MH-ET Live won't display data on serial monitor
MH ET live Scanner beeps which indicates it has read the barcode but not displaying on screen.
Here are my connections
scanner - arduino
s-rx - pin 3
s-tx - pin 2
vcc - 5v
gnd - gnd
button - pin 8
i am using arduino uno also used arduino mega but still wont get any thing on my serial monitor , i have tried all the possible things availble on different forums, youtube videos but wont get the solution below is my daigram and code,
String inputString = "";      // Variable to store the scanner input
String DataScanner = "";      // Variable for processing the scanner data
bool stringComplete = false;  // Variable to check if the data is completely received
  pinMode(8, OUTPUT);         // Pin for triggering the scanner
  Serial.begin(9600);         // Initialize the main serial communication for debugging
  Serial1.begin(9600);        // Initialize Serial1 for communication with the scanner
  // Reserve 200 characters for the inputString
  inputString.reserve(200);
  Serial.println("Setup complete, starting loop...");
  digitalWrite(8, HIGH);   // Send a logic HIGH signal
  delay(200);              // Wait for 200 milliseconds
  digitalWrite(8, LOW);    // Send a logic LOW signal, simulating a button press to trigger the scanner
  // Check if the data from the scanner is completely received
  if (stringComplete) {
      Serial.print("Received Data: ");
      Serial.println(DataScanner); // Print the received data for debugging
      if (DataScanner == "8859411300023\r\n") { // If the data matches the specified value, print "OK"
          Serial.println("OK");
          Serial.println("No Data"); // If the data doesn't match, print "No Data"
    // Clear the variables for new data
    inputString = "";
    DataScanner = "";
  SerialEvent1 occurs whenever new data comes in the hardware serial RX1. This
  routine is run between each time loop() runs, so using delay inside loop can
  delay response. Multiple bytes of data may be available.
void serialEvent1() {
  while (Serial1.available()) {
    // Get the new byte:
    char inChar = (char)Serial1.read();
    // Add it to the inputString:
    inputString += inChar;
    // If the incoming character is a newline, set a flag so the main loop can
    // do something about it:
    if (inChar == '\n') {
      stringComplete = true;
      DataScanner = String(inputString);
Well, since no one's jumping on this, I'll wade in although I have no idea about "MH-ET Live".
Your connection diagram seems to use D10, D11 on the Uno for some form of serial. Yet, I see nothing in your Uno code that defines a software serial connection. Unless that's done 'behind the curtain' in a library(which I see no #include for...), it's definitely a missing element of the puzzle. If you're a beginner, please provide links to, or copies of, the code you copied from.
Did the scanned item have this code?
