Micro Maestro / Servo Motor
Wird hochgeladen: IMG_6654.jpeg …
Hallo,
ich habe ein Problem mit meinem Micro Maestro.
Und zwar läuft mein Servo Motor nicht. Angeschlossen ist alles wie im Bild zusehen.
/* This example shows how to control Maestro scripts with an
Arduino. It assumes you have an RC hobby servo connected on
channel 0 of your Maestro, and that you have already used the
Maestro Control Center software to verify that the servo is
powered correctly and moves when you command it to from the
Maestro Control Center software.
Before using this example, you should go to the Serial Settings
tab in the Maestro Control Center and apply these settings:
* Serial mode: UART, fixed baud rate
* Baud rate: 9600
* CRC disabled
Be sure to click "Apply Settings" after making any changes.
It also assumes you have connected your Arduino to your Maestro
appropriately. If you have not done so, please see
https://github.com/pololu/maestro-arduino for more details on how
to make the connection between your Arduino and your Maestro.
Also, the Maestro needs to have the script in the comment
below installed on it. */
# Maestro script for Script.ino Arduino library example.
# Copy into the Script tab of the Maestro Control Center and
# click Apply Settings.
# Don't do anything by default.
begin
repeat
# Subroutine 0
sub alternate_mid_to_high
  begin
    6000 0 servo
    1000 delay
    7000 0 servo
    1000 delay
  repeat
# Subroutine 1
# Expects the delay time to be on the top of the stack
sub alternate_mid_to_low
  begin
    6000 0 servo
    dup delay
    5000 0 servo
    dup delay
  repeat
#include <PololuMaestro.h>
/* On boards with a hardware serial port available for use, use
that port to communicate with the Maestro. For other boards,
create a SoftwareSerial object using pin 10 to receive (RX) and
pin 11 to transmit (TX). */
#ifdef SERIAL_PORT_HARDWARE_OPEN
  #define maestroSerial SERIAL_PORT_HARDWARE_OPEN
#else
  #include <SoftwareSerial.h>
  SoftwareSerial maestroSerial(18, 19);
#endif
/* Next, create a Maestro object using the serial port.
Uncomment one of MicroMaestro or MiniMaestro below depending
on which one you have. */
MicroMaestro maestro(maestroSerial);
//MiniMaestro maestro(maestroSerial);
  maestroSerial.begin(9600);
  /* Subroutine numbers can be found by clicking "View Compiled
  Code..." on the Maestro Control Center script tab.
  Restart script at subroutine 0. Subroutine 0 constantly
  alternates the servo position from the neutral position to the
  high end of the range. */
  maestro.restartScript(0);
  delay(4000);
  // Stop the running script.
  maestro.stopScript();
  /* Restart subroutine 1 with the value 2000 on the stack.
  Subroutine 1 constantly alternates the servo position from the
  neutral position to the low end of the range. In this case, The
  parameter put on to the stack represents how long the delay is
  between servo movements.*/
  maestro.restartScriptWithParameter(1, 2000);
  delay(4000);
* Baud rate: 9600
* CRC disabled
begin
repeat
# Subroutine 0
  begin
    6000 0 servo
    1000 delay
    7000 0 servo
    1000 delay
  repeat
# Subroutine 1
  begin
    6000 0 servo
    dup delay
    5000 0 servo
    dup delay
  repeat
#else
#endif
  delay(4000);
  delay(4000);
tippe oder füge den Code hier ein
Im englischen Teil des Forum müssen die Beiträge und Diskussionen in englischer Sprache verfasst werden. Deswegen wurde diese Diskussion in den deutschen Teil des Forums verschoben.
mfg ein Moderator.
Bild nicht da, aber Sketch doppelt
Hallo @sorenert,
herzlich willkommen im Arduino-Forum.
es gibt einige Dinge die das Lösen von Problemen mit Hilfe des Arduino-Forums extrem beschleunigen können.
Das wichtigste ist: ausführliche Beschreibung was genau du für Komponenten benutzt und was du gemacht hast.
So eine ultrakurz-Beschreibung wie
Mit dieser Ultrakurzbeschreibung und der Tatsache, dass das Bild nicht zu sehen ist, vermittelst du den Eindruck, dass du ein "ich möchte das ganz schnell ans laufen bringen"-Mensch bist und dabei ziemlich hektisch vorgehst.
Keine Ahnung ob das wirklich so ist. Es ist jedenfalls der erste Eindruck den man von dir bekommt.
Tja und dann schließen sich eine Menge Fragen an:
welchen exakten Typ Microcontroller benutzt du?
Der Demo-Code verwendet einerseits die IO-pins 18,19 für die serielle Kommunikation die es auf vielen microcontroller-boards gar nicht gibt und verwendet andererseits SoftwareSerial
Das ist schon merkwürdig.
Hast du diese Schritte hier wirklich gemacht?
GitHub - pololu/maestro-arduino: Pololu Maestro Servo Controller library for Arduino for more details on how
begin
repeat
# Subroutine 0
  begin
    6000 0 servo
    1000 delay
    7000 0 servo
    1000 delay
  repeat
# Subroutine 1
  begin
    6000 0 servo
    dup delay
    5000 0 servo
    dup delay
  repeat
Je präzisere Angaben du machst desto schneller wirst du das Ding am Ende am laufen haben.
Du kannst dir aber auch tagelang Zeit nehmen und 20 bis 50 Kurzpostings raushauen nur um die die nächste Detailnachfrage einzufangen.
Wie haste denn das hinbekommen?
Wenn man mit der Maus auf diese Zeile fährt wird der Mauspfeil zur Hand so wie bei Links üblich aber es wird im Browser-Fenster in der linken unteren Ecke kein Link angezeigt?
