Midi Over USB and DIN simultaneously
Hi there i'm and absolute newbee at this and am so lost as to why this code isnt working. I have basically been copying example files and pasting into one file and for some reason. its not working.
Im trying to get 7 buttons to send a midi note on/off value to both the midi out (trx) and over the Usb simultaneously. I can get them to work individually but no joy doing them at the same time??
Someone please help!!!!!!
I have included the code and im using a Leonardo board also tried it with the Pro Micro?
HEEEEEEELLLLP
#include <MIDI.h>
#include "Controller.h"
Sample MIDI Controller using 1-button
Written by: Michael Sobolak
For use with an Arduino Pro Micro
Using MIDI_Controller.h from tttapa
https://github.com/tttapa/MIDI_controller
#include <MIDI_Controller.h> // This lets the microcontroller speak "MIDI"
const uint8_t velocity = 0b1111111; // This sets default velocity to 100% (127 value)
const uint8_t C4 = 60; // Name the note you want to play when the button is pushed(can be anything, C3...D5...E2)
const uint8_t Csharp4 = 61;  // uncomment to use in sketch
const uint8_t D4 = 62;  // uncomment to use in sketch
const uint8_t Dsharp4 = 63;
const uint8_t E4 = 64;
const uint8_t F4 = 65;
const uint8_t Fsharp4 = 66;
const uint8_t G4 = 67;
const uint8_t Gsharp4 = 68;
// Format is this: button[number] (pin, note, channel, velocity)
Digital button1(2, C4, 1, velocity);
Digital button2(3, Csharp4, 1, velocity); // uncomment to use in sketch
Digital button3(4, D4, 1, velocity);  //uncomment to use in sketch
Digital button4(5, Dsharp4, 1, velocity);
Digital button5(6, E4, 1, velocity);
Digital button6(7, F4, 1, velocity);
Digital button7(8, Fsharp4, 1, velocity);
Digital button8(9, G4, 1, velocity);
  MIDI CONTROLLER
  by Notes and Volts
  www.notesandvolts.com
  Version 1.2 **Arduino UNO ONLY!**
MIDI_CREATE_DEFAULT_INSTANCE();
//***SET THE NUMBER OF CONTROLS USED**************************
//---How many buttons are connected directly to pins?---------
byte NUMBER_BUTTONS = 8;
//---How many potentiometers are connected directly to pins?--
//byte NUMBER_POTS = 0;
//---How many buttons are connected to a multiplexer?---------
//byte NUMBER_MUX_BUTTONS = 0;
//---How many potentiometers are connected to a multiplexer?--
//byte NUMBER_MUX_POTS = 0;
//***ANY MULTIPLEXERS? (74HC4067)************************************
//MUX address pins must be connected to Arduino UNO pins 2,3,4,5
//A0 = PIN2, A1 = PIN3, A2 = PIN4, A3 = PIN5
//Mux NAME (OUTPUT PIN, , How Many Mux Pins?(8 or 16) , Is It Analog?);
//Mux M1(10, 16, false); //Digital multiplexer on Arduino pin 10
//Mux M2(A5, 8, true); //Analog multiplexer on Arduino analog pin A0
//***DEFINE DIRECTLY CONNECTED POTENTIOMETERS************************
//Pot (Pin Number, Command, CC Control, Channel Number)
//**Command parameter is for future use**
//Pot PO1(A0, 0, 1, 1);
//Pot PO2(A1, 0, 10, 1);
//Pot PO3(A2, 0, 22, 1);
//Pot PO4(A3, 0, 118, 1);
//Pot PO5(A4, 0, 30, 1);
//Pot PO6(A5, 0, 31, 1);
//Add pots used to array below like this->  Pot *POTS[] {&PO1, &PO2, &PO3, &PO4, &PO5, &PO6};
//Pot *POTS[] {};
//***DEFINE DIRECTLY CONNECTED BUTTONS*******************************
//Button (Pin Number, Command, Note Number, Channel, Debounce Time)
//** Command parameter 0=NOTE  1=CC  2=Toggle CC **
Button BU1(2, 0, 60, 1, 5 );
Button BU2(3, 0, 61, 1, 5 );
Button BU3(4, 0, 62, 1, 5 );
Button BU4(5, 0, 63, 1, 5 );
Button BU5(6, 0, 64, 1, 5 );
Button BU6(7, 0, 65, 1, 5 );
Button BU7(8, 1, 66, 1, 5 );
Button BU8(9, 1, 67, 1, 5 );
//Add buttons used to array below like this->  Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4, &BU5, &BU6, &BU7, &BU8};
//***DEFINE BUTTONS CONNECTED TO MULTIPLEXER*************************
//Button::Button(Mux mux, byte muxpin, byte command, byte value, byte channel, byte debounce)
//Button MBU1(M1, 0, 0, 70, 1, 5);
//Button MBU2(M1, 1, 1, 71, 1, 5);
//Button MBU3(M1, 2, 2, 72, 1, 5);
//Button MBU4(M1, 3, 0, 73, 1, 5);
//Button MBU5(M1, 4, 0, 74, 1, 5);
//Button MBU6(M1, 5, 0, 75, 1, 5);
//Button MBU7(M1, 6, 0, 76, 1, 5);
//Button MBU8(M1, 7, 0, 77, 1, 5);
//Button MBU9(M1, 8, 0, 78, 1, 5);
//Button MBU10(M1, 9, 0, 79, 1, 5);
//Button MBU11(M1, 10, 0, 80, 1, 5);
//Button MBU12(M1, 11, 0, 81, 1, 5);
//Button MBU13(M1, 12, 0, 82, 1, 5);
//Button MBU14(M1, 13, 0, 83, 1, 5);
//Button MBU15(M1, 14, 0, 84, 1, 5);
//Button MBU16(M1, 15, 0, 85, 1, 5);
////Add multiplexed buttons used to array below like this->  Button *MUXBUTTONS[] {&MBU1, &MBU2, &MBU3, &MBU4, &MBU5, &MBU6.....};
//Button *MUXBUTTONS[] {};
//***DEFINE POTENTIOMETERS CONNECTED TO MULTIPLEXER*******************
//Pot::Pot(Mux mux, byte muxpin, byte command, byte control, byte channel)
//Pot MPO1(M2, 0, 0, 1, 1);
//Pot MPO2(M2, 1, 0, 7, 1);
//Pot MPO3(M2, 2, 0, 50, 1);
//Pot MPO4(M2, 3, 0, 55, 2);
//Pot MPO5(M2, 4, 0, 50, 1);
//Pot MPO6(M2, 5, 0, 55, 2);
//Pot MPO7(M2, 6, 0, 50, 1);
//Pot MPO8(M2, 7, 0, 55, 2);
//Pot MPO9(M2, 8, 0, 50, 1);
//Pot MPO10(M2, 9, 0, 55, 2);
//Pot MPO11(M2, 10, 0, 50, 1);
//Pot MPO12(M2, 11, 0, 55, 2);
//Pot MPO13(M2, 12, 0, 50, 1);
//Pot MPO14(M2, 13, 0, 55, 2);
//Pot MPO15(M2, 14, 0, 50, 1);
//Pot MPO16(M2, 15, 0, 55, 2);
//Add multiplexed pots used to array below like this->  Pot *MUXPOTS[] {&MPO1, &MPO2, &MPO3, &MPO4, &MPO5, &MPO6.....};
//Pot *MUXPOTS[] {};
  MIDI.begin(MIDI_CHANNEL_OFF);
  if (NUMBER_BUTTONS != 0) updateButtons();
  /*if (NUMBER_POTS != 0) updatePots();
  if (NUMBER_MUX_BUTTONS != 0) updateMuxButtons();
  if (NUMBER_MUX_POTS != 0) updateMuxPots();
void updateButtons() {
  // Cycle through Button array
  for (int i = 0; i < NUMBER_BUTTONS; i = i + 1) {
    byte message = BUTTONS[i]->getValue();
    //  Button is pressed
    if (message == 0) {
      switch (BUTTONS[i]->Bcommand) {
        case 0: //Note
          MIDI.sendNoteOn(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
        case 1: //CC
          MIDI.sendControlChange(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
        case 2: //Toggle
          if (BUTTONS[i]->Btoggle == 0) {
            BUTTONS[i]->Btoggle = 1;
          else if (BUTTONS[i]->Btoggle == 1) {
            MIDI.sendControlChange(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
            BUTTONS[i]->Btoggle = 0;
    //  Button is not pressed
    if (message == 1) {
        case 0:
          MIDI.sendNoteOff(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
        case 1:
void updateMuxButtons() {
  // Cycle through Mux Button array
  for (int i = 0; i < NUMBER_MUX_BUTTONS; i = i + 1) {
    MUXBUTTONS[i]->muxUpdate();
    byte message = MUXBUTTONS[i]->getValue();
    if (message == 0) {
      switch (MUXBUTTONS[i]->Bcommand) {
        case 0: //Note
          MIDI.sendNoteOn(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
        case 1: //CC
          MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
        case 2: //Toggle
          if (MUXBUTTONS[i]->Btoggle == 0) {
            MUXBUTTONS[i]->Btoggle = 1;
          else if (MUXBUTTONS[i]->Btoggle == 1) {
            MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
            MUXBUTTONS[i]->Btoggle = 0;
    if (message == 1) {
        case 0:
          MIDI.sendNoteOff(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
        case 1:
void updatePots() {
  for (int i = 0; i < NUMBER_POTS; i = i + 1) {
    byte potmessage = POTS[i]->getValue();
    if (potmessage != 255) MIDI.sendControlChange(POTS[i]->Pcontrol, potmessage, POTS[i]->Pchannel);
void updateMuxPots() {
  for (int i = 0; i < NUMBER_MUX_POTS; i = i + 1) {
    MUXPOTS[i]->muxUpdate();
    byte potmessage = MUXPOTS[i]->getValue();
    if (potmessage != 255) MIDI.sendControlChange(MUXPOTS[i]->Pcontrol, potmessage, MUXPOTS[i]->Pchannel);
FYI with the code above only the midi out is working!
The reason it is not working is exactly because you have been copying example files and pasting into one file, without understanding what you are doing.
See this note
Note it says:- Arduino UNO ONLY!.
But you say.
also
Which MIDI out is this the one on the 5 pin connector or the USB one?
On a Leonardo or Micro (same processor) to get at a normal serial port, you have to use Serial1, not just Serial, as that port is busy communicating with the USB.
Hey Grumpy Mike thanks for your replies man. Yeah I actually have no idea what i'm doing! I saw that it was for the uno. This part of the code works over usb and then the rest works over TRX so the new guy thought yeah i will just put them together and hope it works!! Obviously I need humbling here!!! Any help is much appreciated!!
And this alone works over TRX midi out
  MIDI CONTROLLER
  by Notes and Volts
//Pot *POTS[] {};
    if (message == 0) {
        case 0: //Note
        case 1: //CC
        case 2: //Toggle
    if (message == 1) {
        case 0:
        case 1:
    if (message == 0) {
        case 0: //Note
        case 1: //CC
        case 2: //Toggle
    if (message == 1) {
        case 0:
        case 1:
void updatePots() {
