 102MHz does not really make sense, see Overclocking Due over 102MHz gives nothing :frowning:. I did the runs with 192MHz and assumed 3 clock cycles between measurements having dropped from 35.7ns to 15.6ns -- it seems it only dropped to 28ns based on the other posting's measurements:
Setting up the mirror placements always was a very fragile thing, and my big hands did not make it easier. I thought on how I can fine tune mirror inclination and thought on a screw to be needed. Finally I used Lego bricks with a skrew and now have a really robust mirror fine tune setup:
Today I entered the "Intel dead end" for better precision timing. I realized that a very old 1.6GHz Thinkpad T42 has a parallel port [I did build a complete water cutting machine control (with 4000 [Bar](Bar (unit) - Wikipedia) pressure) over parallel port back in 1987!]. And parapin lib immediately worked under Linux:
Two consecutively executed RDTSC commands capturing 64bit Intel CPU clock counter show a difference of 44 which is 27.5ns. Even worse, without parapin lib a single inb() reading in 8 lines of parallel port (compared to 32 lines for Arduino Due read port) takes >1000 clock cycles (or 625ns) -- Due takes only 28ns for reading 32 lines!
I thought that operating system may be the reason for such slow port read, and found nice article Hello, World on the Bare Metal. Based on that I extended the little Hello World assembler program to measure and display the number of clock cycles in Intel real mode (program is stored and executed on master boot record of USB stick, maximal 510 bytes!). The 000EE95F or similar I measured on repeated reboots of the T42 were really dissatisfying, compare to only 44 under Linux (programs, Makefile, README can be found in zip of the tweet):
Summary, Intel processors have few GHz processors, but they are unusable for reading parallel port with 1-2digit nanosecond between measurements, which Arduino Due easily can (35.7ns) even without overclocking! So no Intel anymore, will continue working with Arduino Due.
Hermann.
I did play a lot with (5$) Raspberry Pi Zero recently, and especially its 1ns precision (1GHZ) cycle counter:
https://www.raspberrypi.org/forums/viewtopic.php?p=1017550#p1017550
While 1ns precision sounded promising, a read from GPIO does need 50ns is best case, and hat is worse than the 3 clock cycle per read described above for (12$) Arduino Due, 3*(1000/84)=35.7ns per read.
Hermann.
(8$) 0.83ns precision (1.2GHz quad core) Nanopi Neo is even worse than Pi Zero (92.5ns between GPIO reads),
http://www.friendlyarm.com/Forum/viewtopic.php?f=47&t=273&p=832&sid=cf73f9f4abc39f7f42f18be32c25e705#p832
This posting did show that Arduino Due can even do 28Msps (Million Samples Per Second) until its RAM is fully filled (3 clock cycles between consecutive GPIO reads for 10000s), 32CH for 714μs or 8CH for 3ms.
Summary: Arduino Due is best for high Msps GPIO reads and outperforms Raspberry Pi Zero as well as NanoPi Neo.
The timing of the measurements is really precise, I did show that before.
This is the repeated pattern from today's measurement:
FDFFFFFF FDFFFFFF FDFFFFFF FDFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 84 30
The border floated a bit, and I knew that it is dependent on light (therefore I do the measurements in near darkness normally). Today I changed the cabling in order to connect my 100MSps logic analyzer and that affected the timings as well:
This is how the logic analyzer sees the experiment, channel 0 is the signal sent to laser diode, channel 1 the signal received from the laser sensor:
I did use the Saleae Logic software export function the first time, I captured 6 seconds and since the sketch repeated the experiment every second the data reflects that:
Time[s], Channel 0, Channel 1
0.000000000000000, 0, 0
0.079313560000000, 1, 0
0.079313590000000, 0, 0
0.079314630000000, 0, 1
0.079334550000000, 0, 0
1.079328010000000, 1, 0
1.079328040000000, 0, 0
1.079329090000000, 0, 1
1.079348900000000, 0, 0
2.079342460000000, 1, 0
2.079342500000000, 0, 0
2.079343550000000, 0, 1
2.079363500000000, 0, 0
3.079356920000000, 1, 0
3.079356950000000, 0, 0
3.079358000000000, 0, 1
3.079377870000000, 0, 0
4.079371370000000, 1, 0
4.079371400000000, 0, 0
4.079372450000000, 0, 1
4.079392270000000, 0, 0
5.079385920000000, 1, 0
5.079385950000000, 0, 0
5.079386990000000, 0, 1
5.079406860000000, 0, 0
These are the interesting differences, when timing starts (t0=SysTick->VAL) after laser diode has been turned off and then (t1=SysTick->VAL) just before the laser sensor receives the light beam the first time:
Only the 1st and 6th show a difference of 1040ns (or 1.04μs), the others show 1050ns difference (100MSps resolution is 10ns).
t2=SysTick->VAL is 84+30=114 clock ticks after turning the laser diode signal off, so the rising edge of channel 1 in logic analyzer is somewhere between 84+43=96 and 114-43=102 clock ticks.
Hmmm, 105084/1000=88.2 and 104084/1000=87.36, which indicates 88 clock ticks between falling edge of channel 0 and rising edge of channel 1 ...
Hermann.
Hi HermannSW,
An interesting project your working on and nice to know how the big gun CPU's are poor at I/O though I'm not sure if it's the CPU at fault or the southbridge chip.
As you seem to have tried several different CPU/MCU combinations I wonder if you had tried a PIC MCU?
Specifically a PIC chip that has a Charge-Time Measurement Unit (CTMU) built in, the CTMU can be used to measure time resolution to within a nanosecond (see this).
I cheated with my project here and used and external timing chip (ACAM GP22) to do the timing for me. I had considered trying the same experiment using light instead of electricity and even got as far as buying a light splitter but never continued with the test (bigger and better fish to fry).
Keep up the good work.
