sorry for my bad english
I am a college student, I want to make a medical device that can detect heartbeat, blood oxygen and heart rate. so, I use two main input components.
the first is max30100, I connect it to the oled display to display the output
the second is ad8232, processing IDE
I use Arduino Mega. after the circuit is complete,I tried to use each program for a component, to check the component and program will ran well
max30100
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#include "Wire.h"
#include "Adafruit_GFX.h"
#include "OakOLED.h"
#define REPORTING_PERIOD_MS 1000
OakOLED oled;
PulseOximeter pox;
uint32_t tsLastReport = 0;
void onBeatDetected()
Serial.println("Beat!");
oled.display();
oled.begin();
oled.clearDisplay();
oled.setTextSize(1);
oled.setTextColor(1);
oled.setCursor(0, 0);
oled.println("Initializing pulse oximeter..");
oled.display();
Serial.print("Initializing pulse oximeter..");
if (!pox.begin()) {
Serial.println("FAILED");
oled.println("FAILED");
oled.display();
for (;;);
oled.println("SUCCESS");
oled.display();
Serial.println("SUCCESS");
pox.setOnBeatDetectedCallback(onBeatDetected);
pox.update();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
Serial.print("Heart BPM:");
Serial.print(pox.getHeartRate());
Serial.print("-----");
Serial.print("Oxygen Percent:");
Serial.print(pox.getSpO2());
Serial.println("\n");
oled.setCursor(0, 16);
oled.println(pox.getHeartRate());
oled.println("Heart BPM");
oled.setCursor(0, 30);
oled.println("Spo2");
oled.setCursor(0, 45);
oled.println(pox.getSpO2());
oled.display();
tsLastReport = millis();
ad8232
pinMode(10, INPUT);
pinMode(11, INPUT);
if ((digitalRead(10) == 1) || (digitalRead(11) == 1)) {
Serial.println("Gagal");
else {
Serial.println(analogRead(A1));
delay(10);
Serial.end();
delay(10);
when i use the code for max30100, i can see the output display on the oled display and when using code for ad8232, I can see the waveform on my computer monitor. I think this works well and I tried to merge two codes.
merge codes
#include <Wire.h>
#include "Wire.h"
OakOLED oled;
PulseOximeter pox;
oled.display();
//================================LCD OLED======================//
oled.begin();
//================================MAX30100=====================//
oled.display();
if (!pox.begin()) {
oled.display();
for (;;);
oled.display();
//============================AD8232=========================//
pinMode(10, INPUT);
pinMode(11, INPUT);
//==========================MAX30100==========================//
pox.update();
oled.display();
//===================================AD8232=========================//
else {
delay(100);
Serial.end();
delay(100);
the result is that the oled display does not display anything and my monitor has no waveform, only the message "initializing pulse oximeter..FAILED"
I am a beginner but I understand some basic commands. I try my best to merge it.
Am I wrong in merge the two codes? please,can someone tell me my mistake.
thank
