Meter box with float values! using: keypad + Nokia + Nema 23
hello guys.. i need your help
I am buliding this system that i hope i colud use it controlling the meassure of cut in a machine, its for a project in my university and i will be super gratfull if you help me (dont speak perfectly english)
Components
  • arduino Mega
  • Stepper motor Nema 23
  • TB6560 for control de stepper motor
  • Keypad 4x4
  • Nokia 5110
but my specific question is:
I will work in Cm, what can i do for have a number with decimals: "45.4 Cm (example)", the code that i posted works propertly with int or long value: "45 Cm (Example)" but i really need to work with decimals.
I made a little reseach and i can convert a string to a float value with the function atof(), but i dont know how to use it in those specific parts where i think i have to do the convert f the variable.
The idea is have numbers between 0.0 - 250.0 (Cm)
void checknumber(float x){
  if (firstnumber == 99) { // Check if this is the first number entered
    firstnumber=x;
    String displayvalue = String(firstnumber);  //  Transform int to a string for display
    drawnokiascreen(displayvalue); // Redraw Nokia lcd
    if (secondnumber == 99) {  // Check if it's the second number entered
      secondnumber=x;
      String displayvalue = (String(firstnumber) + String(secondnumber));
     if (thirdnumber == 99) {  // Check if it's the third number entered
      thirdnumber=x;
      String displayvalue = (String(firstnumber) + String(secondnumber) + String(thirdnumber));
       } else {  // It must be the 4rd number entered
      fourthnumber=x;
      String displayvalue = (String(firstnumber) + String(secondnumber) + String(thirdnumber)+ String(fourthnumber));
        Serial.println(keyfullnumber);
void deletenumber() {  // Used to backspace entered numbers
   if (fourthnumber !=99) {
    fourthnumber=99;
  if (thirdnumber !=99) {
    thirdnumber=99;
  else {
    if (secondnumber !=99) {
      secondnumber=99;
   else {
     if (firstnumber !=99) {
       String displayvalue = "";
       firstnumber=99;
void calculatedistance() {  // Used to create a full number from entered numbers
    if (fourthnumber == 99 && thirdnumber == 99 && secondnumber == 99 && firstnumber != 99 ) {
      keyfullnumber=firstnumber;
      movestepper(keyfullnumber);
    if (secondnumber != 99 && thirdnumber == 99 && fourthnumber== 99) {
      keyfullnumber=(firstnumber*10)+secondnumber;
    if (thirdnumber != 99 && fourthnumber==99) {
      keyfullnumber=(firstnumber*100)+(secondnumber*10)+thirdnumber;
      if (fourthnumber != 99) {
      keyfullnumber=(firstnumber*1000)+(secondnumber*100)+(thirdnumber*10)+fourthnumber;
    resetnumbers(); // Reset numbers to get ready for new entry
void movestepper(int z) {  //  Move the stepper
  long calculatedmove=((z*1600L)/80);  //  Calculate number of steps needed in mm
  stepper.runToNewPosition(calculatedmove);
  currentposition = String(z);
  u8g.firstPage();
  do {
    u8g.drawHLine(0, 15, 84);
    u8g.drawVLine(50, 16, 38);
    u8g.drawHLine(0, 35, 84);
    u8g.setFont(u8g_font_profont11);
    u8g.drawStr(0, 10, "ENTER DISTANCE");
    u8g.drawStr(62, 29, "Cm");
    u8g.drawStr(4, 46, "cur-pos");
    u8g.setPrintPos(57,47);
    u8g.print(currentposition);
  while( u8g.nextPage() );
void resetnumbers() {  // Reset numbers for next entry
  firstnumber=99;
  secondnumber=99;
  thirdnumber=99;
  fourthnumber=99;
I hope it could be solved i really dont have too much knowledge on systems
Thank you Guys
Here is the complete code
#include <AccelStepper.h> // AccelStepper Library
#include <Keypad.h>  // Keypad Library
#include "U8glib.h"  // U8glib for Nokia LCD
// Variables to hold entered number on Keypad
volatile int firstnumber=99;  // used to tell how many numbers were entered on keypad
volatile int secondnumber=99;
volatile int thirdnumber=99;
volatile int fourthnumber=99;
// Variables to hold Distance and CurrentPosition
int keyfullnumber=0;  // used to store the final calculated distance value
String currentposition = "";  // Used for display on Nokia LCD
// Keypad Setup
const byte ROWS = 4; // Four Rows
const byte COLS = 4; // Four Columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {22, 24, 26, 28}; // Arduino pins connected to the row pins of the keypad
byte colPins[COLS] = {31, 33, 35, 37}; // Arduino pins connected to the column pins of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );  // Keypad Library definition
// U8glib Setup for Nokia LCD
#define backlight_pin 11
U8GLIB_PCD8544 u8g(3, 4, 6, 5, 7);  // Arduino pins connected to Nokia pins:
                                    // CLK=3, DIN=4, CE=6, DC=5, RST=7
// AccelStepper Setup
AccelStepper stepper(1, A0, A1);  // 1 = Easy Driver interface
                                  // Arduino A0 connected to STEP pin of Easy Driver
                                  // Arduino A1 connected to DIR pin of Easy Driver
 #define Limit01 2
 const int ledPin1 =  9;      // <=======  the number of the LED REDpin
const int ledPin2 =  8;       // <=======  the number of the LED GREEN pin
int step_speed = 2;  // Speed of Stepper motor (higher = slower)on Homing mode
void setup(void) {
pinMode(Limit01, INPUT);
pinMode(A1, OUTPUT);
pinMode(A0, OUTPUT);
//pinMode(pot_pin, INPUT);
 pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
while (!digitalRead(Limit01))
digitalWrite(A0, HIGH);
digitalWrite(A1, LOW);//LOW=clocwise/high=anti-clocwise
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin1, HIGH);
delay(step_speed);
digitalWrite(A0, LOW);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin1, LOW);
delay(step_speed);
  //  Light up the LCD backlight LEDS
  analogWrite(backlight_pin, 80);  // Set the Backlight intensity (0=Bright, 255=Dim)
  //  AccelStepper speed and acceleration setup
  stepper.setMaxSpeed(1200);  // Not to fast or you will have missed steps
  stepper.setAcceleration(200);  //  Same here
  // Draw starting screen on Nokia LCD
  u8g.firstPage();
 do {
  u8g.drawStr(0,10, "ENTER DISTANCE");
  u8g.drawStr(57, 47, "Home");     //when hit Home switch
void loop(){
  char keypressed = keypad.getKey();  // Get value of keypad button if pressed
  if (keypressed != NO_KEY){  // If keypad button pressed check which key it was
    switch (keypressed) {
      case '1':
        checknumber(1);
      case '2':
        checknumber(2);
      case '3':
        checknumber(3);
      case '4':
        checknumber(4);
      case '5':
        checknumber(5);
      case '6':
        checknumber(6);
      case '7':
        checknumber(7);
      case '8':
        checknumber(8);
      case '9':
        checknumber(9);
      case '0':
        checknumber(0);
      case '*':
        deletenumber();
      case '#':
        calculatedistance();
    firstnumber=x;
      secondnumber=x;
      thirdnumber=x;
      fourthnumber=x;
    fourthnumber=99;
    thirdnumber=99;
  else {
      secondnumber=99;
   else {
       firstnumber=99;
  u8g.firstPage();
  do {
  firstnumber=99;
  secondnumber=99;
  thirdnumber=99;
  fourthnumber=99;
void drawnokiascreen(String y) {
    u8g.firstPage();
    do {
      u8g.setPrintPos(0,29);
      u8g.print(y);  // Put entered number on Nokia lcd
      u8g.print(currentposition);  //  Display current position of stepper
Don't use floating point, use integers, but work in units of 1mm (or tenths of a mm if you need to work to two decimals of a cm)
TolpuddleSartre:
You are talking about this?
    firstnumber=x;
Because is the only place where i think i am defining as a float , the variable.
sorry if i am wrong but, you are talking about that i have to write it like this ?
void checknumber(int x){
    firstnumber=x;
It is a bad idea to use Strings on Arduino. They cause memory problems and program crashes.
Use C-strings (character arrays) instead.
Hello everyone i need this, maybe is easy for you, but i dont have a lot of knowledge with code. (i dont speek english)
The thing that i want to do is:
Read from a Keypad, some numbers and i will show them into a LCD. i want to create a numer like this:
23.4 cm
I know my code is working, but just creating a number like this: 2345 cm.
The question is.... how can I change my code for take that number with a dot, because i will work between thee range: 0,0 - 250,0 (cm) ......i really dont know what to do
The code:
    firstnumber=x;
      secondnumber=x;
      thirdnumber=x;
      fourthnumber=x;
Google "arduino keypad enter float" for many posts on the subject.
jremington:
ok, Thank you, i was thinking in made a char null- termined with inside all the numbers that i will ask from the kaypad and then convert number it with atof() function into a float point value. do youi think its a good idea ?
Good idea. The function atof() expects a zero terminated character array, not a String object.
