i wanna to do connect between Arduino Mega 2560 and ov7670
i try this connection
with this code
but when i try to run it stop there without and output
Do not post screen shots, never ever post fritzing diagram and google before posting a question.
Mark
PS You wasted your money on the ov7670 you should have googled first!
M
i search on google for more than month without any solution iam a student in IT and i try to solve my problem there if u have a solution help me if not then not write this post.
any way ty for nothing
This page would suggest that you need an interface shield to use that camera with a low speed microcontroller like a Uno.
ty but the "ArduCAM_OV7670_Camera_Playback.ino" is not work can u send me othere link with many thanks for ur time for help me
Omany:
You may want to read [SOLVED] Problem with camera module OV7670 - Sensors - Arduino Forum where the person got it working.
ieee488:
You may want to read https://forum.arduino.cc/index.php?topic=535819.0 where the person got it working..
ty sir i try it now ![]()
it's not work good the image is not good
up
Omany:
up
Don't do this.
If you want help you need to give more details: all you've said so far is that the image isn't good. If you are using a camera and the image isn't good, do you think the problem is likely to like in the Arduino or the quality of the camera?
BJHenry:
Don't do this.
i use this sketch
and this code
// Pins configurations:
// SDA/SIOD ---> pin A4 (for Arduino UNO) | pin 20/SDA (for Arduino MEGA)
// SCL/SIOC ---> pin A5 (for Arduino UNO) | pin 21/SCL (for Arduino MEGA)
// MCLK/XCLK --> pin 11 (for Arduino UNO) | pin 10 (for Arduino MEGA)
// PCLK -------> pin 2
// VS/VSYNC ---> pin 3
// HS/HREF ----> pin 8
// D0 ---------> pin A0
// D1 ---------> pin A1
// D2 ---------> pin A2
// D3 ---------> pin A3
// D4 ---------> pin 4
// D5 ---------> pin 5
// D6 ---------> pin 6
// D7 ---------> pin 7
#include <Wire.h>
#define CAMERA_ADDRESS 0x21
// Definitions of functions for manipulating the Arduino boards pins according to each Arduino board registers, so the code will work for both Arduino UNO and Arduino MEGA:
// The only change is the connections of the SDA/SIOD, SCL/SIOC and MCLK/XCLK pins to each board (see the pins configurations above).
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) // If you are using Arduino MEGA the IDE will automatically define the "__AVR_ATmega1280__" or "__AVR_ATmega2560__" constants.
#define TIMER2_PWM_A_PIN_MODE_OUTPUT() ({ DDRB |= 0b00010000; })
#define PIN2_DIGITAL_READ() ({ (PINE & 0b00010000) == 0 ? LOW : HIGH; })
#define PIN3_DIGITAL_READ() ({ (PINE & 0b00100000) == 0 ? LOW : HIGH; })
#define PIN4_DIGITAL_READ() ({ (PING & 0b00100000) == 0 ? LOW : HIGH; })
#define PIN5_DIGITAL_READ() ({ (PINE & 0b00001000) == 0 ? LOW : HIGH; })
#define PIN6_DIGITAL_READ() ({ (PINH & 0b00001000) == 0 ? LOW : HIGH; })
#define PIN7_DIGITAL_READ() ({ (PINH & 0b00010000) == 0 ? LOW : HIGH; })
#define PIN8_DIGITAL_READ() ({ (PINH & 0b00100000) == 0 ? LOW : HIGH; })
#define PINA0_DIGITAL_READ() ({ (PINF & 0b00000001) == 0 ? LOW : HIGH; })
#define PINA1_DIGITAL_READ() ({ (PINF & 0b00000010) == 0 ? LOW : HIGH; })
#define PINA2_DIGITAL_READ() ({ (PINF & 0b00000100) == 0 ? LOW : HIGH; })
#define PINA3_DIGITAL_READ() ({ (PINF & 0b00001000) == 0 ? LOW : HIGH; })
#elif defined(__AVR_ATmega328P__) // If you are using Arduino UNO the IDE will automatically define the "__AVR_ATmega328P__" constant.
#define TIMER2_PWM_A_PIN_MODE_OUTPUT() ({ DDRB |= 0b00001000; })
#define PIN2_DIGITAL_READ() ({ (PIND & 0b00000100) == 0 ? LOW : HIGH; })
#define PIN3_DIGITAL_READ() ({ (PIND & 0b00001000) == 0 ? LOW : HIGH; })
#define PIN4_DIGITAL_READ() ({ (PIND & 0b00010000) == 0 ? LOW : HIGH; })
#define PIN5_DIGITAL_READ() ({ (PIND & 0b00100000) == 0 ? LOW : HIGH; })
#define PIN6_DIGITAL_READ() ({ (PIND & 0b01000000) == 0 ? LOW : HIGH; })
#define PIN7_DIGITAL_READ() ({ (PIND & 0b10000000) == 0 ? LOW : HIGH; })
#define PIN8_DIGITAL_READ() ({ (PINB & 0b00000001) == 0 ? LOW : HIGH; })
#define PINA0_DIGITAL_READ() ({ (PINC & 0b00000001) == 0 ? LOW : HIGH; })
#define PINA1_DIGITAL_READ() ({ (PINC & 0b00000010) == 0 ? LOW : HIGH; })
#define PINA2_DIGITAL_READ() ({ (PINC & 0b00000100) == 0 ? LOW : HIGH; })
#define PINA3_DIGITAL_READ() ({ (PINC & 0b00001000) == 0 ? LOW : HIGH; })
#endif
void initializePWMTimer() {
cli();
TIMER2_PWM_A_PIN_MODE_OUTPUT(); // Set the A PWM pin of TIMER2 to output
ASSR &= ~(_BV(EXCLK) | _BV(AS2));
TCCR2A = (1 << COM2A0) | (1 << WGM21) | (1 << WGM20);
TCCR2B = (1 << WGM22) | (1 << CS20);
OCR2A = 0;
sei();
byte readCameraRegister(byte registerId) {
Wire.beginTransmission(CAMERA_ADDRESS);
Wire.write(registerId);
Wire.endTransmission();
Wire.requestFrom(CAMERA_ADDRESS, 1);
while (Wire.available() <= 0);
byte registerValue = Wire.read();
delay(1);
return registerValue;
void writeCameraRegister(byte registerId, byte registerValue) {
Wire.write(registerValue);
delay(1);
void captureFrame(unsigned int frameWidth, unsigned int frameHeight) {
Serial.print("*RDY*"); // send to the frame capture software a "start of frame" message for beginning capturing
cli(); // disable all interrupts during frame capture (because it needs to be as fast as possible)
while (PIN3_DIGITAL_READ() == LOW); // wait until VS/VSYNC pin is high
while (PIN3_DIGITAL_READ() == HIGH); // wait until VS/VSYNC pin is low
unsigned int tempWidth = 0;
while (frameHeight--) {
tempWidth = frameWidth;
while (tempWidth--) {
while (PIN2_DIGITAL_READ() == LOW); // wait until PCLK pin is high
while (PIN2_DIGITAL_READ() == HIGH); // wait until PCLK pin is low
byte byteToWrite = 0b00000000;
byteToWrite |= ((PIN7_DIGITAL_READ() == HIGH) << 7);
byteToWrite |= ((PIN6_DIGITAL_READ() == HIGH) << 6);
byteToWrite |= ((PIN5_DIGITAL_READ() == HIGH) << 5);
byteToWrite |= ((PIN4_DIGITAL_READ() == HIGH) << 4);
byteToWrite |= ((PINA3_DIGITAL_READ() == HIGH) << 3);
byteToWrite |= ((PINA2_DIGITAL_READ() == HIGH) << 2);
byteToWrite |= ((PINA1_DIGITAL_READ() == HIGH) << 1);
byteToWrite |= ((PINA0_DIGITAL_READ() == HIGH));
UDR0 = byteToWrite; // send data via serial connection with UART register (we need to use the serial register directly for fast transfer)
// ignore each second byte (for a grayscale image we only need each first byte, which represents luminescence)
sei(); // enable all interrupts
initializePWMTimer();
Wire.begin();
Serial.begin(1000000); // the frame capture software communicates with the Arduino at a baud rate of 1MHz
captureFrame(320, 240); // capture a frame at QVGA resolution (320 x 240)
but this is output
i use this app to view imge
I would recommend inserting this at the end of your setup() function:
void initializeCamera() {
// these are common registers values for initializing the camera to QVGA (320 x 240) mode at the maximum clock prescaler:
writeCameraRegister(0x12, 0x80); // reset all camera registers to default value
delay(1000); // wait for reset proccess to be done (because it is quite slow)
writeCameraRegister(0x3A, 0x04);
writeCameraRegister(0x12, 0x00);
writeCameraRegister(0x17, 0x13);
writeCameraRegister(0x18, 0x01);
writeCameraRegister(0x32, 0xB6);
writeCameraRegister(0x19, 0x02);
writeCameraRegister(0x1A, 0x7A);
writeCameraRegister(0x03, 0x0A);
writeCameraRegister(0x0C, 0x00);
writeCameraRegister(0x3E, 0x00);
writeCameraRegister(0x70, 0x3A);
writeCameraRegister(0x71, 0x35);
writeCameraRegister(0x72, 0x11);
writeCameraRegister(0x73, 0xF0);
writeCameraRegister(0xA2, 0x01);
writeCameraRegister(0x15, 0x00);
writeCameraRegister(0x7A, 0x20);
writeCameraRegister(0x7B, 0x10);
writeCameraRegister(0x7C, 0x1E);
writeCameraRegister(0x7D, 0x35);
writeCameraRegister(0x7E, 0x5A);
writeCameraRegister(0x7F, 0x69);
writeCameraRegister(0x80, 0x76);
writeCameraRegister(0x81, 0x80);
writeCameraRegister(0x82, 0x88);
writeCameraRegister(0x83, 0x8F);
writeCameraRegister(0x84, 0x96);
writeCameraRegister(0x85, 0xA3);
writeCameraRegister(0x86, 0xAF);
writeCameraRegister(0x87, 0xC4);
writeCameraRegister(0x88, 0xD7);
writeCameraRegister(0x89, 0xE8);
writeCameraRegister(0x13, 0xC0);
writeCameraRegister(0x00, 0x00);
writeCameraRegister(0x10, 0x00);
writeCameraRegister(0x0D, 0x40);
writeCameraRegister(0x14, 0x18);
writeCameraRegister(0xA5, 0x05);
writeCameraRegister(0xAB, 0x07);
writeCameraRegister(0x24, 0x95);
writeCameraRegister(0x25, 0x33);
writeCameraRegister(0x26, 0xE3);
writeCameraRegister(0x9F, 0x78);
writeCameraRegister(0xA0, 0x68);
writeCameraRegister(0xA1, 0x03);
writeCameraRegister(0xA6, 0xD8);
writeCameraRegister(0xA7, 0xD8);
writeCameraRegister(0xA8, 0xF0);
writeCameraRegister(0xA9, 0x90);
writeCameraRegister(0xAA, 0x94);
writeCameraRegister(0x13, 0xC5);
writeCameraRegister(0x30, 0x00);
writeCameraRegister(0x31, 0x00);
writeCameraRegister(0x0E, 0x61);
writeCameraRegister(0x0F, 0x4B);
writeCameraRegister(0x16, 0x02);
writeCameraRegister(0x1E, 0x07);
writeCameraRegister(0x21, 0x02);
writeCameraRegister(0x22, 0x91);
writeCameraRegister(0x29, 0x07);
writeCameraRegister(0x33, 0x0B);
writeCameraRegister(0x35, 0x0B);
writeCameraRegister(0x37, 0x1D);
writeCameraRegister(0x38, 0x71);
writeCameraRegister(0x39, 0x2A);
writeCameraRegister(0x3C, 0x78);
writeCameraRegister(0x4D, 0x40);
writeCameraRegister(0x4E, 0x20);
writeCameraRegister(0x69, 0x00);
writeCameraRegister(0x74, 0x10);
writeCameraRegister(0x8D, 0x4F);
writeCameraRegister(0x8E, 0x00);
writeCameraRegister(0x8F, 0x00);
writeCameraRegister(0x90, 0x00);
writeCameraRegister(0x91, 0x00);
writeCameraRegister(0x96, 0x00);
writeCameraRegister(0x9A, 0x00);
writeCameraRegister(0xB0, 0x84);
writeCameraRegister(0xB1, 0x0C);
writeCameraRegister(0xB2, 0x0E);
writeCameraRegister(0xB3, 0x82);
writeCameraRegister(0xB8, 0x0A);
writeCameraRegister(0x43, 0x0A);
writeCameraRegister(0x44, 0xF0);
writeCameraRegister(0x45, 0x34);
writeCameraRegister(0x46, 0x58);
writeCameraRegister(0x47, 0x28);
writeCameraRegister(0x48, 0x3A);
writeCameraRegister(0x59, 0x88);
writeCameraRegister(0x5A, 0x88);
writeCameraRegister(0x5B, 0x44);
writeCameraRegister(0x5C, 0x67);
writeCameraRegister(0x5D, 0x49);
writeCameraRegister(0x5E, 0x0E);
writeCameraRegister(0x6C, 0x0A);
writeCameraRegister(0x6D, 0x55);
writeCameraRegister(0x6E, 0x11);
writeCameraRegister(0x6F, 0x9E);
writeCameraRegister(0x6A, 0x40);
writeCameraRegister(0x01, 0x40);
writeCameraRegister(0x02, 0x60);
writeCameraRegister(0x13, 0xC7);
writeCameraRegister(0x4F, 0x80);
writeCameraRegister(0x50, 0x80);
writeCameraRegister(0x51, 0x00);
writeCameraRegister(0x52, 0x22);
writeCameraRegister(0x53, 0x5E);
writeCameraRegister(0x54, 0x80);
writeCameraRegister(0x58, 0x9E);
writeCameraRegister(0x41, 0x08);
writeCameraRegister(0x3F, 0x00);
writeCameraRegister(0x75, 0x05);
writeCameraRegister(0x76, 0xE1);
writeCameraRegister(0x4C, 0x00);
writeCameraRegister(0x77, 0x01);
writeCameraRegister(0x3D, 0x48);
writeCameraRegister(0x4B, 0x09);
writeCameraRegister(0xC9, 0x60);
writeCameraRegister(0x56, 0x40);
writeCameraRegister(0x34, 0x11);
writeCameraRegister(0x3B, 0x12);
writeCameraRegister(0xA4, 0x82);
writeCameraRegister(0x97, 0x30);
writeCameraRegister(0x98, 0x20);
writeCameraRegister(0x99, 0x30);
writeCameraRegister(0x9A, 0x84);
writeCameraRegister(0x9B, 0x29);
writeCameraRegister(0x9C, 0x03);
writeCameraRegister(0x9D, 0x4C);
writeCameraRegister(0x9E, 0x3F);
writeCameraRegister(0x78, 0x04);
writeCameraRegister(0x79, 0x01);
writeCameraRegister(0xC8, 0xF0);
writeCameraRegister(0x79, 0x0F);
writeCameraRegister(0xC8, 0x00);
writeCameraRegister(0x79, 0x10);
writeCameraRegister(0xC8, 0x7E);
writeCameraRegister(0x79, 0x0A);
writeCameraRegister(0xC8, 0x80);
writeCameraRegister(0x79, 0x0B);
writeCameraRegister(0xC8, 0x01);
writeCameraRegister(0x79, 0x0C);
writeCameraRegister(0xC8, 0x0F);
writeCameraRegister(0x79, 0x0D);
writeCameraRegister(0xC8, 0x20);
writeCameraRegister(0x79, 0x09);
writeCameraRegister(0x79, 0x02);
writeCameraRegister(0xC8, 0xC0);
writeCameraRegister(0x79, 0x03);
writeCameraRegister(0xC8, 0x40);
writeCameraRegister(0x79, 0x05);
writeCameraRegister(0xC8, 0x30);
writeCameraRegister(0x79, 0x26);
writeCameraRegister(0xFF, 0xFF);
writeCameraRegister(0x15, 0x20);
writeCameraRegister(0x0C, 0x04);
writeCameraRegister(0x3E, 0x19);
writeCameraRegister(0x73, 0xF1);
writeCameraRegister(0x17, 0x16);
writeCameraRegister(0x18, 0x04);
writeCameraRegister(0x32, 0xA4);
writeCameraRegister(0x8C, 0x00);
writeCameraRegister(0x04, 0x00);
writeCameraRegister(0x40, 0xC0);
writeCameraRegister(0x14, 0x6A);
writeCameraRegister(0x3D, 0x40);
writeCameraRegister(0x11, 0x1F);
writeCameraRegister(0x0C, 0x08);
writeCameraRegister(0x12, 0x10);
delay(1000); // wait for registers to be set (because it is quite slow)
As recommended here. If that doesn't help then I don't know what to do next.
BJHenry:
I would recommend inserting this at the end of your setup() function:void initializeCamera() {
As recommended [here](https://forum.arduino.cc/index.php?topic=535819.0). If that doesn't help then I don't know what to do next.
i try it but no change
up
