Hello friends, there is a device that works with Arduino mega. This device is a curve follower. It consists of a total of 12 LEDs and 12 buttons on the front panel, 6 of the buttons are used for different voltage options, 3 of them are used for frequency and the other 3 are used to select a/b channels and create a continuous loop between a/b channels. kind of like a flip-flop.
I want to add Autoscan mode to this device, it is necessary to add a button and an LED for this mode.
When you press the button, the mode becomes active, when you press it again, the mode becomes inactive. If the mode is active, the LED lights up continuously to show that the mode is active, and if the mode is inactive, the LED turns off. Also, when the mode is active, it should work as if the 6 buttons on the front panel were pressed sequentially, one second apart, that is, 1.2.3.. .. should press the button .
// the setup function runs once when you press reset or power the board
#include "TimerOne.h"
#include <SPI.h>
#define FASTADC 1
// defines for setting and clearing register bits
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
int buttonState = 0;
//int menubutton = 5;
int i = 0;
int result = 6;
int M1 = 0;
int M2 = 0;
int M3 = 0;
int M4 = 0;
int M5 = 0;
int M6 = 1;
int MF1 = 1;
int MF2 = 0;
int resultF = 1;
int MFR1 = 1;
int MFR2 = 0;
int MFR3 = 0;
int resultFR = 1;
int t = 1;
long int analog;
long int ti = 500000;
int I = 0;
int te = 0;
int valueX[270];
int valueY[270];
const int CS = 48;
const int CSV = 49;
const int CSI = 46;
int value5 = 100;
//---------------------------------Setup--------------------------------
// initialize digital pin LED_BUILTIN as an output.
SPI.begin();
#if FASTADC
// set prescale to 16
sbi(ADCSRA, ADPS2) ;
cbi(ADCSRA, ADPS1) ;
cbi(ADCSRA, ADPS0) ;
#endif
for (int inc = 6; inc <= 13; inc++)
pinMode(inc, OUTPUT);
for (int inc = 22; inc <= 44; inc = inc + 2)
for (int inc = 23; inc <= 45; inc = inc + 2)
pinMode(inc, INPUT);
pinMode(CS, OUTPUT);
pinMode(CSV, OUTPUT);
pinMode(CSI, OUTPUT);
pinMode(3, OUTPUT);
digitalWrite(13, LOW); // turn the LED on (HIGH is the voltage level)
digitalWrite(12, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
digitalWrite(34, HIGH);
digitalWrite(42, LOW);
digitalWrite(44, LOW);
digitalWrite(40, HIGH);
digitalWrite(38, LOW);
digitalWrite(36, LOW);
void callback()
if (t == 1)
digitalWrite(13, HIGH);
digitalWrite(12, LOW);
t++;
digitalWrite(34, LOW);
digitalWrite(42, HIGH);
t = 1;
//-------------------------------------button---------------------------
int menubutton()
for (i = 35; i <= 45; i = i + 2)
if (digitalRead(i) == 1)
if (i == 45) result = 6;
if (i == 43) result = 5;
if (i == 41) result = 4;
if (i == 39) result = 3;
if (i == 37) result = 2;
if (i == 35) result = 1;
//Serial.print(i);
//delay(100);
if (digitalRead(33) == 1)//A
resultF = 1;
if (digitalRead(25) == 1)//B
resultF = 2;
if (digitalRead(23) == 1)//A/B
resultF = 3;
//----------------Freq---------------
if (digitalRead(27) == 1)//120
resultFR = 1;
if (digitalRead(29) == 1)//1000
resultFR = 2;
if (digitalRead(31) == 1)//2000
resultFR = 3;
return result;
//------------------------------------------------Sets the digital potentiometers-------------------------------------
void MCP41010Write(byte value)
// Note that the integer vale passed to this subroutine
// is cast to a byte
digitalWrite(CS, LOW);
SPI.transfer(B00010001); // This tells the chip to set the pot
SPI.transfer(value); // This tells it the pot position
digitalWrite(CS, HIGH);
//--------------------------------------------Sets the V pot----------------------------------------------------------
void MCP41010WriteV(byte valueV)
digitalWrite(CSV, LOW);
SPI.transfer(valueV); // This tells it the pot position
digitalWrite(CSV, HIGH);
//--------------------------------------------Sets the I pot----------------------------------------------------------
void MCP41010WriteI(byte valueI)
digitalWrite(CSI, LOW);
SPI.transfer(valueI); // This tells it the pot position
digitalWrite(CSI, HIGH);
// the loop function runs over and over again forever
menubutton();
//------------------------------------Timer for A/B channel------------------------------------
switch (resultF) {
case 1: //---------------------------A--------------------
if (MF1 == 1)
detachInterrupt(callback);
cli();
MF1 = 0;
MF2 = 1;
case 2: //---------------------------B--------------------
if (MF2 == 1)
cli();
MF1 = 1;
MF2 = 0;
case 3: //---------------------------A/B--------------------
sei();
digitalWrite(44, HIGH);
analog = analogRead(A15);
ti = (analog + 50) * 800;
Timer1.initialize(ti); // initialize timer1, and set a 1/2 second period
Timer1.attachInterrupt(callback); // attaches callback() as a timer overflow interrupt
MF1 = 1;
MF2 = 1;
Serial.println(resultF);
//------------------------------------Frequency------------------------------------
switch (resultFR) {
case 1: //---------------------------120Hz--------------------
if (MFR1 == 1)
analogWrite(3, 1);
MFR1 = 0;
MFR2 = 1;
MFR3 = 1;
case 2: //---------------------------1000Hz--------------------
if (MFR2 == 1)
analogWrite(3, 120);
digitalWrite(38, HIGH);
digitalWrite(40, LOW);
MFR1 = 1;
MFR2 = 0;
MFR3 = 1;
case 3: //---------------------------2000Hz--------------------
if (MFR3 == 1)
analogWrite(3, 255);
digitalWrite(36, HIGH);
MFR1 = 1;
MFR2 = 1;
MFR3 = 0;
//---------------------------------------PC reader----------------------------------------------
/for (I = 0; I < 100; I++) //sampling from analog pins
valueX[I] = analogRead(A0);
valueY[I] = analogRead(A1);
for (te = 0; te <= 500; te++); //trigger (Set to 50Hz)
Serial.println("CLEARDATA");
Serial.print("DATA,");
Serial.print(valueX[I]);
Serial.print(",");
delay(50);
Serial.print(valueY[I]);
delay(50);
delay(1000);/
/value5 = analogRead(A15);
value5 = map(value5, 0, 1024, 0, 255);
Serial.println(value5);
MCP41010WriteI(value5);/
switch (result) {
case 1: //---------------------------VR1_VERY_LOW--------------------
if (M1 == 1)
digitalWrite(32, HIGH);//------------------LEDS--------------------
digitalWrite(30, LOW);
digitalWrite(28, LOW);
digitalWrite(26, LOW);
digitalWrite(24, LOW);
digitalWrite(22, LOW);
digitalWrite(11, LOW);
M1 = 0;
M2 = 1;
M3 = 1;
M4 = 1;
M5 = 1;
M6 = 1;
MCP41010WriteI(4);
MCP41010Write(5);
MCP41010WriteV(0);
case 2: //---------------------------VR2_LOW--------------------
if (M2 == 1)
digitalWrite(32, LOW);//------------------LEDS--------------------
digitalWrite(30, HIGH);
digitalWrite(10, LOW);
M1 = 1;
M2 = 0;
M3 = 1;
M4 = 1;
M5 = 1;
M6 = 1;
MCP41010WriteI(4);
MCP41010Write(29);
//Serial.print(M2);
MCP41010WriteV(3);
case 3: //---------------------------VR3_MED_1--------------------
if (M3 == 1)
digitalWrite(28, HIGH);
digitalWrite(9, LOW);
M1 = 1;
M2 = 1;
M3 = 0;
M4 = 1;
M5 = 1;
M6 = 1;
MCP41010WriteI(1);
MCP41010Write(52);
MCP41010WriteV(6);
case 4: //---------------------------VR4_MED_2--------------------
if (M4 == 1)
digitalWrite(26, HIGH);
digitalWrite(8, LOW);
M1 = 1;
M2 = 1;
M3 = 1;
M4 = 0;
M5 = 1;
M6 = 1;
MCP41010WriteI(1);
MCP41010Write(110);
MCP41010WriteV(12);
case 5: //---------------------------VR5_HIGH--------------------
if (M5 == 1)
digitalWrite(24, HIGH);
digitalWrite(7, LOW);
M1 = 1;
M2 = 1;
M3 = 1;
M4 = 1;
M5 = 0;
M6 = 1;
MCP41010WriteI(1);
MCP41010Write(189);
MCP41010WriteV(22);
case 6: //---------------------------VR6_VERY_HIGH--------------------
if (M6 == 1)
digitalWrite(22, HIGH);
digitalWrite(6, LOW);
M1 = 1;
M2 = 1;
M3 = 1;
M4 = 1;
M5 = 1;
M6 = 0;
MCP41010WriteI(1);
MCP41010Write(254);
MCP41010WriteV(30);
//Serial.println("");
//Serial.println(result);
