i have to measure time in arduino.I think i should use stopwatch library but i didn't include this library in my computer.Maybe you can help me.thanks
unsigned long StartTime = millis();
later...
unsigned long CurrentTime = millis();
unsigned long ElapsedTime = CurrentTime - StartTime;
That will give you the elapsed time in milliseconds, up to about 40 days. If you need more precise measurement you can use 'micros()' instead of ''millis()' to get microseconds, up to a couple of hours, I think.
The Arduino clock isn't very accurate so your timing may be off by minutes a day.
micros() last for 2^32 micros = 4295 seconds = ~71.5 minutes so just more than one hour
thanks all your replies
i have another problem.I will make speedometer of te hydro car.Therefore i have to get time and measure the speed.i will use magnetic reed sensor.i use milis();
hiz =2pir*3600/(elapsed time );
my measuring time code is this. eplased time is ElapsedTime = CurrentTime - StartTime;
is it true approach?
you missed the factor 1000 as you measure in millis(). Just do the math for some known values and you see if a formula works.
e.g 1 second, 10 seconds 3600 seconds.
Partial code not tested
unsigned long prev = 0;
unsigned long now = millis();
float speed = 2.0*pi*r * 3600 * 1000 / (now- prev); speed in meters/hour
prev = now;
Serial.println(speed);
FWIW, once you get ready to finalize the code, try to compress all the math calcs in this example into a constant float or long up front. The reason being, there is no benefit to recalculating "2.0pi 3600 * 1000" over and over, it's 22619467.11... Ideally, Define R in that function as well and you may not even need to use a float.
Less calculations for Arduino to do = better responsiveness by Arduino.
If you want higher sampling speeds, look into the ways that are required to bypass Analog.read and have the ADC go directly to the pins in question. For example, you could set this up as a sub-routine with 100 samples taken, then return the speed based on the micro-seconds that have elapsed. One benefit of not using the analog.Read routines is that the ADC runs independently of the main CPU, you you can likely get some math done between each read (it's what I did with my energy logger - start sampling the voltage channel but work on the current data, then switch to measuring current while processing the just-sampled voltage data).
"The Arduino clock isn't very accurate so your timing may be off by minutes a day. "
I think that partly depends on whether the arduino uses a Crsytal vs a Resonator, and also how the seconds are tracked.
I have done tests with my duemilanove, it has tracked the official US time with no losses over a day.
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
unsigned long previousTime = 0;
byte seconds ;
byte minutes ;
bytes hours ;
void setup(){
Serial.begin {9600);
// I think using microseconds is even more accurate
if (millis() >= (previousTime) ) {
previousTime = previousTime + 1000; // use 100000 for uS
seconds = seconds +1;
if (seconds == 60)
seconds = 0;
minutes = minutes +1;
if (minutes == 60)
minutes = 0;
hours = hours +1;
if (hours == 13)
hours = 1;
Serial.print (hours, DEC);
Serial.print (":");
Serial.print (minutes,DEC);
Serial.print (":");
Serial.println(seconds,DEC);
} // end 1 second
} // end loop
Constantin:
In a way, it is good that he is using "float", because this way there is less chance of overflow.
Also, I highly recommend using "micros()" here instead of "millis()".
You will probably also want to check for switch bounce (that is, when the sensor registers twice when it should only register once). If the "elapsed time" for one revolution of the wheel is less than 5 milliseconds, then the measurement should be rejected.
You will also need to check for speeds close to zero (that is, a long time without the wheel moving).
Hi, CrossRoads
There were a couple of typos, oversights in your code; it didn't compile.
I took the liberty of fixing that.
It works good!
/* CrossRoads Time-clock */
byte seconds ;
byte minutes ;
byte hours ;
Serial.begin (9600);
void loop ()
if (millis() >= (previousTime))
if (seconds == 60)
seconds = 0;
if (minutes == 60)
minutes = 0;
hours = hours +1;
if (hours == 13)
hours = 1;
Serial.print (":");
Serial.print (":");
} // end 1 second
} // end loop
Well, making it from scratch at work while on a short break without a chance to compile will do that.
Can't believe I left out void loop(){ !
100000 ? ==> 1000000 ![]()
Yeah 5 zeroes, 6 zereos, whatever it takes 8)
Hello,
Though this comment is too late but it might be helpful as knowledge base for newbies.
The above code is only correct if the loop is ticked every 1 second. Hence, you have to add delay(1000); as last row at the end of the loop() function.
Så the final version of lovely CrossRoad's code looks like below:
byte seconds ;
byte minutes ;
byte hours ;
void loop ()
previousTime = previousTime + 1000; // use 1000000 for uS
if (seconds == 60)
seconds = 0;
if (minutes == 60)
minutes = 0;
hours = hours +1;
if (hours == 13)
hours = 1;
Serial.print (":");
Serial.print (":");
} // end 1 second
delay(1000); //This will ensure one loop per second
} // end loop
2014sideline:
I have to disagree with you, 2014sideline.
If you use the function delay(1000), then the sketch will wait for 1 second (=1000 ms), during which time it can't do anything else, and then after that time has elapsed it has to update the hours, minutes and seconds, and then send the results to the serial monitor.
This will take a finite time, so I think that means that your solution will always run slow (maybe not a lot).
Hi there, I'm new to arduino, I need some help trying to measure time between actuating to different switches.
ie. press sw1 once and the press sw2 later. The time in between can be milliseconds.
Thanks.
Some arduinos use a ceramic resonator, which could be +/- 3%%
some use crystals, which could be as bad as +/- 100ppm - ie 0.01%
if this isn't good enough, buy a 30ppm crystal - 0.003%
if you want better than this is it gets more expensive
regards
Allan
Call millis(), remember the result on each press, then you can subtract one from the other.
When I needed accurate time, I use a DS3231 board
that I got from ebay. I set it to do a one second interrupt.
In the interrupt, I take a micros() reading.
When the code is running, I watch for an update from the one
second interrupt, while doing other things that take less than a second.
I take the result of the interrupts time reading from the
uPs clock and calculate the error. I apply it to the current
one second time span.
Even though the uP is running on a resonator, it is relatively
constant over a one second time span.
The drift rate is mostly related to temperature changes.
The change in rate is a little higher for the first 15 minutes
after power up and then slows down a lot.
Dwight
Hi everybody!
I'm almost new in Arduino and I'm trying to send a sample of an Ultrasonic (HC-SR04) sensor to PC over Bluetooth. The main problem is that time the pulseIn function I am using to work out the distance depends on the distance. I mean, the more distance, the more time it takes.
Any idea of how I can set the sampling time? I don't mind if it's not too quick because I will interpolate the signal in matlab.
I have tried using millis() but it doesn't work.
Thanks
I can absolutely assure you that the millis function does work.
If the delay caused by increased range is a problem, you have at least two solutions:
A) reduce the range
B) increase the speed of sound - try an atmosphere of helium.
