Hey. I'm trying to test my INMP441 microphone (datasheet) on my Lolin D32 (ESP32) board. I've been going through a lot of different codes on forums, GitHub repos and whatnot but I can't seem to get any of them to work.
I was hoping if anyone could share on insight into this and if I might be doing something wrong? My knowledge level in understanding the microphone and its programming are pretty much in the basics.
Two examples I've been trying to get to work:
Visual Studio Code sketch that prints "�H�!jHH1!)9MJ!)1I�8�␞�)!��!�WH�␌)" (forum post)
* app_main.c
* Created on: 30.03.2017
* Author: michaelboeckling
#include <stdlib.h>
#include <stddef.h>
#include <inttypes.h>
#include <string.h>
#include <stdio.h>
#include <stdbool.h>
#include <sys/time.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_log.h"
#include "driver/i2s.h"
#define TAG "main"
static void init_i2s()
const int sample_rate = 44100;
/* TX: I2S_NUM_0 */
i2s_config_t i2s_config_tx = {
.mode = I2S_MODE_MASTER | I2S_MODE_TX,
.sample_rate = sample_rate,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT, // 2-channels
.communication_format = I2S_COMM_FORMAT_I2S_MSB,
.dma_buf_count = 32, // number of buffers, 128 max.
.dma_buf_len = 32 * 2, // size of each buffer
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1 // Interrupt level 1
i2s_pin_config_t pin_config_tx = {
.bck_io_num = GPIO_NUM_26,
.ws_io_num = GPIO_NUM_25,
.data_out_num = GPIO_NUM_22,
.data_in_num = GPIO_NUM_23
i2s_driver_install(I2S_NUM_0, &i2s_config_tx, 0, NULL);
i2s_set_pin(I2S_NUM_0, &pin_config_tx);
/* RX: I2S_NUM_1 */
i2s_config_t i2s_config_rx = {
.mode = I2S_MODE_MASTER | I2S_MODE_RX, // Only TX
.bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT, // Only 8-bit DAC support
i2s_pin_config_t pin_config_rx = {
.bck_io_num = GPIO_NUM_2,
.ws_io_num = GPIO_NUM_15,
.data_out_num = I2S_PIN_NO_CHANGE,
.data_in_num = GPIO_NUM_13
i2s_driver_install(I2S_NUM_1, &i2s_config_rx, 0, NULL);
i2s_set_pin(I2S_NUM_1, &pin_config_rx);
void task_megaphone(void *pvParams)
uint16_t buf_len = 1024;
char *buf = calloc(buf_len, sizeof(char));
struct timeval tv = {0};
struct timezone *tz = {0};
gettimeofday(&tv, &tz);
uint64_t micros = tv.tv_usec + tv.tv_sec * 1000000;
uint64_t micros_prev = micros;
uint64_t delta = 0;
init_i2s();
int cnt = 0;
int bytes_written = 0;
while(1)
char *buf_ptr_read = buf;
char *buf_ptr_write = buf;
// read whole block of samples
int bytes_read = 0;
while(bytes_read == 0) {
bytes_read = i2s_read_bytes(I2S_NUM_1, buf, buf_len, 0);
uint32_t samples_read = bytes_read / 2 / (I2S_BITS_PER_SAMPLE_32BIT / 8);
// convert 2x 32 bit stereo -> 1 x 16 bit mono
for(int i = 0; i < samples_read; i++) {
// const char samp32[4] = {ptr_l[0], ptr_l[1], ptr_r[0], ptr_r[1]};
// left
buf_ptr_write[0] = buf_ptr_read[2]; // mid
buf_ptr_write[1] = buf_ptr_read[3]; // high
// right
buf_ptr_write[2] = buf_ptr_write[0]; // mid
buf_ptr_write[3] = buf_ptr_write[1]; // high
buf_ptr_write += 2 * (I2S_BITS_PER_SAMPLE_16BIT / 8);
buf_ptr_read += 2 * (I2S_BITS_PER_SAMPLE_32BIT / 8);
// local echo
bytes_written = samples_read * 2 * (I2S_BITS_PER_SAMPLE_16BIT / 8);
i2s_write_bytes(I2S_NUM_0, buf, bytes_written, portMAX_DELAY);
cnt += samples_read;
if(cnt >= 44100) {
delta = micros - micros_prev;
printf("%d samples in %" PRIu64 " usecs\n", cnt, delta);
cnt = 0;
* entry point
void app_main()
printf("starting app_main()\n");
xTaskCreatePinnedToCore(&task_megaphone, "task_megaphone", 16384, NULL, 20, NULL, 0);
Arduino IDE sketch that prints nothing but 0 (youtube video and GitHub repo):
#include <driver/i2s.h>
#define I2S_WS 15
#define I2S_SD 13
#define I2S_SCK 2
#define I2S_PORT I2S_NUM_0
Serial.println("Setup I2S ...");
i2s_install();
i2s_setpin();
i2s_start(I2S_PORT);
int32_t sample = 0;
int bytes = i2s_pop_sample(I2S_PORT, (char*)&sample, portMAX_DELAY);
if(bytes > 0){
Serial.println(sample);
void i2s_install(){
const i2s_config_t i2s_config = {
.mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX),
.sample_rate = 44100,
.bits_per_sample = i2s_bits_per_sample_t(32),
.communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = 0, // default interrupt priority
.dma_buf_count = 8,
.dma_buf_len = 64,
.use_apll = false
i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
void i2s_setpin(){
const i2s_pin_config_t pin_config = {
.bck_io_num = I2S_SCK,
.ws_io_num = I2S_WS,
.data_out_num = -1,
.data_in_num = I2S_SD
i2s_set_pin(I2S_PORT, &pin_config);
