Hi guys, Im new in this forum and new in arduino.
im using a secuence effect for Whammy 4 with a switch on pin 2, that works as start/stop sequence loop, I would like to disable/enebale effect too, I mean press switch start loop and effect on, press again stop loop effect off.
I have all the sequence except to stop and off effect, it’s only stop the loop whle the ffect remains on.
A great guy is helping me but I would like to finsih this, my brian will blow away.
thanks
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
const float TEMPO = 120;
const float DELAY = 60 / TEMPO / 4 * 1000;
const float MIN_TREADLE = 0;
const float MAX_TREADLE = 125;
const int LED = 13;
//here you have to check what interrupt pins your board have and set it
const byte interruptPin = 2; //in some arduino board 2 is an interrupt
volatile byte state = LOW; //this is the variable that if it's TRUE sequence run and if FALSE sequence stop
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), toggle, FALLING); //every time you FALL the signal on the button (BUTTON DOWN) execute toggle() function
pinMode(LED, OUTPUT);
MIDI.begin();
void down()
MIDI.sendProgramChange(3, 1);
MIDI.sendControlChange(11, MAX_TREADLE, 1);
delay(DELAY);
void normal()
MIDI.sendControlChange(11, MIN_TREADLE, 1);
delay(DELAY);
void up()
MIDI.sendProgramChange(1, 1);
delay(DELAY);
if(state) {
//put here the code of the midi execution of the last sketch, it will be executed only when state is true.
motp();
// MUSE - Map of the Problematique
void motp()
digitalWrite(LED, HIGH);
down();
digitalWrite(LED, LOW);
normal();
up();
normal();
up();
normal();
down();
normal();
up();
normal();
up();
normal();
down();
normal();
up();
normal();
void toggle() {
state = !state;
midiSendCC(0,0,0); //this is off
midiSendCC(0,127,0); //this is on
void midiSendCC(byte controller, byte value, byte channel) {
byte a = 0xb;
byte b = a << 4;
byte ch = b | channel;
Serial.write(ch);
Serial.write(controller);
Serial.write(value);
//interrupt pin allows you to BREAK the program when input change.
