hola, he conseguido hacer funcioanr una matriz led de 8x8 , siguiendo este tutorial, y con el ultimo codigo, usando timer1
http://www.arduino.cc/playground/Main/DirectDriveLEDMatrix
* _8x8 LED matrix
* (c) 2009 BlushingBoy.net
#include "TimerOne.h"
byte rows[8] = {9, 14, 8, 12, 1, 7, 2, 5};
byte cols[8] = {13, 3, 4, 10, 6, 11, 15, 16};
byte pins[16] = {5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
byte screen[8] = {0, 0, 0, 0, 0, 0, 0, 0};
volatile byte screenRow = 0;
volatile byte screenCol = 0;
Timer1.initialize(100);
for (int i = 2; i <= 17; i++)
pinMode(i, OUTPUT);
Timer1.attachInterrupt(doubleBuffer);
// interrupt routine
void doubleBuffer() {
// reset the previous iteration
digitalWrite(translatePin(rows[screenRow]), HIGH); // set previous off
digitalWrite(translatePin(cols[screenCol]), LOW); // set previous off
// go to the next iteration...
// go to the next screenCol, wrap if necessary
screenCol++;
if (screenCol >= 8) {
screenCol = 0;
// when screenCol wraps, go to the next screenRow, wrap if necessary
screenRow++;
if (screenRow >= 8) {
screenRow = 0;
// set this iteration
if((screen[screenRow]>>screenCol)&B1 == B1) {
digitalWrite(translatePin(rows[screenRow]), LOW); // set this on
digitalWrite(translatePin(cols[screenCol]), HIGH); // set this on
digitalWrite(translatePin(rows[screenRow]), HIGH); // set this off
digitalWrite(translatePin(cols[screenCol]), LOW); // set this off
byte translatePin(byte original) {
return pins[original - 1];
void allOFF() {
for (int i = 0; i < 8; i++)
screen[i]=0;
void on(byte row, byte column) {
screen[column-1] |= (B1<<(row-1));
void off(byte row, byte column) {
screen[column-1] &= ~(B1<<(row-1));
// looping some LEDs routine
allOFF();
on(3,3); on(3,4); on(3,5); on(3,6);
delay(400);
allOFF();
on(4,4);
delay(400);
el problema es , que a la matriz se le quedan todos los leds iluminados, cuando yo pensaba que iba a mostrar "hello", tengo poca idea de programacion, pero deduzco que algo esta mal , porque lo que esta en el void loop no "aparece" reflejado en la matriz, es decir siempre muestra todos los leds encendidos
me gustaria que alguien me dijera como poner algun tipo de mensaje
muchas gracias, un saludo
recien cargado el codigo
trasteando con el codigo jeje
pd: siento mi ignorancia, pero estoi intentando aprender
un saludo y gracias
