MegaAVR (Arduino Uno WiFi Rev 2) compatibility with OV7670?
Hi all,
I am trying to capture an image using a OV7670
connected to an Arduino Uno WiFi Rev 2.
I understand that (OV7670 with both arduino uno and now mega) have some examples but none can be found relating to MegaAVR, especially on Arduino Uno WiFi Rev 2 and OV7670.
Using the example given in that forum (GitHub - ComputerNerd/ov7670-no-ram-arduino-uno: Allows you to use a non fifo ov7670 on the arudino uno without external spi ram like other examples. Sends the data to UART.), I have created a circuit connection sketch
However, running this code does not work.
#define F_CPU 16000000UL
#include <stdint.h>
#include <avr/io.h>
#include <util/twi.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#include "ov7670.h"
static const struct regval_list vga_ov7670[] PROGMEM = {
	{REG_HREF,0xF6},	// was B6
	{0x17,0x13},		// HSTART
	{0x18,0x01},		// HSTOP
	{0x19,0x02},		// VSTART
	{0x1a,0x7a},		// VSTOP
	{REG_VREF,0x0a},	// VREF
	{0xff, 0xff},		/* END MARKER */
static const struct regval_list qvga_ov7670[] PROGMEM = {
	{REG_COM14, 0x19},
	{0x72, 0x11},
	{0x73, 0xf1},
	{REG_HSTART,0x16},
	{REG_HSTOP,0x04},
	{REG_HREF,0x24},
	{REG_VSTART,0x02},
	{REG_VSTOP,0x7a},
	{REG_VREF,0x0a},
static const struct regval_list qqvga_ov7670[] PROGMEM = {
	{REG_COM14, 0x1a},	// divide by 4
	{0x72, 0x22},		// downsample by 4
	{0x73, 0xf2},		// divide by 4
	{REG_HSTART,0x16},
	{REG_HSTOP,0x04},
	{REG_HREF,0xa4},
	{REG_VSTART,0x02},
	{REG_VSTOP,0x7a},
	{REG_VREF,0x0a},
static const struct regval_list yuv422_ov7670[] PROGMEM = {
	{REG_COM7, 0x0},	/* Selects YUV mode */
	{REG_RGB444, 0},	/* No RGB444 please */
	{REG_COM1, 0},
	{REG_COM15, COM15_R00FF},
	{REG_COM9, 0x6A},	/* 128x gain ceiling; 0x8 is reserved bit */
	{0x4f, 0x80},		/* "matrix coefficient 1" */
	{0x50, 0x80},		/* "matrix coefficient 2" */
	{0x51, 0},		/* vb */
	{0x52, 0x22},		/* "matrix coefficient 4" */
	{0x53, 0x5e},		/* "matrix coefficient 5" */
	{0x54, 0x80},		/* "matrix coefficient 6" */
	{REG_COM13,/*COM13_GAMMA|*/COM13_UVSAT},
static const struct regval_list rgb565_ov7670[] PROGMEM = {
	{REG_COM7, COM7_RGB}, /* Selects RGB mode */
	{REG_COM1, 0x0},
	{REG_COM15, COM15_RGB565|COM15_R00FF},
	{0x4f, 0xb3},		 /* "matrix coefficient 1" */
	{0x50, 0xb3},		 /* "matrix coefficient 2" */
	{0x51, 0},		 /* vb */
	{0x52, 0x3d},		 /* "matrix coefficient 4" */
	{0x53, 0xa7},		 /* "matrix coefficient 5" */
	{0x54, 0xe4},		 /* "matrix coefficient 6" */
	{REG_COM13, /*COM13_GAMMA|*/COM13_UVSAT},
static const struct regval_list bayerRGB_ov7670[] PROGMEM = {
	{REG_COM7, COM7_BAYER},
	{REG_COM13, 0x08}, /* No gamma, magic rsvd bit */
	{REG_COM16, 0x3d}, /* Edge enhancement, denoise */
	{REG_REG76, 0xe1}, /* Pix correction, magic rsvd */
static const struct regval_list ov7670_default_regs[] PROGMEM = {//from the linux driver
	{REG_COM7, COM7_RESET},
	{REG_TSLB,  0x04},	/* OV */
	{REG_COM7, 0},	/* VGA */
	 * Set the hardware window.  These values from OV don't entirely
	 * make sense - hstop is less than hstart.  But they work...
	{REG_HSTART, 0x13},	{REG_HSTOP, 0x01},
	{REG_HREF, 0xb6},	{REG_VSTART, 0x02},
	{REG_VSTOP, 0x7a},	{REG_VREF, 0x0a},
	{REG_COM3, 0},	{REG_COM14, 0},
	/* Mystery scaling numbers */
	{0x70, 0x3a},		{0x71, 0x35},
	{0x72, 0x11},		{0x73, 0xf0},
	{0xa2,/* 0x02 changed to 1*/1},{REG_COM10, COM10_VS_NEG},
	/* Gamma curve values */
	{0x7a, 0x20},		{0x7b, 0x10},
	{0x7c, 0x1e},		{0x7d, 0x35},
	{0x7e, 0x5a},		{0x7f, 0x69},
	{0x80, 0x76},		{0x81, 0x80},
	{0x82, 0x88},		{0x83, 0x8f},
	{0x84, 0x96},		{0x85, 0xa3},
	{0x86, 0xaf},		{0x87, 0xc4},
	{0x88, 0xd7},		{0x89, 0xe8},
	/* AGC and AEC parameters.  Note we start by disabling those features,
	   then turn them only after tweaking the values. */
	{REG_COM8, COM8_FASTAEC | COM8_AECSTEP},
	{REG_GAIN, 0},	{REG_AECH, 0},
	{REG_COM4, 0x40}, /* magic reserved bit */
	{REG_COM9, 0x18}, /* 4x gain + magic rsvd bit */
	{REG_BD50MAX, 0x05},	{REG_BD60MAX, 0x07},
	{REG_AEW, 0x95},	{REG_AEB, 0x33},
	{REG_VPT, 0xe3},	{REG_HAECC1, 0x78},
	{REG_HAECC2, 0x68},	{0xa1, 0x03}, /* magic */
	{REG_HAECC3, 0xd8},	{REG_HAECC4, 0xd8},
	{REG_HAECC5, 0xf0},	{REG_HAECC6, 0x90},
	{REG_HAECC7, 0x94},
	{REG_COM8, COM8_FASTAEC|COM8_AECSTEP|COM8_AGC|COM8_AEC},
	{0x30,0},{0x31,0},//disable some delays
	/* Almost all of these are magic "reserved" values.  */
	{REG_COM5, 0x61},	{REG_COM6, 0x4b},
	{0x16, 0x02},		{REG_MVFP, 0x07},
	{0x21, 0x02},		{0x22, 0x91},
	{0x29, 0x07},		{0x33, 0x0b},
	{0x35, 0x0b},		{0x37, 0x1d},
	{0x38, 0x71},		{0x39, 0x2a},
	{REG_COM12, 0x78},	{0x4d, 0x40},
	{0x4e, 0x20},		{REG_GFIX, 0},
	/*{0x6b, 0x4a},*/		{0x74,0x10},
	{0x8d, 0x4f},		{0x8e, 0},
	{0x8f, 0},		{0x90, 0},
	{0x91, 0},		{0x96, 0},
	{0x9a, 0},		{0xb0, 0x84},
	{0xb1, 0x0c},		{0xb2, 0x0e},
	{0xb3, 0x82},		{0xb8, 0x0a},
	/* More reserved magic, some of which tweaks white balance */
	{0x43, 0x0a},		{0x44, 0xf0},
	{0x45, 0x34},		{0x46, 0x58},
	{0x47, 0x28},		{0x48, 0x3a},
	{0x59, 0x88},		{0x5a, 0x88},
	{0x5b, 0x44},		{0x5c, 0x67},
	{0x5d, 0x49},		{0x5e, 0x0e},
	{0x6c, 0x0a},		{0x6d, 0x55},
	{0x6e, 0x11},		{0x6f, 0x9e}, /* it was 0x9F "9e for advance AWB" */
	{0x6a, 0x40},		{REG_BLUE, 0x40},
	{REG_RED, 0x60},
	{REG_COM8, COM8_FASTAEC|COM8_AECSTEP|COM8_AGC|COM8_AEC|COM8_AWB},
	/* Matrix coefficients */
	{0x4f, 0x80},		{0x50, 0x80},
	{0x51, 0},		{0x52, 0x22},
	{0x53, 0x5e},		{0x54, 0x80},
	{0x58, 0x9e},
	{REG_COM16, COM16_AWBGAIN},	{REG_EDGE, 0},
	{0x75, 0x05},		{REG_REG76, 0xe1},
	{0x4c, 0},		{0x77, 0x01},
	{REG_COM13, /*0xc3*/0x48},	{0x4b, 0x09},
	{0xc9, 0x60},		/*{REG_COM16, 0x38},*/
	{0x56, 0x40},
	{0x34, 0x11},		{REG_COM11, COM11_EXP|COM11_HZAUTO},
	{0xa4, 0x82/*Was 0x88*/},		{0x96, 0},
	{0x97, 0x30},		{0x98, 0x20},
	{0x99, 0x30},		{0x9a, 0x84},
	{0x9b, 0x29},		{0x9c, 0x03},
	{0x9d, 0x4c},		{0x9e, 0x3f},
	{0x78, 0x04},
	/* Extra-weird stuff.  Some sort of multiplexor register */
	{0x79, 0x01},		{0xc8, 0xf0},
	{0x79, 0x0f},		{0xc8, 0x00},
	{0x79, 0x10},		{0xc8, 0x7e},
	{0x79, 0x0a},		{0xc8, 0x80},
	{0x79, 0x0b},		{0xc8, 0x01},
	{0x79, 0x0c},		{0xc8, 0x0f},
	{0x79, 0x0d},		{0xc8, 0x20},
	{0x79, 0x09},		{0xc8, 0x80},
	{0x79, 0x02},		{0xc8, 0xc0},
	{0x79, 0x03},		{0xc8, 0x40},
	{0x79, 0x05},		{0xc8, 0x30},
	{0x79, 0x26},
static void errorLed(void){
	DDRB|=32;//make sure led is output
	while(1){//wait for reset
		PORTB^=32;// toggle led
		_delay_ms(100);
static void twiStart(void){
	TWCR=_BV(TWINT)| _BV(TWSTA)| _BV(TWEN);//send start
	while(!(TWCR & (1<<TWINT)));//wait for start to be transmitted
	if((TWSR & 0xF8)!=TW_START)
		errorLed();
static void twiWriteByte(uint8_t DATA,uint8_t type){
	TWDR = DATA;
	TWCR = _BV(TWINT) | _BV(TWEN);		/* clear interrupt to start transmission */
	while (!(TWCR & (1<<TWINT)));		/* wait for transmission */
	if ((TWSR & 0xF8) != type)
		errorLed();
void wrReg(uint8_t reg,uint8_t dat){
	//send start condition
	twiStart();
	twiWriteByte(OV7670_I2C_ADDRESS<<1,TW_MT_SLA_ACK);
	twiWriteByte(reg,TW_MT_DATA_ACK);
	twiWriteByte(dat,TW_MT_DATA_ACK);
	TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);//send stop
	_delay_ms(1);
static uint8_t twiRd(uint8_t nack){
	if (nack){
		TWCR=_BV(TWINT) | _BV(TWEN);
		while ((TWCR & _BV(TWINT)) == 0);	/* wait for transmission */
		if ((TWSR & 0xF8) != TW_MR_DATA_NACK)
			errorLed();
	}else{
		TWCR=_BV(TWINT) | _BV(TWEN) | _BV(TWEA);
		while ((TWCR & _BV(TWINT)) == 0) ; /* wait for transmission */
		if ((TWSR & 0xF8) != TW_MR_DATA_ACK)
			errorLed();
	return TWDR;
uint8_t rdReg(uint8_t reg){
	uint8_t dat;
	twiStart();
	_delay_ms(1);
	twiStart();
	twiWriteByte((OV7670_I2C_ADDRESS<<1)|1,TW_MR_SLA_ACK);
	dat=twiRd(1);
	_delay_ms(1);
	return dat;
static void wrSensorRegs8_8(const struct regval_list reglist[]){
	const struct regval_list *next = reglist;
	for(;;){
		uint8_t reg_addr = pgm_read_byte(&next->reg_num);
		uint8_t reg_val = pgm_read_byte(&next->value);
		if((reg_addr==255)&&(reg_val==255))
		wrReg(reg_addr, reg_val);
		next++;
void setColorSpace(enum COLORSPACE color){
	switch(color){
		case YUV422:
			wrSensorRegs8_8(yuv422_ov7670);
		case RGB565:
			wrSensorRegs8_8(rgb565_ov7670);
			{uint8_t temp=rdReg(0x11);
			_delay_ms(1);
			wrReg(0x11,temp);}//according to the Linux kernel driver rgb565 PCLK needs rewriting
		case BAYER_RGB:
			wrSensorRegs8_8(bayerRGB_ov7670);
void setRes(enum RESOLUTION res){
	switch(res){
		case VGA:
			wrReg(REG_COM3,0);	// REG_COM3
			wrSensorRegs8_8(vga_ov7670);
		case QVGA:
			wrReg(REG_COM3,4);	// REG_COM3 enable scaling
			wrSensorRegs8_8(qvga_ov7670);
		case QQVGA:
			wrSensorRegs8_8(qqvga_ov7670);
void camInit(void){
	wrReg(0x12, 0x80);//Reset the camera.
	_delay_ms(100);
	wrSensorRegs8_8(ov7670_default_regs);
	wrReg(REG_COM10,32);//PCLK does not toggle on HBLANK.
Can any kind soul here please guide me on debugging the issue (both hardware and program)? Additionally, is it necessary to connect all the pins in OV7670, is there a way to reduce the wires?
Please translate the Frizing picture to real schematics. Pin positions are not good enough.
And that sentence provides zero useful information. And I'm certainly not going to play 20 questions with you to draw out exactly HOW it does not work. Providing that information up front is your responsibility.
Code like this is very specific to the ATmega328 family.
And code like this... no, just no.
i noticed that my 5v was not powering the OV7670, would this connection suffice?
The serial clk is voltage converted to 3.3 volt level but SDA is not. That looks not good.
In general, any AVR does not have enough RAM to do anything meaningful with camera images. A 640x480 image would occupy at least 28k of RAM, and the UnoWiFi2 has 6k.
The example you linked is not an Arduino sketch. (What have to done to make it one?) It reads bytes from the camera and immediate sends them out the serials port, never storing the image on the Arduino. If that's all you need, it might be possible, I guess...
You need to be using an esp32, that board can't handle a camera.
