Midi CC (ControlChange) Adafruit Bluefruit LE
Hello Hi and another Happy New Year in the round ...
I'm Robert from near Hanover and am a complete newcomer to Arduino & Co.
To be honest, I am also not a programmer and only became aware of Arduino because I am a guitarist and have seen that I can convert a foot controller with an Arduino.
THE FOLLOWING:
  • I have a housing with 12x foot switches
  • Each of these switches should send a simple Midi CC command to control the "BIAS FX" software
  • I watched some videos and tutorials and finally came across Merwin's "MIDI_Guitar" project
  • I then ordered an Adafruit Bluefruit LE and wired everything as he did it.
  • I also installed the Sketsch and I managed to connect to my iPad via Bluetooth
  • JAAA, I even have a great MIDI keyboard on the floor now :slight_smile: :smiley:
Because then I found that BIAS FX didn't want to send "notes", but CC's (ControlChanges)
I tried everything "me" possible but unfortunately my knowledge is far from sufficient.
I do not need a "bank" or "octave" switchover, just 12 fixed CC's that are sent to the iPad via the 12 buttons ...
for example like this:
Key 1 sends CC30 with a value of 127
Key 2 sends CC31 with a value of 127
etc etc
Please excuse me if a beginner should be able to do that, but I'm finished with my Latin and would be very grateful for a solution ...
Best wishes
This is the code using by Merwin:
Video for this project here:https://youtu.be/QPgYpVHFSQY
Thank you for checking out my video and my code!
For more videos and information check out
https://www.youtube.com/merwinmusic
http://www.lukemerwin.com/
#include <Arduino.h>
#include <SPI.h>
#if not defined (_VARIANT_ARDUINO_DUE_X_) && not defined (_VARIANT_ARDUINO_ZERO_)
  #include <SoftwareSerial.h>
#endif
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "Adafruit_BLEMIDI.h"
#include "BluefruitConfig.h"
#define FACTORYRESET_ENABLE         0
#define MINIMUM_FIRMWARE_VERSION    "0.7.0"
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
Adafruit_BLEMIDI midi(ble);
bool isConnected = false;
// A small helper
void error(const __FlashStringHelper*err) {
  Serial.println(err);
  while (1);
// callback
void connected(void)
  isConnected = true;
  Serial.println(F(" CONNECTED!"));
void disconnected(void)
  Serial.println("disconnected");
void BleMidiRX(uint16_t timestamp, uint8_t status, uint8_t byte1, uint8_t byte2)
  Serial.print("[MIDI ");
  Serial.print(timestamp);
  Serial.print(" ] ");
  Serial.print(status, HEX); Serial.print(" ");
  Serial.print(byte1 , HEX); Serial.print(" ");
  Serial.print(byte2 , HEX); Serial.print(" ");
const int ButtonPins[12] = {2, 3, 5, 6, 9, 10, 11, 12, 13, 18, 19, 20};
int LastButtonState[12] = {0};
int currentMillis = 0;
int LastButtonChangeTime[12] = {currentMillis};
int NoteNumber[12] = {24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35};
int buttonPushCounter = 0;
void setup(void)
  Serial.println(F("Adafruit Bluefruit MIDI Example"));
  Serial.println(F("---------------------------------------"));
  /* Initialise the module */
  Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )
    error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
  if ( FACTORYRESET_ENABLE )
    /* Perform a factory reset to make sure everything is in a known state */
    Serial.println(F("Performing a factory reset: "));
    if ( ! ble.factoryReset() ) {
      error(F("Couldn't factory reset"));
  //ble.sendCommandCheckOK(F("AT+uartflow=off"));
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  /* Print Bluefruit information */
  ble.info();
  /* Set BLE callbacks */
  ble.setConnectCallback(connected);
  ble.setDisconnectCallback(disconnected);
  // Set MIDI RX callback
  midi.setRxCallback(BleMidiRX);
  Serial.println(F("Enable MIDI: "));
  if ( ! midi.begin(true) )
    error(F("Could not enable MIDI"));
  ble.verbose(false);
  Serial.print(F("Waiting for a connection..."));
for(int i=0; i < 15; i++)
  pinMode(ButtonPins[i],INPUT_PULLUP);
  // interval for each scanning ~ 500ms (non blocking)
  ble.update(250);
  // bail if not connected
  if (! isConnected)
    return;
int octave = (buttonPushCounter * 12);
  for (int i=0; i<15; i++) {
    boolean state = !digitalRead(ButtonPins[13]);  // 'true'==pressed, 'false'==released
    // Check for state change and do debounce
    if (state != LastButtonState[13] && currentMillis-LastButtonChangeTime[13] > 50) {
      LastButtonState[13] = state;
      LastButtonChangeTime[13] = currentMillis;
      if (state){
        buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
    boolean state = !digitalRead(ButtonPins[14]);  // 'true'==pressed, 'false'==released
    if (state != LastButtonState[14] && currentMillis-LastButtonChangeTime[14] > 50) {
      LastButtonState[14] = state;
      LastButtonChangeTime[14] = currentMillis;
      if (state){
        buttonPushCounter--;
  if (buttonPushCounter < -1){
    buttonPushCounter = -1;
  if (buttonPushCounter > 6){
    buttonPushCounter = 6;
  for (int i=0; i<13; i++) {
    boolean state = !digitalRead(ButtonPins[i]);  // 'true'==pressed, 'false'==released
    if (state != LastButtonState[i] && currentMillis-LastButtonChangeTime[i] > 50) {
      LastButtonState[i] = state;
      LastButtonChangeTime[i] = currentMillis;
      if (state)
        midi.send(0xB0, octave + NoteNumber[i], 127);  // Pressed
        midi.send(0xB0, octave + NoteNumber[i], 0);  // Released
Aaaaaand ... the german thread:
https://forum.arduino.cc/index.php?topic=658518.msg4437048#msg4437048
the same with a few answers ... but german :slight_smile: ... and 2 hours older
