Mechanical Pinball to MLB Scoreboard
I bought the head from an old mechanical williams pitch and bat and I would like to turn it into a scoreboard for mlb games.
I am extremely new to any type of coding and arduino.
The issue i dont know how to solve is getting the scores.
I have a relay bank that will activate different solenoids and I can figure out the logic to those but my end goal is to pick a specific team and then display the following stats
Home Score
Away Score
inning
current outs
current balls
current strikes
so every time a new batter comes up i will reset the the balls, strikes,and outs
i dont know how to get that data into my arduino. i am currently using a nano but plan on upgrading to a Giga R1 with wifi. I was thinking of eventually having a scrolling LED display on top that says the current batter or something but that is later down the line.
I dont care if i have to pay for a subscription as long as its not outrageous.
const int numRelays = 16;  // Number of relays
const int relayPins[numRelays] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, A0, A1, A2, A3};  // Define relay pins
  // Set all relay pins as OUTPUT
  for (int i = 0; i < numRelays; i++) {
    pinMode(relayPins[i], OUTPUT);
    digitalWrite(relayPins[i], LOW); // Ensure all relays are initially off
  Serial.begin(9600);  // Initialize serial communication
  Serial.println("Enter the number of times to close each relay:");
  // Relay 1
  Serial.println("Enter the number of times to close relay 1:");
  while (Serial.available() == 0) {}
  int numClosures1 = Serial.parseInt();
  closeRelay(0, numClosures1);  // Close relay 1
 /* // Relay 2
  Serial.println("Enter the number of times to close relay 2:");
  int numClosures2 = Serial.parseInt();
  closeRelay(1, numClosures2);  // Close relay 2
  // Relay 3
  Serial.println("Enter the number of times to close relay 3:");
  int numClosures3 = Serial.parseInt();
  closeRelay(2, numClosures3);  // Close relay 3
  // Add similar blocks for remaining relays...
// Function to close a relay
void closeRelay(int relayIndex, int numClosures) {
  if (numClosures > 0) {
    for (int j = 0; j < numClosures; j++) {
      digitalWrite(relayPins[relayIndex], HIGH);
      delay(500);  // Adjust delay as needed (milliseconds)
      digitalWrite(relayPins[relayIndex], LOW);
    Serial.print("Relay ");
    Serial.print(relayIndex + 1);
    Serial.println(" closed.");
    Serial.print("Invalid input for relay ");
    Serial.println(". Please enter a positive number.");
Photos
I just want to add that this was just part of the machine and it doesn't have the glass and I didn't dismantle a restorable machine in order to do this. I plan on keeping everything original inside and I even bought an old mechanical wiring harness for parts so that nothing needs to be soldered and I can hook everything up to the Jones plugs without modifying it in any way
Far out.
Here is a 16-relay, baselines simulation for testing relays and maybe light (somewhat) sequences...
I restore a 60s Williams pinch hitter that has fastball and curveball. I also recently got into restoring 50s seeburg jukeboxes
If that Pitch n Bat back glass is in good condition would you be willing to part with it?
I actually found a reproduction years ago so I don't have the original glass
Where did you get a reproduction Backglass? Was it BGResto?
