Here's what I'm trying to accomplish. I use the Wemos D1R2 with this shield. It will only control 8 outputs and I need 12. so thats why I'm moving to the Mega to have more outputs. Now I'm running into the issue of the E131 library doesn't run on Mega. Do you know of one that does? can I run the E131 sketch on the ESP8266 and then have it control out outputs on the Mega? Does that make sense?
Here is the sketch I've been using.
// Wemos D1 E1.31 - 8 channel sketch for Sparkfun EL Escudo Dos shield
//Spark Fun link https://www.sparkfun.com/products/10878
#include <ESP8266WiFi.h>
#include <E131.h> // Copyright (c) 2015 Shelby Merrick http://www.forkineye.com
// ***** USER SETUP STUFF *****
const char ssid[] = "MYSSID"; // replace with your SSID.
const char passphrase[] = "12345678"; // replace with your passphrase.
const int universe = 12; // this sets the universe number you are using.
//The IP setup is only required if you are using Unicast and/or you want a static IP for multicast.
//In multicast this IP is only for network connectivity not multicast data
IPAddress ip (192,168,1,222); // xx,xx,xx,xx
IPAddress netmask (255,255,255,0); //255,255,255,0 is common
IPAddress gateway (192,168,1,1); // xx,xx,xx,xx normally your router / access piont IP address
IPAddress dns (192,168,1,1); // // xx,xx,xx,xx normally your router / access point IP address
// this sets the pin numbers to use as outputs.
//for Wemos D1 R1 pins are 16,5,4,14,12,13,0,2
//for Wemos D1 R2 pins are 16,5,4,0,2,14,12,13
const int output_1 = 16; //the pin to use as output 1 (D0)
const int output_2 = 5; //the pin to use as output 2 (D1)
const int output_3 = 4; //the pin to use as output 3 (D2)
const int output_4 = 0; //the pin to use as output 4 (D3)
const int output_5 = 2; //the pin to use as output 5 (D4)
const int output_6 = 14; //the pin to use as output 6 (D5)
const int output_7 = 12; //the pin to use as output 7 (D6)
const int output_8 = 13; //the pin to use as output 8 (D7)
E131 e131;
// set the pins chosen above as outputs.
pinMode(output_1, OUTPUT);
pinMode(output_2, OUTPUT);
pinMode(output_3, OUTPUT);
pinMode(output_4, OUTPUT);
pinMode(output_5, OUTPUT);
pinMode(output_6, OUTPUT);
pinMode(output_7, OUTPUT);
pinMode(output_8, OUTPUT);
// set the pins chosen above to low / off.
digitalWrite(output_1, LOW);
digitalWrite(output_2, LOW);
digitalWrite(output_3, LOW);
digitalWrite(output_4, LOW);
digitalWrite(output_5, LOW);
digitalWrite(output_6, LOW);
digitalWrite(output_7, LOW);
digitalWrite(output_8, LOW);
/* Choose one to begin listening for E1.31 data */
//e131.begin(ssid, passphrase, ip, netmask, gateway, dns); /* via Unicast on the default port */
e131.beginMulticast(ssid, passphrase, universe, ip, netmask, gateway, dns); /* via Multicast with static IP Address */
//e131.beginMulticast(ssid, passphrase, universe); /* via Multicast with DHCP IP Address */
/* Parse a packet */
uint16_t num_channels = e131.parsePacket();
/* Process channel data if we have it */
if (num_channels) {
Serial.println("we have data");
digitalWrite(output_1, (e131.data[0] > 127) ? HIGH : LOW);
digitalWrite(output_2, (e131.data[1] > 127) ? HIGH : LOW);
digitalWrite(output_3, (e131.data[2] > 127) ? HIGH : LOW);
digitalWrite(output_4, (e131.data[3] > 127) ? HIGH : LOW);
digitalWrite(output_5, (e131.data[4] > 127) ? HIGH : LOW);
digitalWrite(output_6, (e131.data[5] > 127) ? HIGH : LOW);
digitalWrite(output_7, (e131.data[6] > 127) ? HIGH : LOW);
digitalWrite(output_8, (e131.data[7] > 127) ? HIGH : LOW);
}//end we have data
} // end void loop
