I want to use the ADC 'A0' to read my analoge values. Therefore I tried the following code:
int numSamples=0;
long t, t0;
ADCSRA = 0; // clear ADCSRA register
ADCSRB = 0; // clear ADCSRB register
ADMUX |= (0 & 0x07); // set A0 analog input pin
ADMUX |= (1 << REFS0); // set reference voltage
ADMUX |= (1 << ADLAR); // left align ADC value to 8 bits from ADCH register
// sampling rate is [ADC clock] / [prescaler] / [conversion clock cycles]
// for Arduino Uno ADC clock is 16 MHz and a conversion takes 13 clock cycles
//ADCSRA |= (1 << ADPS2) | (1 << ADPS0); // 32 prescaler for 38.5 KHz
ADCSRA |= (1 << ADPS2); // 16 prescaler for 76.9 KHz
//ADCSRA |= (1 << ADPS1) | (1 << ADPS0); // 8 prescaler for 153.8 KHz
ADCSRA |= (1 << ADATE); // enable auto trigger
ADCSRA |= (1 << ADIE); // enable interrupts when measurement complete
ADCSRA |= (1 << ADEN); // enable ADC
ADCSRA |= (1 << ADSC); // start ADC measurements
ISR(ADC_vect)
byte x = ADCH; // read 8 bit value from ADC
numSamples++;
if (numSamples>=1000)
t = micros()-t0; // calculate elapsed time
Serial.print("Sampling frequency: ");
Serial.print((float)1000000/t);
Serial.println(" KHz");
delay(2000);
// restart
t0 = micros();
numSamples=0;
That code works fine, but I need to increase the accuracy to a range of 0...1023. I allways found a 8-bit solution. So my question is: how can i increase the accuracy to 10 bit, or is it limited by the 8-bit-databus, which is connected to the ADC-Data-Register?
Many Thanks..
Dave
