** Also I looked at the Arduino DUE schematic and tried connecting :
MOSI-> 26
MISO-> 25
CLK->27
After trying the above things,i am not able to read the SDCard.
Please guide me regarding this.
I added the SdFatBeta20121203.ziP to the arduino ide1.5.6 but when was compliling the SDFATinfo then
compilation was terminated.
/root/Arduino/libraries/SdFat-master/src/SysCall.h:33:17: fatal error: SPI.h: No such file or directory #include <SPI.h>
I then added the #include <SPI.h> but encountered with errors.
i am still not able to interface SDcard adapter with the arduino due board.
Pls guide me.
What errors are you getting?
Also, it isn't obvious how you're connecting the hardware, or even what the hardware is. I would be using the SPI header, but I don't know what those numbers you've listed are for.
The above connections have worked for my SD card. I uploaded the following program for simple write/read operation, and they worked well!
//SIMPLE WRITE AND READ
#include<SPI.h> //sd cARD USES spi bUS
#include<SD.h> //contains library functions
#define CSPIN 4 //slecting DPin-4 does not require to set direction
File myFile; //file pointer variavle declaration
SD.begin(CSPIN); //SD Card is initialized
SD.remove("Test1.txt"); //remove any existing file with this name
myFile = SD.open("Test1.txt", FILE_WRITE); //file created and opened for writing
if(myFile) //file has really been opened
myFile.println(4000);
myFile.println(200);
myFile.println(3000);
myFile.close();
myFile = SD.open("Test1.txt", FILE_READ); //file created and opened for writing
while(myFile.available())
Serial.print((char)myFile.read());
myFile.close();
OK, how did you get that working? I couldn't match the pin numbers with either the Due SPI, SD card, Micro SD card, or one of the many adaptors available (obviously I couldn't tell if the named pins were for the Due or the SD end!)
You happen to be on the correct pins, but the numbering is incorrect (your pin 1 is correct but your pin 4 is actually pin 6). Where did these Due SPI pin numbers originate?
