Hello,
Here is the code a,d the error message, in French but i'm sure you will understand
Le croquis utilise 35628 octets (110%) de l'espace de stockage de programmes. Le maximum est de 32256 octets.
Les variables globales utilisent 2238 octets (109%) de mémoire dynamique, ce qui laisse -190 octets pour les variables locales. Le maximum est de 2048 octets.
Croquis trop gros; vois https://support.arduino.cc/hc/en-us/articles/360013825179 pour des conseils de réduction.
text section exceeds available space in board
Compilation error: text section exceeds available space in board
/************************* Library ***************************/
#include <SPI.h>
#include "Adafruit_MQTT_Client.h"
#include <Ethernet.h>
#include <Adafruit_BME280.h>
#include <SD.h>
/************************* Ethernet Client Setup *****************************/
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEC};
IPAddress myDns(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
EthernetServer server(80);
/************************* SD Card *********************************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME "xxxx"
#define AIO_KEY "xxxxx"
/************ Global State ******************/
EthernetClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
#define halt(s) { Serial.println(F( s )); while(1); }
/************************* Input Setup *********************************/
#define adresseI2CduBME280 0x76
Adafruit_BME280 bme;
/****************************** Feeds ***************************************/
Adafruit_MQTT_Publish publi_temperature = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/temperature");
Adafruit_MQTT_Publish publi_humidite = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/humidite");
/****************************** Other ***************************************/
#define error(s) error_P(PSTR(s))
#define BUFSIZ 100
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode())
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
char* strupper( char* s )
// helper function char array to uppercase letters
for (char* p = s; *p; ++p)
*p = toupper( *p );
return s;
char* strlower( char* s )
// helper function char array to lowercase letters
*p = tolower( *p );
return s;
/*------------------------------------ Setup ------------------------------------*/
Serial.println(F("Debut programme"));
Serial.print(F("\nInit the Client..."));
Ethernet.begin(mac);
delay(1000); //give the ethernet a second to initialize
bme.begin(adresseI2CduBME280);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
PgmPrintln("Done");
server.begin();
/*------------------------------------ Loop ------------------------------------*/
// Ensure the connection to the MQTT server is alive (this will make the first
// connection and automatically reconnect when disconnected). See the MQTT_connect
// function definition further below.
MQTT_connect();
//Serial.print(F(bme.readTemperature() ));
//Serial.println("C°");
//Serial.print(bme.readHumidity());
//Serial.println("%");
publi_temperature.publish(bme.readTemperature()) ;
publi_humidite.publish(bme.readHumidity()) ;
// ping the server to keep the mqtt connection alive
if(! mqtt.ping())
mqtt.disconnect();
{ //Loop file server
char clientline[BUFSIZ];
int index = 0;
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
// reset the input buffer
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// If it isn't a new line, add the character to the buffer
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
// Print it out for debugging
Serial.println(clientline);
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
// print all the files, use a helper to keep it clean
client.println("<h2>Files:</h2>");
ListFiles(client, LS_SIZE);
} else if (strstr(clientline, "GET /") != 0) {
// this time no space after the /, so a sub-file!
char *filename;
filename = clientline + 5; // look after the "GET /" (5 chars)
// a little trick, look for the " HTTP/1.1" string and
// turn the first character of the substring into a 0 to clear it out.
(strstr(clientline, " HTTP"))[0] = 0;
// print the file we want
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println();
client.println("<h2>File Not Found!</h2>");
Serial.println("Opened!");
strlower(filename);
if (strstr(filename,".htm")!=NULL)
else if (strstr(filename,".jpg")!=NULL)
client.println("Content-Type: image/jpg");
client.println("Content-Type: text/plain");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
// uncomment the serial to debug (slow!)
//Serial.print((char)c);
client.print((char)c);
file.close();
// everything else is a 404
client.println();
// give the web browser time to receive the data
delay(1);
client.stop();
delay(3000);
/************************* Void *****************************/
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect()
int8_t ret;
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000); // wait 5 seconds
Serial.println("MQTT Connected!");
void ListFiles(EthernetClient client, uint8_t flags)
// This code is just copied from SdFile.cpp in the SDFat library
// and tweaked to print to the client output in html!
dir_t p;
root.rewind();
client.println("<ul>");
while (root.readDir(p) > 0) {
// done if past last used entry
if (p.name[0] == DIR_NAME_FREE) break;
// skip deleted entry and entries for . and ..
if (p.name[0] == DIR_NAME_DELETED || p.name[0] == '.') continue;
// only list subdirectories and files
if (!DIR_IS_FILE_OR_SUBDIR(&p)) continue;
// print any indent spaces
client.print("<li><a href=\"");
for (uint8_t i = 0; i < 11; i++) {
if (p.name[i] == ' ') continue;
if (i == 8) {
client.print('.');
client.print((char)p.name[i]);
client.print("\">");
// print file name with possible blank fill
if (i == 8) {
client.print('.');
client.print("</a>");
if (DIR_IS_SUBDIR(&p)) {
client.print('/');
// print modify date/time if requested
if (flags & LS_DATE) {
root.printFatDate(p.lastWriteDate);
client.print(' ');
root.printFatTime(p.lastWriteTime);
// print size if requested
if (!DIR_IS_SUBDIR(&p) && (flags & LS_SIZE)) {
client.print(' ');
client.print(p.fileSize);
client.println("</li>");
client.println("</ul>");
