measuring upper and lower limit of DAC output
to know the values of lower limt and upper limit of DAC in arduino due.
I tried to measure the DAC analog output with multimeter with the attached code.
after uploading the program the measuring value is 0.334V continuously.
not varying after delay of 2 seconds.
how to measure the DAC analog voltage.
Pl.correct my code.
int value;
  analogWriteResolution(12);
  value =0;
  analogWrite(DAC0,value);
  delay(2000);
  value =4095;
There is a good chance that you burned your DAC ...
DAC output is in the range of 1/6 * 3.3V and 5/6 * 3.3V. You always want to connect at least a 1.5 K Ohms resistor in serie for each DAC to avoid burning your DACs.
