I am using the Arduino Nano, and I am trying to allocate a lookup array of unsigned chars 50x50.
unsigned char swing_array[50][50] = { {0, 10, 11, 10, ...
When I do this, the program never even reaches the setup() function. In fact, the L ("Load") LED stays lit, whereas usually it blinks upon reset.
However, when I reduce the size of the array to, say, 200 elements. I do not have this problem. I feel like the large array size is proving to have issues. The program compiles and uploads just fine, but when I try to run it, that is where I run into the problem. I made the setup() function print out a message (after Serial.begin) once the function began, and then once the setup() function concludes. Neither of these messages are ever being displayed.
Is there a way to do dynamic memory allocation with the Arduino? I am still only using 18K of the 30K limit, so how do I store this array without having this happen?
