Mega 2560 and 5 speakers with Tone Library
So apparently this had been a problem longer than I've known, but there's a tone library that can play up to 5/6 speaker tones but it seems the source code is outdated. Anything i need to fix and what pins do i use for the 5 tone setup?
|| @author         Brett Hagman <bhagman@wiring.org.co>
|| @contribution   Fotis Papadopoulos <fpapadopou@gmail.com>
|| @url            http://wiring.org.co/
|| @url            http://roguerobotics.com/
|| @description
|| | A Software Digital Square Wave Tone Generation Library
|| | Written by Brett Hagman
|| | http://www.roguerobotics.com/
|| | bhagman@roguerobotics.com, bhagman@wiring.org.co
|| | This is a Wiring Framework (Arduino) library to produce square-wave
|| | tones on an arbitrary pin.
|| | You can make multiple instances of the Tone object, to create tones on
|| | different pins.
|| | The number of tones that can be generated at the same time is limited
|| | by the number of hardware timers available on the hardware.
|| | (e.g. ATmega328 has 3 available timers, and the ATmega1280 has 6 timers)
|| | A simplified (single tone) version of this library has been included
|| | in the Wiring Framework since Wiring 0025 and in the Arduino distribution
|| | since Arduino 0018.
|| @license Please see the accompanying LICENSE.txt file for this project.
|| @name Software PWM Library
|| @type Library
|| @target Atmel AVR 8 Bit
|| @version 1.0.0
#if defined(WIRING)
 #include <Wiring.h>
#elif ARDUINO >= 100
 #include <Arduino.h>
#else
 #include <WProgram.h>
#endif
#include "Tone.h"
#if defined(__AVR_ATmega8__)
#define TCCR2A TCCR2
#define TCCR2B TCCR2
#define COM2A1 COM21
#define COM2A0 COM20
#define OCR2A OCR2
#define TIMSK2 TIMSK
#define OCIE2A OCIE2
#define TIMER2_COMPA_vect TIMER2_COMP_vect
#define TIMSK1 TIMSK
#endif
// timerx_toggle_count:
//  > 0 - duration specified
//  = 0 - stopped
//  < 0 - infinitely (until stop() method called, or new play() called)
#if !defined(__AVR_ATmega8__)
volatile int32_t timer0_toggle_count;
volatile uint8_t *timer0_pin_port;
volatile uint8_t timer0_pin_mask;
#endif
volatile int32_t timer1_toggle_count;
volatile uint8_t *timer1_pin_port;
volatile uint8_t timer1_pin_mask;
volatile int32_t timer2_toggle_count;
volatile uint8_t *timer2_pin_port;
volatile uint8_t timer2_pin_mask;
#if defined(__AVR_ATmega1280__)
volatile int32_t timer3_toggle_count;
volatile uint8_t *timer3_pin_port;
volatile uint8_t timer3_pin_mask;
volatile int32_t timer4_toggle_count;
volatile uint8_t *timer4_pin_port;
volatile uint8_t timer4_pin_mask;
volatile int32_t timer5_toggle_count;
volatile uint8_t *timer5_pin_port;
volatile uint8_t timer5_pin_mask;
#endif
#define AVAILABLE_TONE_PINS 6
// Leave timers 1, and zero to last.
const uint8_t PROGMEM tone_pin_to_timer_PGM[] = { 2, 3, 4, 5, 1, 0 };
#elif defined(__AVR_ATmega8__)
#define AVAILABLE_TONE_PINS 2
const uint8_t PROGMEM tone_pin_to_timer_PGM[] = { 2, 1 };
#else
#define AVAILABLE_TONE_PINS 3
// Leave timer 0 to last.
const uint8_t PROGMEM tone_pin_to_timer_PGM[] = { 2, 1, 0 };
#endif
// Initialize our pin count
uint8_t Tone::_tone_pin_count = 0;
// Interrupt routines
#ifdef WIRING
void Tone_Timer0_Interrupt(void)
#else
ISR(TIMER0_COMPA_vect)
#endif
  if (timer0_toggle_count != 0)
    // toggle the pin
    *timer0_pin_port ^= timer0_pin_mask;
    if (timer0_toggle_count > 0)
      timer0_toggle_count--;
    TIMSK0 &= ~(1 << OCIE0A);                 // disable the interrupt
    *timer0_pin_port &= ~(timer0_pin_mask);   // keep pin low after stop
#endif
#ifdef WIRING
void Tone_Timer1_Interrupt(void)
#else
ISR(TIMER1_COMPA_vect)
#endif
  if (timer1_toggle_count != 0)
    // toggle the pin
    *timer1_pin_port ^= timer1_pin_mask;
    if (timer1_toggle_count > 0)
      timer1_toggle_count--;
    TIMSK1 &= ~(1 << OCIE1A);                 // disable the interrupt
    *timer1_pin_port &= ~(timer1_pin_mask);   // keep pin low after stop
#ifdef WIRING
void Tone_Timer2_Interrupt(void)
#else
ISR(TIMER2_COMPA_vect)
#endif
  int32_t temp_toggle_count = timer2_toggle_count;
  if (temp_toggle_count != 0)
    // toggle the pin
    *timer2_pin_port ^= timer2_pin_mask;
    if (temp_toggle_count > 0)
      temp_toggle_count--;
    TIMSK2 &= ~(1 << OCIE2A);                 // disable the interrupt
    *timer2_pin_port &= ~(timer2_pin_mask);   // keep pin low after stop
  timer2_toggle_count = temp_toggle_count;
#ifdef WIRING
void Tone_Timer3_Interrupt(void)
#else
ISR(TIMER3_COMPA_vect)
#endif
  if (timer3_toggle_count != 0)
    // toggle the pin
    *timer3_pin_port ^= timer3_pin_mask;
    if (timer3_toggle_count > 0)
      timer3_toggle_count--;
    TIMSK3 &= ~(1 << OCIE3A);                 // disable the interrupt
    *timer3_pin_port &= ~(timer3_pin_mask);   // keep pin low after stop
#ifdef WIRING
void Tone_Timer4_Interrupt(void)
#else
ISR(TIMER4_COMPA_vect)
#endif
  if (timer4_toggle_count != 0)
    // toggle the pin
    *timer4_pin_port ^= timer4_pin_mask;
    if (timer4_toggle_count > 0)
      timer4_toggle_count--;
    TIMSK4 &= ~(1 << OCIE4A);                 // disable the interrupt
    *timer4_pin_port &= ~(timer4_pin_mask);   // keep pin low after stop
#ifdef WIRING
void Tone_Timer5_Interrupt(void)
#else
ISR(TIMER5_COMPA_vect)
#endif
  if (timer5_toggle_count != 0)
    // toggle the pin
    *timer5_pin_port ^= timer5_pin_mask;
    if (timer5_toggle_count > 0)
      timer5_toggle_count--;
    TIMSK5 &= ~(1 << OCIE5A);                 // disable the interrupt
    *timer5_pin_port &= ~(timer5_pin_mask);   // keep pin low after stop
#endif
void Tone::begin(uint8_t tonePin)
  if (_tone_pin_count < AVAILABLE_TONE_PINS)
    _pin = tonePin;
    _timer = pgm_read_byte(tone_pin_to_timer_PGM + _tone_pin_count);
    _tone_pin_count++;
    // Set timer specific stuff
    // All timers in CTC mode
    // 8 bit timers will require changing prescalar values,
    // whereas 16 bit timers are set to either ck/1 or ck/64 prescalar
    switch (_timer)
      case 0:
        // 8 bit timer
        TCCR0A = 0;
        TCCR0B = 0;
        bitWrite(TCCR0A, WGM01, 1);
        bitWrite(TCCR0B, CS00, 1);
        timer0_pin_port = portOutputRegister(digitalPinToPort(_pin));
        timer0_pin_mask = digitalPinToBitMask(_pin);
#ifdef WIRING
        Timer0.attachInterrupt(INTERRUPT_COMPARE_MATCH_A, Tone_Timer0_Interrupt);
#endif
#endif
      case 1:
        // 16 bit timer
        TCCR1A = 0;
        TCCR1B = 0;
        bitWrite(TCCR1B, WGM12, 1);
        bitWrite(TCCR1B, CS10, 1);
        timer1_pin_port = portOutputRegister(digitalPinToPort(_pin));
        timer1_pin_mask = digitalPinToBitMask(_pin);
#ifdef WIRING
        Timer1.attachInterrupt(INTERRUPT_COMPARE_MATCH_A, Tone_Timer1_Interrupt);
#endif
      case 2:
        // 8 bit timer
        TCCR2A = 0;
        TCCR2B = 0;
        bitWrite(TCCR2A, WGM21, 1);
        bitWrite(TCCR2B, CS20, 1);
        timer2_pin_port = portOutputRegister(digitalPinToPort(_pin));
        timer2_pin_mask = digitalPinToBitMask(_pin);
#ifdef WIRING
        Timer2.attachInterrupt(INTERRUPT_COMPARE_MATCH_A, Tone_Timer2_Interrupt);
#endif
      case 3:
        // 16 bit timer
        TCCR3A = 0;
        TCCR3B = 0;
        bitWrite(TCCR3B, WGM32, 1);
        bitWrite(TCCR3B, CS30, 1);
        timer3_pin_port = portOutputRegister(digitalPinToPort(_pin));
        timer3_pin_mask = digitalPinToBitMask(_pin);
#ifdef WIRING
        Timer3.attachInterrupt(INTERRUPT_COMPARE_MATCH_A, Tone_Timer3_Interrupt);
#endif
      case 4:
        // 16 bit timer
        TCCR4A = 0;
        TCCR4B = 0;
        bitWrite(TCCR4B, WGM42, 1);
        bitWrite(TCCR4B, CS40, 1);
        timer4_pin_port = portOutputRegister(digitalPinToPort(_pin));
        timer4_pin_mask = digitalPinToBitMask(_pin);
#ifdef WIRING
        Timer4.attachInterrupt(INTERRUPT_COMPARE_MATCH_A, Tone_Timer4_Interrupt);
#endif
      case 5:
        // 16 bit timer
        TCCR5A = 0;
        TCCR5B = 0;
        bitWrite(TCCR5B, WGM52, 1);
        bitWrite(TCCR5B, CS50, 1);
        timer5_pin_port = portOutputRegister(digitalPinToPort(_pin));
        timer5_pin_mask = digitalPinToBitMask(_pin);
#ifdef WIRING
        Timer5.attachInterrupt(INTERRUPT_COMPARE_MATCH_A, Tone_Timer5_Interrupt);
#endif
#endif
    // disabled
    _timer = -1;
// frequency (in hertz) and duration (in milliseconds).
void Tone::play(uint16_t frequency, uint32_t duration)
  uint8_t prescalarbits = 0b001;
  int32_t toggle_count = 0;
  uint32_t ocr = 0;
  if (_timer >= 0)
    // Set the pinMode as OUTPUT
    pinMode(_pin, OUTPUT);
    // if we are using an 8 bit timer, scan through prescalars to find the best fit
    if (_timer == 0 || _timer == 2)
      ocr = F_CPU / frequency / 2 - 1;
      prescalarbits = 0b001;  // ck/1: same for both timers
      if (ocr > 255)
        ocr = F_CPU / frequency / 2 / 8 - 1;
        prescalarbits = 0b010;  // ck/8: same for both timers
        if (_timer == 2 && ocr > 255)
          ocr = F_CPU / frequency / 2 / 32 - 1;
          prescalarbits = 0b011;
        if (ocr > 255)
          ocr = F_CPU / frequency / 2 / 64 - 1;
          prescalarbits = _timer == 0 ? 0b011 : 0b100;
            ocr = F_CPU / frequency / 2 / 128 - 1;
            prescalarbits = 0b101;
          if (ocr > 255)
            ocr = F_CPU / frequency / 2 / 256 - 1;
            prescalarbits = _timer == 0 ? 0b100 : 0b110;
            if (ocr > 255)
              // can't do any better than /1024
              ocr = F_CPU / frequency / 2 / 1024 - 1;
              prescalarbits = _timer == 0 ? 0b101 : 0b111;
      if (_timer == 0)
        TCCR0B = (TCCR0B & 0b11111000) | prescalarbits;
#endif
        TCCR2B = (TCCR2B & 0b11111000) | prescalarbits;
      // two choices for the 16 bit timers: ck/1 or ck/64
      if (ocr > 0xffff)
      if (_timer == 1)
        TCCR1B = (TCCR1B & 0b11111000) | prescalarbits;
      else if (_timer == 3)
        TCCR3B = (TCCR3B & 0b11111000) | prescalarbits;
      else if (_timer == 4)
        TCCR4B = (TCCR4B & 0b11111000) | prescalarbits;
      else if (_timer == 5)
        TCCR5B = (TCCR5B & 0b11111000) | prescalarbits;
#endif
    // Calculate the toggle count
    if (duration > 0)
      toggle_count = 2 * frequency * duration / 1000;
      toggle_count = -1;
    // Set the OCR for the given timer,
    // set the toggle count,
    // then turn on the interrupts
    switch (_timer)
      case 0:
        OCR0A = ocr;
        timer0_toggle_count = toggle_count;
        bitWrite(TIMSK0, OCIE0A, 1);
#endif
      case 1:
        OCR1A = ocr;
        timer1_toggle_count = toggle_count;
        bitWrite(TIMSK1, OCIE1A, 1);
      case 2:
        OCR2A = ocr;
        timer2_toggle_count = toggle_count;
        bitWrite(TIMSK2, OCIE2A, 1);
      case 3:
        OCR3A = ocr;
        timer3_toggle_count = toggle_count;
        bitWrite(TIMSK3, OCIE3A, 1);
      case 4:
        OCR4A = ocr;
        timer4_toggle_count = toggle_count;
        bitWrite(TIMSK4, OCIE4A, 1);
      case 5:
        OCR5A = ocr;
        timer5_toggle_count = toggle_count;
        bitWrite(TIMSK5, OCIE5A, 1);
#endif
void Tone::stop()
  switch (_timer)
    case 0:
#endif
    case 1:
    case 2:
    case 3:
    case 4:
    case 5:
#endif
  digitalWrite(_pin, 0);
bool Tone::isPlaying(void)
  bool returnvalue = false;
  switch (_timer)
    case 0:
      returnvalue = (TIMSK0 & (1 << OCIE0A));
#endif
    case 1:
      returnvalue = (TIMSK1 & (1 << OCIE1A));
    case 2:
      returnvalue = (TIMSK2 & (1 << OCIE2A));
    case 3:
      returnvalue = (TIMSK3 & (1 << OCIE3A));
    case 4:
      returnvalue = (TIMSK4 & (1 << OCIE4A));
    case 5:
      returnvalue = (TIMSK5 & (1 << OCIE5A));
#endif
  return returnvalue;
This Cpp is what I'm using for the tones.
Take a look at arduino/reference and tone and see if there is any useful information
well that was interesting. was using platformio and had both the old and new tone libraries installed and the outdated one was taking priority.
