#include <Arduino.h>
#include <SPI.h>
#include <TFT_eSPI.h>
#include "utilities.h"
typedef struct {
uint8_t cmd;
uint8_t data[14];
uint8_t len;
} lcd_cmd_t;
lcd_cmd_t lcd_st7789v[] = {
{0x01, {0}, 0 | 0x80},
{0x11, {0}, 0 | 0x80},
{0x3A, {0X05}, 1},
{0x36, {0x55}, 1},
{0xB2, {0x0C, 0x0C, 0X00, 0X33, 0X33}, 5},
{0xB7, {0X75}, 1},
{0xBB, {0X1A}, 1},
{0xC0, {0X2C}, 1},
{0xC2, {0X01}, 1},
{0xC3, {0X13}, 1},
{0xC4, {0X20}, 1},
{0xC6, {0X0F}, 1},
{0xD0, {0XA4, 0XA1}, 2},
{0xD6, {0XA1}, 1},
{0xE0, {0XD0, 0X0D, 0X14, 0X0D, 0X0D, 0X09, 0X38, 0X44, 0X4E, 0X3A, 0X17, 0X18, 0X2F, 0X30}, 14},
{0xE1, {0XD0, 0X09, 0X0F, 0X08, 0X07, 0X14, 0X37, 0X44, 0X4D, 0X38, 0X15, 0X16, 0X2C, 0X3E}, 14},
{0x21, {0}, 0}, //invertDisplay
{0x29, {0}, 0},
{0x2C, {0}, 0},
TFT_eSPI tft;
// LilyGo T-Deck control backlight chip has 16 levels of adjustment range
// The adjustable range is 0~15, 0 is the minimum brightness, 16 is the maximum brightness
void setBrightness(uint8_t value)
static uint8_t level = 0;
static uint8_t steps = 16;
if (value == 0) {
digitalWrite(BOARD_BL_PIN, 0);
delay(3);
level = 0;
return;
if (level == 0) {
digitalWrite(BOARD_BL_PIN, 1);
level = steps;
delayMicroseconds(30);
int from = steps - level;
int to = steps - value;
int num = (steps + to - from) % steps;
for (int i = 0; i < num; i++) {
level = value;
Serial.println("T-DECK factory");
//! The board peripheral power control pin needs to be set to HIGH when using the peripheral
pinMode(BOARD_POWERON, OUTPUT);
digitalWrite(BOARD_POWERON, HIGH);
//! Set CS on all SPI buses to high level during initialization
pinMode(BOARD_SDCARD_CS, OUTPUT);
pinMode(RADIO_CS_PIN, OUTPUT);
pinMode(BOARD_TFT_CS, OUTPUT);
digitalWrite(BOARD_SDCARD_CS, HIGH);
digitalWrite(RADIO_CS_PIN, HIGH);
digitalWrite(BOARD_TFT_CS, HIGH);
pinMode(BOARD_SPI_MISO, INPUT_PULLUP);
SPI.begin(BOARD_SPI_SCK, BOARD_SPI_MISO, BOARD_SPI_MOSI); //SD
Serial.print("Init display id:");
Serial.println(USER_SETUP_ID);
tft.begin();
* * T-Deck-Plus and T-Deck display panels are different.
* * This initialization is used to override the initialization parameters.
* * It is used when the display is abnormal after the TFT_eSPI update. */
#if 0
for (uint8_t i = 0; i < (sizeof(lcd_st7789v) / sizeof(lcd_cmd_t)); i++) {
tft.writecommand(lcd_st7789v[i].cmd);
for (int j = 0; j < (lcd_st7789v[i].len & 0x7f); j++) {
tft.writedata(lcd_st7789v[i].data[j]);
if (lcd_st7789v[i].len & 0x80) {
delay(120);
#endif
tft.setRotation( 1 );
tft.fillScreen(TFT_BLACK);
tft.setTextDatum(MC_DATUM);
tft.setFreeFont(&FreeSansOblique12pt7b);
tft.drawString("Hello World", TFT_WIDTH / 2, TFT_HEIGHT / 2);
pinMode(BOARD_BL_PIN, OUTPUT);
for (int i = 0; i <= 16; ++i) {
setBrightness(i);
delay(30);
tft.setTextColor(random(0xFFFF));
tft.drawString("Hello World", random(5, 320), random(5, 240));
delay(5000);
This is the HelloWorld example code.
